Old 09-27-2011, 06:33 PM   #1 (permalink)
Project: electric assisted quadracycle or ped
I've been lurking for sometime soaking up as much knowledge as possiable to bring my project to life. Being well on the way at the drawing board, there are a few things, I've not found an answer for. OK, it will be chain driven, two seater side by side pedals, like on a paddle boat. It will be pretty heavy duty. I want the pedals to coast or engage depending on the need, by clutch or ? Not clear on centripetal clutch, or would it need a derailer? Any suggestion?
Old 09-27-2011, 06:51 PM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '011 Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Here are some good kits and parts for a pedal / electric vehicle: Worlds best Electric bicycle recumbent DIY conversion kits kit NuVinci Electric Scooter e-bike worlds best Electric bicycle recumbent DIY conversion kits kit Worlds best Electric bicycle recumbent DIY conversion kits kit NuVinci Electric Scooter e-bi
The Following User Says Thank You to dennyt For This Useful Post:
Green Jeanne (09-28-2011)
Old 09-27-2011, 08:48 PM   #3 (permalink)
Wow, that pretty spendy! Looks like a cross of coaster brake and centripetal clutch. Still look for a DIY fix. Thanks
Old 09-28-2011, 12:29 AM   #4 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
This design looks like it uses conventional bicycle parts to drive the rear wheels independently. I think the plans are $17 from their website.
Then you might be able to adapt a kit like this to it:
24V 250W ELECTRIC MOTORIZED E BIKE CONVERSION KIT | eBay
Or if you use conventional bicycle forks for your front wheels you can use hub motor wheels in the front.
EZ-Glide Electric Bike kit for 26 in Bicycle | eBay
The Following User Says Thank You to Patrick For This Useful Post:
Old 09-28-2011, 03:05 AM   #5 (permalink)
I have been helping this guy:
About-face bike turns many heads - oddstuff | Stuff.co.nz
I have this bike in my garage at the moment, I am doing some work on the mechanics and also the wiring.
Old 09-28-2011, 10:02 AM   #6 (permalink)
Patrick's Avatar
What type of chain reversing mechanism does it have for the stoker?
Old 09-28-2011, 02:33 PM   #7 (permalink)
it has two open gears, I will take some pictures as soon as I get a chance, Ithere are just too many mechanical bit, gears, chains, sprockets, etc.
Old 09-28-2011, 02:36 PM   #8 (permalink)
Would one of these be heavy duty enough? I'm using is 36v & controller out of a ezgo golf cart & motorcycle tires. The design will be like a horseless carriage/beach surrey.
Old 09-29-2011, 03:16 AM   #9 (permalink)
BikerModder's Avatar
I don't think the frame strong right? All that right?
First thing what tools do you need for the job?
Walk around the machine and see if any thing looks unsafe
outline the steps to complete the job.
You want bug splat on the goggles I guess and all that.
Old 09-29-2011, 01:16 PM   #10 (permalink)
Thanks for the insight. Just what I was looking for, help to make sure I'm not missing anything. The project will be built from the frame up. The frame design is taken from original electric horseless carriage spec's & diagrams adapted to include pedals. Full shop and tools are at the ready, while a massing the parts. Gaining from the links given, the clutch will have to manufactured. If one beefy enough can't be found.
bicycle, clutch, moped
