11-24-2009, 08:37 PM
#131 (permalink )
Left Lane Ecodriver
Thank you for being rigorous as always. Hopefully, you'll see a big improvement with the belly pan.
The car is roughly symmetrical, so you might be able to either save time or increase the resolution (number of tufts) by testing only half of the car.
11-24-2009, 09:59 PM
#132 (permalink )
Moderate your Moderation.
wagonman76 -
The few companies I looked into for the opportunity to use Cara for some ad space had waivers that the drivers had to sign, basically absolving them of all responsibility for damage to the vehicle whether due to advertising materials or otherwise. I'm pretty sure it's not a liability for them, really.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
11-24-2009, 10:32 PM
#133 (permalink )
Originally Posted by
RobertSmalls
Good point. That's my plan for tuft testing the top & side of the boat tail.
Tidbit: I got out my undertray panels (coroplast & aluminum flashing) which I put away after
testing them in September 2006 . Will reinstall them tomorrow.
Other tidbit: I nearly wrecked the web cam today! Backing into the driveway after the last video run this afternoon I smacked the cam hard against the curb/lip of the driveway - it had been mounted low to the ground below the rear mud flap, looking up & backwards at the boat tail. Lucky me: despite some gouges & yanking the wire free from the housing, it still seems to work!
11-24-2009, 11:16 PM
#134 (permalink )
MetroMPG, honest, I scanned this whole thread first, I hate wasting bandwidth and I apologize if you've already told us, but what web cam are you using? In fact, I wouldn't mind seeing a pic of your webcam mounted as you did to observe the bottom of the boat tail.
PS--Majestic, that's a remarkable act of photoshopping you did there. I took it for real the first two times I saw it.
11-24-2009, 11:35 PM
#135 (permalink )
Hi Jack - It's a
Logitech Quickcam Pro 5000, I think . It came with a used laptop I got - didn't realize how useful it would be!
You can see it (the cam is the little sphere) duct taped to the end of a yardstick beneath the end of the boat tail in the 3rd photo in
post 129 , above.
And you can see it in action in a previous
Edit: I spliced in an extension to the wire so I could mount the cam on the back corner of the vehicle, and still reach the laptop sitting on the passenger seat. Today's test with the longer boat tail required yet another USB extension.
Darin
11-25-2009, 05:02 PM
#136 (permalink )
Got the belly pan installed this afternoon.
I'm convinced it's going to make a significant improvement to the flow on the bottom of the boat tail. The middle 25% or so of the belly pan is a straight shot between the rear control arms in line with the plane of the bottom of the boat tail.
One thing left to do: I'll do my best to blend/transition the control arms back to the boat tail as well.
All in all, I figure 50% of the boat tail bottom will have fully attached & relatively smooth flow, vs. 0% smooth flow now.
Unfortunately, it's rainy today, so I can't do tuft testing. Tomorrow looks decent though.
11-25-2009, 05:49 PM
#137 (permalink )
Grrr :-)
how steep an angle can you go before losing laminar flow? I am wondering if you can make the angle higher and the tail SHORTER and get the same results. the flow seems awfully stable on top. it should be JUST on the verge of going unstable to be at optimum.
I ask because I am driving out to colorado next summer in my van. I am thinking of adding a giant boat tail to the back that will pivot UP onto the roof when I am parking etc.. (the van is already longer than some parking spaces so permanent tail would be a big nono :-)
The shorter I can make it the better!
11-25-2009, 05:56 PM
#138 (permalink )
Ultimate Fail
MetroMPG
And the area behind those mudflaps ...
? ( ducks for cover
11-25-2009, 06:04 PM
#139 (permalink )
Ultimate Fail
It's too bad you can't create some sort of a flush NACA ducting on the bottom of the tail and have it exhaust some air around the dead zone.
That would be a waste of time, since you wouldn't produce any usable air pressure out of it, right ? ( Would it also create more drag ? )
It would look cool though.
11-25-2009, 06:21 PM
#140 (permalink )
Nerys
Note the difference between attached flow and laminar flow. Very few automobiles (with the exception of solar cars, and maybe the Aptera) would have laminar flow over a significant portion of the body. For a discussion of the different flow types, see this thread:
A Crash Course in Aerodynamics and an Introduction to Turbulence
I've seen figures ranging from 10-15 degrees as the highest initial change you can do while retaining attached flow, and up to and beyond 20 if the transition is gradual (think curve, not sharp angle).
Yup, exactly.
FYI, the top of my boat tail curves gradually from the roof to ~15.x degrees from horizontal. For the sides, I aimed for a transition of ~10 degrees, also taking advantage of the OEM curvature at the rear corners. (But since I accidentally made it off kilter, one side is actually less, the other more.)
I aimed for a smaller angle on the sides because I figure the boundary layer there (compared to the top of the car) is already more turbulent - from windows, mirror, front wheels, panel gaps, trim - and less likely to stay attached on a more aggressive taper. Only a guess though. I'm just making this up as I go along
It would take a fair amount of effort to keep refining the boat tail to find the "verge of going unstable" for a particular car. I'm going to be satisfied with my boat tail if the air likes it the way it is with these angles. I could keep refining until the cows come home, or make a best guess, and be happy with it if it appears to work (which it does so far).
LinkBacks (? )
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-geo-metro-boat-tail-prototype-15-mpg-10691.html
Posted By
For
Type
Date
AeroProject: Prototipo Punto "Economy power"
This thread
Refback
Yesterday 11:59 AM
AeroProject: Impressioni da una gita fuori porta
This thread
Refback
01-10-2012 11:34 AM
BlogYueNMe: Aerodynamic tail makes Geo Metro even cooler
This thread
Refback
01-01-2012 04:20 PM
Club smart Car > The 100 MPG Challenge 2.011
This thread
Refback
12-20-2011 08:20 AM
achieving an optimal shape
This thread
Refback
12-15-2011 12:39 PM
Elektromos Auto - Index Frum
This thread
Refback
11-22-2011 03:25 AM
Keversite.NL • Toon onderwerp - Dakspoiler
This thread
Refback
11-20-2011 02:49 PM
The ten nerdiest ways to modify your car
This thread
Refback
11-11-2011 12:10 PM
AeroProject: Pressione degli pneumatici
This thread
Refback
11-06-2011 05:20 PM
Raw video for: "Testing aerodynamic boat tail +15% MPG" - YouTube
This thread
Refback
11-03-2011 10:57 AM
17 DIY Cars Hacked for Fuel Efficiency : Page 6 : TreeHugger
This thread
Refback
11-02-2011 01:50 PM
DonsDeals: Aerodynamic tail makes Geo Metro even cooler - Hack a Day
This thread
Refback
11-01-2011 07:19 AM
BlogYueNMe: February 2010
This thread
Refback
10-31-2011 04:28 AM
Hypermiling | Autopia | Wired.com
This thread
Refback
10-22-2011 08:54 AM
Energy News
This thread
Refback
10-17-2011 11:08 AM
MAKE | Green
This thread
Refback
10-10-2011 05:34 AM
"Offtopic-posts-topic" NSFW - Page94
This thread
Refback
10-01-2011 05:41 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
This thread
Refback
09-28-2011 04:35 PM
Testing an aerodynamic boat tail - 15% better MPG - Geo Metro - YouTube
This thread
Refback
09-26-2011 10:21 AM
Attention, Greenies: Your Geo Metro Needs A Boattail
This thread
Refback
09-18-2011 09:09 PM
MAKE | DIY Projects
This thread
Refback
09-11-2011 05:12 AM
AeroProject: Aerodinamica ruote (parte 2)
This thread
Refback
08-30-2011 04:57 PM
AeroProject: Flow Illustrator Moviemaker
This thread
Refback
08-24-2011 05:10 PM
kamm back and golfball texture on rear of car. any design info? : engineering
This thread
Refback
07-27-2011 02:21 PM
‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ - YouTube
This thread
Refback
07-20-2011 11:57 AM
Streamlined? - Page 2
This thread
Refback
07-05-2011 07:40 AM
YouTube - ‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏
This thread
Refback
06-29-2011 04:18 AM
Bil Hjemmelaget Båt Tail Car modifikasjonssett Gir Geo Metro Amazing Fuel Economy
This thread
Refback
06-09-2011 04:57 PM
archives for 04/2010
This thread
Refback
05-14-2011 08:55 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green
This thread
Refback
04-11-2011 01:56 PM
The 100 MPG Challenge 2.011 - Club smart Car
This thread
Refback
04-09-2011 09:47 PM
Make: Online | MPG boosting tail cone
This thread
Refback
04-09-2011 03:19 PM
Pointes arrires
This thread
Refback
03-28-2011 06:36 PM
Motórum • Toon onderwerp - funny fototopic
This thread
Refback
03-17-2011 04:53 PM
Search Results firefly Hack a Day
This thread
Refback
03-11-2011 05:08 PM
impressive s2k mpg! - S2KI Honda S2000 Forums
This thread
Refback
03-01-2011 11:27 PM
AeroProject: Giusto per chiarirsi.
This thread
Refback
02-13-2011 07:38 PM
oldsmobile aerotech | Le Pics
This thread
Refback
02-10-2011 03:00 PM
Auto Home made boat tail Auto Retrofit Geeft Geo Metro Amazing Fuel Economy
This thread
Refback
02-01-2011 04:51 AM
This thread
Refback
01-22-2011 01:25 PM
DIY automobile aerodynamic modification
This thread
Refback
01-14-2011 03:13 AM
Weight loss program for a Class B motorhome on an '89 E250 SD chassis - Page 3 - Ford Truck Enthusiasts Forums
This thread
Refback
01-09-2011 12:21 AM
Jullie mening gevraagd?? Onzin of waarheid?? - Focusclub.nl | Forum
This thread
Refback
12-15-2010 06:04 PM
Wind tunnel testing
This thread
Refback
11-24-2010 10:16 PM
Pointes arrières
This thread
Refback
11-09-2010 01:08 PM
Geo Metro: Geo Metro Photos, Wallpapers, Galleries, metro boat
This thread
Refback
11-05-2010 10:46 PM
Nopeusrajoituksia alennetaan 20-40 km/h!
This thread
Refback
10-03-2010 12:52 PM
Weekly Archive for January 3, 2010 : TreeHugger
This thread
Refback
09-17-2010 02:08 PM
Steel Aero Wheels For MoreMPG - RecycleBlog - RecycleBills
This thread
Refback
09-05-2010 06:40 AM
Coches eficientes y aerodinamicos sin comprar uno nuevo
This thread
Refback
08-26-2010 03:02 PM
Boat Tail - Kosmix : Reference, Videos, Images, News, Shopping and more...
This thread
Refback
08-17-2010 06:35 PM
S2000 Forums -> impressive s2k mpg! : S2KI
This thread
Refback
08-14-2010 08:08 PM
geo metro - Jalopnik
This thread
Refback
08-10-2010 09:52 AM
Energy News
This thread
Refback
07-20-2010 05:27 PM
This thread
Refback
07-15-2010 06:54 AM
This thread
Refback
07-11-2010 08:44 PM
Aerodynamic tail makes Geo Metro even cooler | PS2Cover.com News
This thread
Refback
07-09-2010 02:25 PM
????, ?????(??) : monogocoro ????? - Part 10
This thread
Refback
06-23-2010 05:31 AM
cool but ugly Archives : TreeHugger
This thread
Refback
06-20-2010 11:13 AM
Detto | Motorcafè il blog dei motociclisti dalla mente aperta
This thread
Refback
06-01-2010 03:00 AM
Keversite.NL • Bekijk onderwerp - Dakspoiler
This thread
Refback
05-31-2010 05:24 AM
Jalopnik: Obsessed With The Cult Of Cars
This thread
Refback
05-29-2010 05:04 PM
Autoblog Green
This thread
Refback
05-21-2010 01:36 PM
Bike Hugger: DL Byron: January 2010 Archives
This thread
Refback
05-14-2010 12:06 PM
citrina/straisniai/aerodinamika
This thread
Refback
05-06-2010 04:57 AM
ifeelgassy - Jalopnik
This thread
Refback
05-05-2010 05:58 PM
Home made boat tail auto Retrofit Geeft Geo Metro Amazing Fuel Economy Cars Transportation buildaroo.com
This thread
Refback
05-01-2010 06:27 AM
????, ???? : monogocoro ????? - Part 7
This thread
Refback
04-25-2010 03:56 AM
17 DIY Cars Hacked for Fuel Efficiency : TreeHugger
This thread
Refback
04-23-2010 01:03 PM
Walden Effect: Homesteading and Simple Living Blog
This thread
Refback
04-19-2010 08:14 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com
This thread
Refback
03-31-2010 10:09 PM
This thread
Refback
03-31-2010 04:56 PM
Ricerca Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta
This thread
Refback
03-30-2010 12:52 PM
How To Change A Tail Light In Geo Prizm - Kosmix : Reference, Videos, Images, News, Shopping and more...
This thread
Refback
03-27-2010 10:31 PM
Stop Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta
This thread
Refback
03-22-2010 05:06 PM
2009 December 25 | PS2Cover.com News
This thread
Refback
03-21-2010 05:17 AM
How To: Paritial Kammback
This thread
Refback
03-19-2010 10:00 PM
2010 January 07 | The Entertainment Blog
This thread
Refback
03-19-2010 04:00 PM
Fuel Economy | Autopia | Wired.com
This thread
Refback
03-06-2010 07:57 AM
La Cacharrería: un blog de tecnología diferente - Part 2
This thread
Refback
02-18-2010 12:41 PM
S2KI - S2000 Forums -> impressive s2k mpg!
This thread
Refback
02-04-2010 02:28 AM
cars Archives : TreeHugger
This thread
Refback
01-30-2010 12:58 PM
Transportation-buildaroo.com
This thread
Refback
01-20-2010 04:54 AM
Kawasaki Triples WorldWide • View topic - Bike maintaining Tips ....
This thread
Refback
01-18-2010 01:53 PM
Anno | Motorcafè il blog dei motociclisti dalla mente aperta
This thread
Refback
01-16-2010 12:36 PM
This thread
Refback
01-12-2010 10:26 PM
Slashdot Submission | Aerodynamic tail on Geo Metro boosts MPG 15%
This thread
Refback
01-12-2010 07:13 PM
Slashdot - News for nerds, stuff that matters
This thread
Refback
01-12-2010 06:57 PM
Autopia - Part 5
This thread
Refback
01-12-2010 05:47 PM
Cool Cars | Autopia | Wired.com
This thread
Refback
01-11-2010 04:28 PM
This thread
Refback
01-10-2010 01:04 AM
This thread
Refback
01-09-2010 10:03 AM
Ingeniøren Mobil
This thread
Refback
01-09-2010 06:27 AM
Spar 15 procent med en grim hale - Motorbloggen | Ingeniøren
This thread
Refback
01-08-2010 05:04 AM
Difícil de aparcar, sí; ¡pero gasta como un mechero! | La Cacharrería
This thread
Refback
01-07-2010 02:34 PM
monogocoro ????? - Part 4
This thread
Refback
01-07-2010 10:58 AM
Motorcafè il blog dei motociclisti dalla mente aperta - Part 2
This thread
Refback
01-07-2010 10:00 AM
Chuck Squatriglia | Autopia | Wired.com
This thread
Refback
01-06-2010 08:25 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Topic Powered by Social Strata
This thread
Refback
01-06-2010 07:00 PM
Design & Architecture Archives : TreeHugger
This thread
Refback
01-05-2010 12:58 AM
insidE of jaXonz
This thread
Refback
01-04-2010 11:02 PM
Buzz Punching: "Boat Tail" Increases Car's Miles Per Gallon by 15.1%
This thread
Refback
01-04-2010 10:47 PM
Guy Adds Boat Tail to Car, Increases MPG by 15.1% : TreeHugger
This thread
Refback
01-04-2010 03:28 PM
TreeHugger
This thread
Refback
01-04-2010 03:18 PM
Cars & Transportation Archives : TreeHugger
This thread
Refback
01-04-2010 02:16 PM
Items Tag RIT Make Club Idea Stream
This thread
Refback
01-04-2010 01:16 PM
Oszcz?dzaj paliwo z aerodynamicznym ogonem! (wideo) | Gad?etomania.pl
This thread
Refback
01-04-2010 12:14 PM
Teemu's planet
This thread
Refback
01-02-2010 10:15 AM
Bike Hugger
This thread
Refback
01-02-2010 08:55 AM
Daily DIY Network - Science Projects Plans Guides Blog Archive MPG boosting tail cone
This thread
Refback
01-02-2010 01:08 AM
This thread
Refback
01-01-2010 08:22 PM
Make: Online
This thread
Refback
01-01-2010 08:11 PM
Autopia - Part 2
This thread
Refback
01-01-2010 08:06 PM
siani_hedgehog's Friends
This thread
Refback
01-01-2010 06:09 PM
Make: Online : MPG boosting tail cone
This thread
Refback
01-01-2010 05:21 PM
Make: Online
This thread
Refback
01-01-2010 05:13 PM
A New Years Resolution - Bike Hugger
This thread
Refback
01-01-2010 12:17 PM
Firefly efficiency mods - MetroMPG.com
This thread
Refback
01-01-2010 02:42 AM
green hacks - Hack a Day
This thread
Refback
12-31-2009 04:02 PM
FFFFOUND! | flea-boat-tail-collage.jpg (JPEG Image, 500x363 pixels)
This thread
Refback
12-31-2009 10:56 AM
PWnT 2009 - (P)ost (W)hori(n)' (T)hread - Page 10598 - CarForums.net - Automotive Chat Forum
This thread
Refback
12-30-2009 08:08 PM
GeenStijl : Sneller, Scherper, Beter (maar eigenlijk komt hier een betere tagline)
This thread
Refback
12-30-2009 03:01 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage — Autoblog Green
This thread
Refback
12-29-2009 10:01 PM
Jalopnik - Attention, Greenies: Your Geo Metro Needs A Boattail
This thread
Refback
12-29-2009 09:46 PM
Interesting New Products and Inventions: Boat Tail improves Mileage
This thread
Refback
12-29-2009 08:25 PM
Autoblog Green — We Obsessively Cover The Green Scene
This thread
Refback
12-29-2009 08:09 PM
Attention, Greenies: Your Geo Metro Needs A Boattail - hypermiling - Jalopnik
This thread
Refback
12-29-2009 06:17 PM
This thread
Refback
12-29-2009 06:16 PM
YouTube - EcoModderDOTcom's Channel
This thread
Refback
12-29-2009 05:19 PM
GeenStijl
This thread
Refback
12-29-2009 03:19 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend
This thread
Refback
12-29-2009 12:41 PM
This thread
Refback
12-29-2009 11:46 AM
GeenStijl : 15% zuiniger rijden met iedere auto!
This thread
Refback
12-29-2009 11:35 AM
GeenStijl
This thread
Refback
12-29-2009 11:16 AM
GeenStijl : 15% Zuinig rijden met iedere auto!
This thread
Refback
12-29-2009 11:16 AM
This thread
Refback
12-29-2009 11:15 AM
This thread
Refback
12-29-2009 11:04 AM
Aerodynamic long tail improves fuel efficiency 15 percent
This thread
Refback
12-29-2009 04:24 AM
Autopia
This thread
Refback
12-29-2009 01:37 AM
This thread
Refback
12-28-2009 07:55 PM
DIY ‘Boat Tail’ Gives Little Car Big Fuel Economy | Autopia | Wired.com
This thread
Refback
12-28-2009 02:22 PM
Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Madshrimps Forum Madness
This thread
Refback
12-28-2009 08:16 AM
R4 DS Cards, R4 DS and Wii Modchip News And Reviews
This thread
Refback
12-27-2009 04:21 PM
Mike Szczys - Hack a Day
This thread
Refback
12-26-2009 06:51 PM
transportation hacks - Hack a Day
This thread
Refback
12-26-2009 08:35 AM
mpg - Hack a Day
This thread
Refback
12-26-2009 08:05 AM
Friends
This thread
Refback
12-26-2009 07:57 AM
Hack: Aerodynamic tail makes Geo Metro even cooler -> ASTALAVISTA.com - the hacking & security community
This thread
Refback
12-26-2009 04:36 AM
the other end of the spectrum...
This thread
Refback
12-25-2009 11:44 PM
YouTube - Raw video for: "Testing aerodynamic boat tail +15% MPG"
This thread
Refback
12-25-2009 10:51 PM
YouTube - Testing an aerodynamic boat tail - 15% better MPG - Geo Metro
This thread
Refback
12-25-2009 07:07 PM
You put WHAT on your car? Stupid shit we've seen people put on their cars - The Something Awful Forums
This thread
Refback
12-25-2009 07:03 PM
Hack a Day
This thread
Refback
12-25-2009 05:24 PM
Geo Metro Mpg - Kosmix : Reference, Videos, Images, News, Shopping and more...
This thread
Refback
12-24-2009 07:07 AM
