Project: ECOfamily Civic and its Aero Hitch Box / Boat Tail
In order to make the Civic a more perfect family car, it needs better aerodynamics, additional cargo space, (and an improvement of ICE efficiency by some method: P&G/EOC for now, maybe a taller transmission on the horizon). An Aero Hitch Box and other mods will improve aerodynamics and increase cargo space.
Aero Hitch Box status :
My best guess for Cd is around 0.30, but the error margin on my estimate is very wide. Crr probably around 0.12 at 45-50 PSI. (Stupid Les Schwab. I really should have upgraded.) I also have some winter tires on here, generally Nov through Apr. Lower-hanging mod to-do list:
Tail-end to-do list:
http://ecomodder.com/forum/member-ch...els-desert.jpg http://ecomodder.com/forum/member-ch...-boat-tail.jpg http://ecomodder.com/forum/member-ch...-fill-side.jpg http://ecomodder.com/forum/member-ch...ncing-rock.jpg http://ecomodder.com/forum/member-ch...l-scofield.jpg http://ecomodder.com/forum/member-ch...ch-box-car.jpg Original post: ====================================== This thread will probably mostly be about my forthcoming hitch-mounted cargo box boat-tail. Okay, not exactly the first time we've seen the general idea, but maybe the first project thread applicable to a sedan. Also I'll have some brief descriptions of other mods on our 97 family-of-four Civic, and of course results. Getting right down to it; my plan for the Aero Hitch Box (avoiding the 'copyrighted' name :D): http://ecomodder.com/forum/member-ch...7civicwbox.jpg Green - the part I'm fabricating. (Black is the hitch receiver on the car.) I'm thinking strip reinforced aluminum sheet, rivet construction. However, that method hasn't got the wife test green light yet. I could probably get it done just as fast in plywood, plus foam/bondo, and it would be more likely to pass the wife test that way, but I expect that would be heavier and less durable. I've sized the space from the bumper to the front of the box to give enough clearance for the trunk to open, plus a half-inch for good measure. I'm probably going to want to put a caster on the main steel post that it will be on to minimize damage in the event of a departure angle violation, but I probably need to experiment in my driveway. Now, I see some aerodynamic gaps here to fill. The only question is how far do I need to go to get good results? I expect this to require some testing to be sure about it. Possible Gap Fill Remedies: Opaque Half-Kammback (orange) with clear plastic side fillers (blue): http://ecomodder.com/forum/member-ch...cwboxnkamm.jpg Full-Kammback with hinged window (or louvers): http://ecomodder.com/forum/member-ch...xnliftkamm.jpg All the remedies attach to the car, so you can imagine with the aero box off the car roughly fits a Prius profile with a full Kammback. Any thoughts so far? Hoping to get this done before spring, but you never know with me. ============================================ Random background notes, if you want them:
=================================== I will be editing this post for current status and index. |
Sounds like a great project. I await more updates. :)
Subscribed.
troposphilic
You've covered the major bases,so you can expect the out-of-the-park home run as soon as she's on the road.
Whereas the sky is presently experiencing tropos-fear when it see's you coming,that won't be he case later. We'll induct you into the End-dependent Oil Producers Association,as your car will be producing nega-barrels of oil out of thin air as she 'barrels' down the highway once she's shaken her money-maker. And don't be surprised should you receive a membership invitation from the (F)riends of (A)erodynamic (R)ennaissance (T)echnology,whom just love to pass gas (stations) with their retrodynamic cars. Welcome to the past! I think you'll dig it.:D |
Shouldn't the top half of the hitch aero box conform to a taper from the roof line (From top down view), instead of the rear fender panel? The top half of the box should look like a miniature version of the silhouette of your car. That is, if you are trying to go for maximum aerodynamic efficiency.
top half
If the top portion is deleted you'll pay some in extra drag,but 'practicalities' may demand that you stray from the ideal.The missing link should create a locked-vortex of which the outer flow field will skip over. |
What's your wife's issue with sheet alu construction ? It's visually the cleanest method of construction, lighter than wood and if you keep it galvanically separated from steel, more durable as well. Quote:
So you'll have a decent part the positive effects of a boattail even if you use just the cargo box. What you might want to fill up is the hole between the cargo box and the car, so you won't have air cross-drafting and causing drag. |
I have heard about the idea before, but I did not know that it went anywhere. Make it so, Number One! :)
You could put the bottom contour at ~10° and extend a flap all the way to the back of the gas tank/spare tire well or whatever's under there. What do you plan to do to keep the taillights visible? |
