Old 12-05-2009, 04:23 AM   #211 (permalink)
Grrr :-)
Nerys's Avatar
V ger - '96 Voyager SE
90 day: 22.21 mpg (US)
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 59 mpg (US)
well man now we are talking a whole different kind of snow. I have done a lot of snow driving when we used to actually get some snow around here. I miss it a lot.
also most of my cars have cavernouse enough wheels wells that this would never be an issue enclosed or not. I could see it maybe being a problem on the metro. I wonder of a teflon coating on the inside of the wheel well would be enough to prevent the ice from building up in the first place. another idea is heaters under the wells but that raises safety concerns unless you used a hot water circulation system but then your now talking ultra complex.
Interesting issue. There are an assortment of cars that come with skirts stock. I wonder how they deal with the problem or if most have large enough wells not to be a problem.
Old 12-05-2009, 10:27 AM   #212 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
I've had no problems with snow packing in the wheel wells when driving on snowy roads in the NC mountains. The front wells are kept warm by air exhausted from the radiator.
aerocivic.com
Old 12-05-2009, 11:07 AM   #213 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
For what it's worth, I've had the rear skirts on for 2 Ontario (more snowy) and 1 Nova Scotia (less snowy) winters without any problems. Haven't had to remove them to clear ice.
Obviously the Ontario snow doesn't compare to what guitarguy sees in Colorado.
Also, I don't drive a lot.
Old 12-05-2009, 11:15 AM   #214 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
Thanks. In my perspicacious and verbose way, that's about all I was trying to say.
Old 12-05-2009, 12:16 PM   #215 (permalink)
pstrbrc's Avatar
Actually, just butting in here 'cause I found a couple of copper colored coins in my pocket and wanted to throw them out,
Spent most of my life in the kind of winters theguitarguy pictured earlier, and have to admit that I've had the same concerns. But then I read you canucks and nor'easters saying it's no problem. So I think.
That's never good for the digestion.
But...
rear wheel skirts might be OK on a front wheel drive. Now that I reflect, all of my serious "wheel well packed with slush-turned-to-ice so tightly the wheel is frozen solid" experience has been on the front wheels of a front wheel drive car. Huh. So, maybe, even in the worst wet-snow-turned-to-slush-then refreezing-into-a-gianormous-block scenario wouldn't be a problem on a fwd with rear wheel skirts. Not that I wouldn't advise removing a front air dam before driving in the snow!
And remembering how many times I've gotten "highcentered" on snow that you could drive on until you stopped, which was when you sank through the bottom three inches of "slushpack", I'm not sure a bellypan would survive a typical Colorado winter. Removing skirts and airdam is one thing, but to have to do it to a bellypan? AAARRRGGGHHH!
'96 Escort LX, now known as "deerslayer"
'84 Merc Grand Marquis, affectionately known as "le barge"
~35,000 mostly 2 lane highway miles a year.
I was born a Rambler man, but with the passing of AMC (sigh), just give me another Ford.
How many kids with A.D.D. does it take to change a light bulb?
Hey, ya wanna go ride bikes?
Old 12-05-2009, 04:24 PM   #216 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.88 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Have you checked out the ironwork on the tornado intercept vehicles? The Dominator...
Old 12-05-2009, 04:28 PM   #217 (permalink)
pack ice
Originally Posted by thatguitarguy View Post
This doesn't sound right to me. The reason they have 10 ton front loaders moving snow around here is that it doesn't just gently move to the side. And every vehicle I've ever driven in the snow (many) has collected packed ice and snow inside the wheel wells. This much enclosure around a wheel could be a disaster. This configuration looks to me to be a dry weather set up.
It's a challenge to find low budget aerodynamic solutions. It's a real challenge to find a usable balance between a Bonneville test vehicle and a daily commuter.
I've been able to muddle through Salt Lake and over the mountains,Vail Pass,etc.,into Colorado and then south and over Raton Pass with all sorts of aero appendages in significant snows.
I was "clenched" a lot of those miles,but it worked out okay.
If I were designing for 4-seasons I might consider exotic Rube Goldbergesque technology for the wheel areas but sofar,low tech has doe pretty well.
Old 12-05-2009, 06:51 PM   #218 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I've had skirts on through winter and no freeze up. Well, actually it was the car that had the skirts.
And I've had cars with no skirts totally get the wheelwells packed with frozen slush to where the car would barely be able to steer until I got out, laid on the ground, and kicked the ice out. I'm very glad there were no skirts in the way for that condition.
I guess I'd say run the skirts but they should be easy to take off if needed. Or if you are in an area that sees those ice-up conditions more than rarely, run without the skirts for those few months.
Old 12-05-2009, 07:41 PM   #219 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If the mods become a problem, just take 'em off when you think you might get snow.
Now about that boat tail.....( hint )
Old 12-05-2009, 07:51 PM   #220 (permalink)
A-B-A testing done. Went well - really good testing conditions (little wind).
Not telling yet. Got stuff to do tonight & tomorrow.
But I added a poll to this thread if anyone wants to guess.
boat tail, testing
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-geo-metro-boat-tail-prototype-15-mpg-10691.html
Posted By For Type Date
AeroProject: Prototipo Punto "Economy power" This thread Refback Yesterday 11:59 AM
AeroProject: Impressioni da una gita fuori porta This thread Refback 01-10-2012 11:34 AM
BlogYueNMe: Aerodynamic tail makes Geo Metro even cooler This thread Refback 01-01-2012 04:20 PM
Club smart Car > The 100 MPG Challenge 2.011 This thread Refback 12-20-2011 08:20 AM
achieving an optimal shape This thread Refback 12-15-2011 12:39 PM
Elektromos Auto - Index Frum This thread Refback 11-22-2011 03:25 AM
Keversite.NL • Toon onderwerp - Dakspoiler This thread Refback 11-20-2011 02:49 PM
The ten nerdiest ways to modify your car This thread Refback 11-11-2011 12:10 PM
AeroProject: Pressione degli pneumatici This thread Refback 11-06-2011 05:20 PM
Raw video for: "Testing aerodynamic boat tail +15% MPG" - YouTube This thread Refback 11-03-2011 10:57 AM
17 DIY Cars Hacked for Fuel Efficiency : Page 6 : TreeHugger This thread Refback 11-02-2011 01:50 PM
DonsDeals: Aerodynamic tail makes Geo Metro even cooler - Hack a Day This thread Refback 11-01-2011 07:19 AM
BlogYueNMe: February 2010 This thread Refback 10-31-2011 04:28 AM
Hypermiling | Autopia | Wired.com This thread Refback 10-22-2011 08:54 AM
Energy News This thread Refback 10-17-2011 11:08 AM
MAKE | Green This thread Refback 10-10-2011 05:34 AM
"Offtopic-posts-topic" NSFW - Page94 This thread Refback 10-01-2011 05:41 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-28-2011 04:35 PM
Testing an aerodynamic boat tail - 15% better MPG - Geo Metro - YouTube This thread Refback 09-26-2011 10:21 AM
Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 09-18-2011 09:09 PM
MAKE | DIY Projects This thread Refback 09-11-2011 05:12 AM
AeroProject: Aerodinamica ruote (parte 2) This thread Refback 08-30-2011 04:57 PM
AeroProject: Flow Illustrator Moviemaker This thread Refback 08-24-2011 05:10 PM
kamm back and golfball texture on rear of car. any design info? : engineering This thread Refback 07-27-2011 02:21 PM
‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ - YouTube This thread Refback 07-20-2011 11:57 AM
Streamlined? - Page 2 This thread Refback 07-05-2011 07:40 AM
YouTube - ‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ This thread Refback 06-29-2011 04:18 AM
Bil Hjemmelaget Båt Tail Car modifikasjonssett Gir Geo Metro Amazing Fuel Economy This thread Refback 06-09-2011 04:57 PM
archives for 04/2010 This thread Refback 05-14-2011 08:55 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 04-11-2011 01:56 PM
The 100 MPG Challenge 2.011 - Club smart Car This thread Refback 04-09-2011 09:47 PM
Make: Online | MPG boosting tail cone This thread Refback 04-09-2011 03:19 PM
Pointes arrires This thread Refback 03-28-2011 06:36 PM
Motórum • Toon onderwerp - funny fototopic This thread Refback 03-17-2011 04:53 PM
Search Results firefly Hack a Day This thread Refback 03-11-2011 05:08 PM
impressive s2k mpg! - S2KI Honda S2000 Forums This thread Refback 03-01-2011 11:27 PM
AeroProject: Giusto per chiarirsi. This thread Refback 02-13-2011 07:38 PM
oldsmobile aerotech | Le Pics This thread Refback 02-10-2011 03:00 PM
Auto Home made boat tail Auto Retrofit Geeft Geo Metro Amazing Fuel Economy This thread Refback 02-01-2011 04:51 AM
Motórum • Toon onderwerp - funny fototopic This thread Refback 01-22-2011 01:25 PM
DIY automobile aerodynamic modification This thread Refback 01-14-2011 03:13 AM
Weight loss program for a Class B motorhome on an '89 E250 SD chassis - Page 3 - Ford Truck Enthusiasts Forums This thread Refback 01-09-2011 12:21 AM
Jullie mening gevraagd?? Onzin of waarheid?? - Focusclub.nl | Forum This thread Refback 12-15-2010 06:04 PM
Wind tunnel testing This thread Refback 11-24-2010 10:16 PM
Pointes arrières This thread Refback 11-09-2010 01:08 PM
Geo Metro: Geo Metro Photos, Wallpapers, Galleries, metro boat This thread Refback 11-05-2010 10:46 PM
Nopeusrajoituksia alennetaan 20-40 km/h! This thread Refback 10-03-2010 12:52 PM
Weekly Archive for January 3, 2010 : TreeHugger This thread Refback 09-17-2010 02:08 PM
Steel Aero Wheels For MoreMPG - RecycleBlog - RecycleBills This thread Refback 09-05-2010 06:40 AM
Coches eficientes y aerodinamicos sin comprar uno nuevo This thread Refback 08-26-2010 03:02 PM
Boat Tail - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 08-17-2010 06:35 PM
S2000 Forums -> impressive s2k mpg! : S2KI This thread Refback 08-14-2010 08:08 PM
geo metro - Jalopnik This thread Refback 08-10-2010 09:52 AM
Energy News This thread Refback 07-20-2010 05:27 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 07-15-2010 06:54 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 07-11-2010 08:44 PM
Aerodynamic tail makes Geo Metro even cooler | PS2Cover.com News This thread Refback 07-09-2010 02:25 PM
????, ?????(??) : monogocoro ????? - Part 10 This thread Refback 06-23-2010 05:31 AM
cool but ugly Archives : TreeHugger This thread Refback 06-20-2010 11:13 AM
Detto | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 06-01-2010 03:00 AM
Keversite.NL • Bekijk onderwerp - Dakspoiler This thread Refback 05-31-2010 05:24 AM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 05-29-2010 05:04 PM
Autoblog Green This thread Refback 05-21-2010 01:36 PM
Bike Hugger: DL Byron: January 2010 Archives This thread Refback 05-14-2010 12:06 PM
citrina/straisniai/aerodinamika This thread Refback 05-06-2010 04:57 AM
ifeelgassy - Jalopnik This thread Refback 05-05-2010 05:58 PM
Home made boat tail auto Retrofit Geeft Geo Metro Amazing Fuel Economy Cars Transportation buildaroo.com This thread Refback 05-01-2010 06:27 AM
????, ???? : monogocoro ????? - Part 7 This thread Refback 04-25-2010 03:56 AM
17 DIY Cars Hacked for Fuel Efficiency : TreeHugger This thread Refback 04-23-2010 01:03 PM
Walden Effect: Homesteading and Simple Living Blog This thread Refback 04-19-2010 08:14 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 03-31-2010 10:09 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 03-31-2010 04:56 PM
Ricerca Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-30-2010 12:52 PM
How To Change A Tail Light In Geo Prizm - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 03-27-2010 10:31 PM
Stop Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-22-2010 05:06 PM
2009 December 25 | PS2Cover.com News This thread Refback 03-21-2010 05:17 AM
How To: Paritial Kammback This thread Refback 03-19-2010 10:00 PM
2010 January 07 | The Entertainment Blog This thread Refback 03-19-2010 04:00 PM
Fuel Economy | Autopia | Wired.com This thread Refback 03-06-2010 07:57 AM
La Cacharrería: un blog de tecnología diferente - Part 2 This thread Refback 02-18-2010 12:41 PM
S2KI - S2000 Forums -> impressive s2k mpg! This thread Refback 02-04-2010 02:28 AM
cars Archives : TreeHugger This thread Refback 01-30-2010 12:58 PM
Transportation-buildaroo.com This thread Refback 01-20-2010 04:54 AM
Kawasaki Triples WorldWide • View topic - Bike maintaining Tips .... This thread Refback 01-18-2010 01:53 PM
Anno | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 01-16-2010 12:36 PM
????, ???? : monogocoro ????? This thread Refback 01-12-2010 10:26 PM
Slashdot Submission | Aerodynamic tail on Geo Metro boosts MPG 15% This thread Refback 01-12-2010 07:13 PM
Slashdot - News for nerds, stuff that matters This thread Refback 01-12-2010 06:57 PM
Autopia - Part 5 This thread Refback 01-12-2010 05:47 PM
Cool Cars | Autopia | Wired.com This thread Refback 01-11-2010 04:28 PM
????, ?????(??) : monogocoro ????? This thread Refback 01-10-2010 01:04 AM
????? ??????????? ?????? ????? • ???????? ???? - ???????(????) This thread Refback 01-09-2010 10:03 AM
Ingeniøren Mobil This thread Refback 01-09-2010 06:27 AM
Spar 15 procent med en grim hale - Motorbloggen | Ingeniøren This thread Refback 01-08-2010 05:04 AM
Difícil de aparcar, sí; ¡pero gasta como un mechero! | La Cacharrería This thread Refback 01-07-2010 02:34 PM
monogocoro ????? - Part 4 This thread Refback 01-07-2010 10:58 AM
Motorcafè il blog dei motociclisti dalla mente aperta - Part 2 This thread Refback 01-07-2010 10:00 AM
Chuck Squatriglia | Autopia | Wired.com This thread Refback 01-06-2010 08:25 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Topic Powered by Social Strata This thread Refback 01-06-2010 07:00 PM
Design & Architecture Archives : TreeHugger This thread Refback 01-05-2010 12:58 AM
insidE of jaXonz This thread Refback 01-04-2010 11:02 PM
Buzz Punching: "Boat Tail" Increases Car's Miles Per Gallon by 15.1% This thread Refback 01-04-2010 10:47 PM
Guy Adds Boat Tail to Car, Increases MPG by 15.1% : TreeHugger This thread Refback 01-04-2010 03:28 PM
TreeHugger This thread Refback 01-04-2010 03:18 PM
Cars & Transportation Archives : TreeHugger This thread Refback 01-04-2010 02:16 PM
Items Tag RIT Make Club Idea Stream This thread Refback 01-04-2010 01:16 PM
Oszcz?dzaj paliwo z aerodynamicznym ogonem! (wideo) | Gad?etomania.pl This thread Refback 01-04-2010 12:14 PM
Teemu's planet This thread Refback 01-02-2010 10:15 AM
Bike Hugger This thread Refback 01-02-2010 08:55 AM
Daily DIY Network - Science Projects Plans Guides Blog Archive MPG boosting tail cone This thread Refback 01-02-2010 01:08 AM
Daily DIY Network - Science Projects Plans Guides This thread Refback 01-01-2010 08:22 PM
Make: Online This thread Refback 01-01-2010 08:11 PM
Autopia - Part 2 This thread Refback 01-01-2010 08:06 PM
siani_hedgehog's Friends This thread Refback 01-01-2010 06:09 PM
Make: Online : MPG boosting tail cone This thread Refback 01-01-2010 05:21 PM
Make: Online This thread Refback 01-01-2010 05:13 PM
A New Years Resolution - Bike Hugger This thread Refback 01-01-2010 12:17 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 02:42 AM
green hacks - Hack a Day This thread Refback 12-31-2009 04:02 PM
FFFFOUND! | flea-boat-tail-collage.jpg (JPEG Image, 500x363 pixels) This thread Refback 12-31-2009 10:56 AM
PWnT 2009 - (P)ost (W)hori(n)' (T)hread - Page 10598 - CarForums.net - Automotive Chat Forum This thread Refback 12-30-2009 08:08 PM
GeenStijl : Sneller, Scherper, Beter (maar eigenlijk komt hier een betere tagline) This thread Refback 12-30-2009 03:01 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage — Autoblog Green This thread Refback 12-29-2009 10:01 PM
Jalopnik - Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 12-29-2009 09:46 PM
Interesting New Products and Inventions: Boat Tail improves Mileage This thread Refback 12-29-2009 08:25 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 12-29-2009 08:09 PM
Attention, Greenies: Your Geo Metro Needs A Boattail - hypermiling - Jalopnik This thread Refback 12-29-2009 06:17 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 12-29-2009 06:16 PM
YouTube - EcoModderDOTcom's Channel This thread Refback 12-29-2009 05:19 PM
GeenStijl This thread Refback 12-29-2009 03:19 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 12:41 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:46 AM
GeenStijl : 15% zuiniger rijden met iedere auto! This thread Refback 12-29-2009 11:35 AM
GeenStijl This thread Refback 12-29-2009 11:16 AM
GeenStijl : 15% Zuinig rijden met iedere auto! This thread Refback 12-29-2009 11:16 AM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:15 AM
La Cacharrería: un blog de tecnología diferente This thread Refback 12-29-2009 11:04 AM
Aerodynamic long tail improves fuel efficiency 15 percent This thread Refback 12-29-2009 04:24 AM
Autopia This thread Refback 12-29-2009 01:37 AM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 12-28-2009 07:55 PM
DIY ‘Boat Tail’ Gives Little Car Big Fuel Economy | Autopia | Wired.com This thread Refback 12-28-2009 02:22 PM
Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Madshrimps Forum Madness This thread Refback 12-28-2009 08:16 AM
R4 DS Cards, R4 DS and Wii Modchip News And Reviews This thread Refback 12-27-2009 04:21 PM
Mike Szczys - Hack a Day This thread Refback 12-26-2009 06:51 PM
transportation hacks - Hack a Day This thread Refback 12-26-2009 08:35 AM
mpg - Hack a Day This thread Refback 12-26-2009 08:05 AM
Friends This thread Refback 12-26-2009 07:57 AM
Hack: Aerodynamic tail makes Geo Metro even cooler -> ASTALAVISTA.com - the hacking & security community This thread Refback 12-26-2009 04:36 AM
the other end of the spectrum... This thread Refback 12-25-2009 11:44 PM
YouTube - Raw video for: "Testing aerodynamic boat tail +15% MPG" This thread Refback 12-25-2009 10:51 PM
YouTube - Testing an aerodynamic boat tail - 15% better MPG - Geo Metro This thread Refback 12-25-2009 07:07 PM
You put WHAT on your car? Stupid shit we've seen people put on their cars - The Something Awful Forums This thread Refback 12-25-2009 07:03 PM
Hack a Day This thread Refback 12-25-2009 05:24 PM
Geo Metro Mpg - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 12-24-2009 07:07 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
