Old 11-04-2009, 06:50 PM   #51 (permalink)
usual
I probably got my usual pace at the same store as you did Darin!
Old 11-04-2009, 07:22 PM   #52 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
My usual pace hasn't arrived yet.... must've bought it from one of you guys.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-05-2009, 03:37 AM   #53 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Originally Posted by BamZipPow View Post
How about this train of thought...
Something like one of those collapsible cups but in a bigger format to fit the back of the vehicle. It could be made out of coroplast quite easily fer shape and low weight. Attach it to the back of the vehicle, pull it out and lock it in place when you need the aero capabilities and unlock/collapse it back down when you don't need it.
Do you really need to go to the very edge to git all of the aero effects? Can't you just kinda step it down from the edges to git some effect? Sort of a step/chop of the extension...a compromise? Just a thought...
From an old, forgotten post:
Originally Posted by Piwoslaw View Post
Another idea is that the boattail is in segments, like descibed above, only they're not inflatable, but stiff and they retract one into the other like a telescope. The first segment is a kammback, the others fit inside of it. This reminds me of a collapsible cup:
Piwoslaw's Peugeot 307sw modding thread
Old 11-05-2009, 04:02 AM   #54 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.88 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Exactly...now who's up to making one? I think it would be more of gitting the calculations correctly to git them to nest and expand without being too loose. Although...it could be augmented with some rubber sheeting...
Old 11-05-2009, 01:42 PM   #55 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
That's an idea. At work we build retractable loading spouts with cones that have to collapse similar to that without jamming. Calculations are pretty easy.
Winter daily driver, parked most days right now
Summer daily driver
The Following User Says Thank You to wagonman76 For This Useful Post:
Christ (11-05-2009)
Old 11-05-2009, 03:38 PM   #56 (permalink)
Was that a volunteer post? ^^
Old 11-13-2009, 06:53 PM   #57 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
This week I unbent the aluminum bows I picked up.
Set up a stool on the driveway, got out the duct tape and taped one of the tubes between the stool and the car, extending the existing angle of the Kammback (~15 degrees). Spent a long time staring at things.
Fired up Photoshop. Drew some lines.
Then I chose 130 cm / 52 inches as the length of the boat tail (roughly to the vertical green line. Two reasons: partly for aesthetic proportions because it's close to length of the car's existing "sections" (hood / door / rear), and 2) partly because the longest aluminum tubes will fit crosswise in the back of the car.
I think I'm going to aim for a 6 degree bottom angle, approximately what's shown there (don't do the photoshop measurement to check my work on this image - it's 5 degrees there.)
Bicycle Bob advocates for no more than a 4 degree angle. Unfortunately, that will leave the end of the tail a bit lower than I'd like for departing slope angles from the back tire.
I've since made a cardboard "transom", and four struts. Mounted on the car.
Plan is to make an aluminum + cardboard skinned prototype tail based on these angles and tuft test it.
Should have a couple of photos of construction this weekend.
Old 11-13-2009, 08:03 PM   #58 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
It takes me a long time to stare at stuff that isn't there yet, too. Looks good so far. When it is done, you can tape a camera on a lower rear corner to make a video of some tell-tales taped on underneath. If they are flapping, a nice line of vortex generators will probably save the day. Being a bit sloppy on the belly pan would get somewhat the same result. I'm sure a lot of people would be interested in that bottom side data.
Another approach to departure angle is to leave the attachments a bit loose at the bottom, so that the whole assembly can ground out without damage and slip back into position, if anybody really wants to get fussy.
Old 11-13-2009, 08:29 PM   #59 (permalink)
I probably won't bother tufting the bottom yet, because I have no belly pan on the car - it'll be messy even with a shallower angle.
Interesting idea for a possible "tail strike". Could put a little wheel under the bottom of the tip, too.
Old 11-13-2009, 08:42 PM   #60 (permalink)
Wheels are the 1st thing that come to mind, but they create point loads I try to stay away from. Race cars use skid plates on the bottom instead of bump stops, saving space, weight and complication. They can be very cheap to replace, and protect a wide area. Some helicopters land with forward motion so often, they have carbide skids.
boat tail, testing
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-geo-metro-boat-tail-prototype-15-mpg-10691.html
Posted By For Type Date
AeroProject: Impressioni da una gita fuori porta This thread Refback 01-10-2012 11:34 AM
BlogYueNMe: Aerodynamic tail makes Geo Metro even cooler This thread Refback 01-01-2012 04:20 PM
Club smart Car > The 100 MPG Challenge 2.011 This thread Refback 12-20-2011 08:20 AM
achieving an optimal shape This thread Refback 12-15-2011 12:39 PM
Elektromos Auto - Index Frum This thread Refback 11-22-2011 03:25 AM
Keversite.NL • Toon onderwerp - Dakspoiler This thread Refback 11-20-2011 02:49 PM
The ten nerdiest ways to modify your car This thread Refback 11-11-2011 12:10 PM
AeroProject: Pressione degli pneumatici This thread Refback 11-06-2011 05:20 PM
Raw video for: "Testing aerodynamic boat tail +15% MPG" - YouTube This thread Refback 11-03-2011 10:57 AM
17 DIY Cars Hacked for Fuel Efficiency : Page 6 : TreeHugger This thread Refback 11-02-2011 01:50 PM
DonsDeals: Aerodynamic tail makes Geo Metro even cooler - Hack a Day This thread Refback 11-01-2011 07:19 AM
BlogYueNMe: February 2010 This thread Refback 10-31-2011 04:28 AM
Hypermiling | Autopia | Wired.com This thread Refback 10-22-2011 08:54 AM
Energy News This thread Refback 10-17-2011 11:08 AM
MAKE | Green This thread Refback 10-10-2011 05:34 AM
"Offtopic-posts-topic" NSFW - Page94 This thread Refback 10-01-2011 05:41 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-28-2011 04:35 PM
Testing an aerodynamic boat tail - 15% better MPG - Geo Metro - YouTube This thread Refback 09-26-2011 10:21 AM
Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 09-18-2011 09:09 PM
MAKE | DIY Projects This thread Refback 09-11-2011 05:12 AM
AeroProject: Aerodinamica ruote (parte 2) This thread Refback 08-30-2011 04:57 PM
AeroProject: Flow Illustrator Moviemaker This thread Refback 08-24-2011 05:10 PM
kamm back and golfball texture on rear of car. any design info? : engineering This thread Refback 07-27-2011 02:21 PM
‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ - YouTube This thread Refback 07-20-2011 11:57 AM
Streamlined? - Page 2 This thread Refback 07-05-2011 07:40 AM
YouTube - ‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ This thread Refback 06-29-2011 04:18 AM
Bil Hjemmelaget Båt Tail Car modifikasjonssett Gir Geo Metro Amazing Fuel Economy This thread Refback 06-09-2011 04:57 PM
archives for 04/2010 This thread Refback 05-14-2011 08:55 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 04-11-2011 01:56 PM
The 100 MPG Challenge 2.011 - Club smart Car This thread Refback 04-09-2011 09:47 PM
Make: Online | MPG boosting tail cone This thread Refback 04-09-2011 03:19 PM
Pointes arrires This thread Refback 03-28-2011 06:36 PM
Motórum • Toon onderwerp - funny fototopic This thread Refback 03-17-2011 04:53 PM
Search Results firefly Hack a Day This thread Refback 03-11-2011 05:08 PM
impressive s2k mpg! - S2KI Honda S2000 Forums This thread Refback 03-01-2011 11:27 PM
AeroProject: Giusto per chiarirsi. This thread Refback 02-13-2011 07:38 PM
oldsmobile aerotech | Le Pics This thread Refback 02-10-2011 03:00 PM
Auto Home made boat tail Auto Retrofit Geeft Geo Metro Amazing Fuel Economy This thread Refback 02-01-2011 04:51 AM
Motórum • Toon onderwerp - funny fototopic This thread Refback 01-22-2011 01:25 PM
DIY automobile aerodynamic modification This thread Refback 01-14-2011 03:13 AM
Weight loss program for a Class B motorhome on an '89 E250 SD chassis - Page 3 - Ford Truck Enthusiasts Forums This thread Refback 01-09-2011 12:21 AM
Jullie mening gevraagd?? Onzin of waarheid?? - Focusclub.nl | Forum This thread Refback 12-15-2010 06:04 PM
Wind tunnel testing This thread Refback 11-24-2010 10:16 PM
Pointes arrières This thread Refback 11-09-2010 01:08 PM
Geo Metro: Geo Metro Photos, Wallpapers, Galleries, metro boat This thread Refback 11-05-2010 10:46 PM
Nopeusrajoituksia alennetaan 20-40 km/h! This thread Refback 10-03-2010 12:52 PM
Weekly Archive for January 3, 2010 : TreeHugger This thread Refback 09-17-2010 02:08 PM
Steel Aero Wheels For MoreMPG - RecycleBlog - RecycleBills This thread Refback 09-05-2010 06:40 AM
Coches eficientes y aerodinamicos sin comprar uno nuevo This thread Refback 08-26-2010 03:02 PM
Boat Tail - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 08-17-2010 06:35 PM
S2000 Forums -> impressive s2k mpg! : S2KI This thread Refback 08-14-2010 08:08 PM
geo metro - Jalopnik This thread Refback 08-10-2010 09:52 AM
Energy News This thread Refback 07-20-2010 05:27 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 07-15-2010 06:54 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 07-11-2010 08:44 PM
Aerodynamic tail makes Geo Metro even cooler | PS2Cover.com News This thread Refback 07-09-2010 02:25 PM
????, ?????(??) : monogocoro ????? - Part 10 This thread Refback 06-23-2010 05:31 AM
cool but ugly Archives : TreeHugger This thread Refback 06-20-2010 11:13 AM
Detto | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 06-01-2010 03:00 AM
Keversite.NL • Bekijk onderwerp - Dakspoiler This thread Refback 05-31-2010 05:24 AM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 05-29-2010 05:04 PM
Autoblog Green This thread Refback 05-21-2010 01:36 PM
Bike Hugger: DL Byron: January 2010 Archives This thread Refback 05-14-2010 12:06 PM
citrina/straisniai/aerodinamika This thread Refback 05-06-2010 04:57 AM
ifeelgassy - Jalopnik This thread Refback 05-05-2010 05:58 PM
Home made boat tail auto Retrofit Geeft Geo Metro Amazing Fuel Economy Cars Transportation buildaroo.com This thread Refback 05-01-2010 06:27 AM
????, ???? : monogocoro ????? - Part 7 This thread Refback 04-25-2010 03:56 AM
17 DIY Cars Hacked for Fuel Efficiency : TreeHugger This thread Refback 04-23-2010 01:03 PM
Walden Effect: Homesteading and Simple Living Blog This thread Refback 04-19-2010 08:14 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 03-31-2010 10:09 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 03-31-2010 04:56 PM
Ricerca Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-30-2010 12:52 PM
How To Change A Tail Light In Geo Prizm - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 03-27-2010 10:31 PM
Stop Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-22-2010 05:06 PM
2009 December 25 | PS2Cover.com News This thread Refback 03-21-2010 05:17 AM
How To: Paritial Kammback This thread Refback 03-19-2010 10:00 PM
2010 January 07 | The Entertainment Blog This thread Refback 03-19-2010 04:00 PM
Fuel Economy | Autopia | Wired.com This thread Refback 03-06-2010 07:57 AM
La Cacharrería: un blog de tecnología diferente - Part 2 This thread Refback 02-18-2010 12:41 PM
S2KI - S2000 Forums -> impressive s2k mpg! This thread Refback 02-04-2010 02:28 AM
cars Archives : TreeHugger This thread Refback 01-30-2010 12:58 PM
Transportation-buildaroo.com This thread Refback 01-20-2010 04:54 AM
Kawasaki Triples WorldWide • View topic - Bike maintaining Tips .... This thread Refback 01-18-2010 01:53 PM
Anno | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 01-16-2010 12:36 PM
????, ???? : monogocoro ????? This thread Refback 01-12-2010 10:26 PM
Slashdot Submission | Aerodynamic tail on Geo Metro boosts MPG 15% This thread Refback 01-12-2010 07:13 PM
Slashdot - News for nerds, stuff that matters This thread Refback 01-12-2010 06:57 PM
Autopia - Part 5 This thread Refback 01-12-2010 05:47 PM
Cool Cars | Autopia | Wired.com This thread Refback 01-11-2010 04:28 PM
????, ?????(??) : monogocoro ????? This thread Refback 01-10-2010 01:04 AM
????? ??????????? ?????? ????? • ???????? ???? - ???????(????) This thread Refback 01-09-2010 10:03 AM
Ingeniøren Mobil This thread Refback 01-09-2010 06:27 AM
Spar 15 procent med en grim hale - Motorbloggen | Ingeniøren This thread Refback 01-08-2010 05:04 AM
Difícil de aparcar, sí; ¡pero gasta como un mechero! | La Cacharrería This thread Refback 01-07-2010 02:34 PM
monogocoro ????? - Part 4 This thread Refback 01-07-2010 10:58 AM
Motorcafè il blog dei motociclisti dalla mente aperta - Part 2 This thread Refback 01-07-2010 10:00 AM
Chuck Squatriglia | Autopia | Wired.com This thread Refback 01-06-2010 08:25 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Topic Powered by Social Strata This thread Refback 01-06-2010 07:00 PM
Design & Architecture Archives : TreeHugger This thread Refback 01-05-2010 12:58 AM
insidE of jaXonz This thread Refback 01-04-2010 11:02 PM
Buzz Punching: "Boat Tail" Increases Car's Miles Per Gallon by 15.1% This thread Refback 01-04-2010 10:47 PM
Guy Adds Boat Tail to Car, Increases MPG by 15.1% : TreeHugger This thread Refback 01-04-2010 03:28 PM
TreeHugger This thread Refback 01-04-2010 03:18 PM
Cars & Transportation Archives : TreeHugger This thread Refback 01-04-2010 02:16 PM
Items Tag RIT Make Club Idea Stream This thread Refback 01-04-2010 01:16 PM
Oszcz?dzaj paliwo z aerodynamicznym ogonem! (wideo) | Gad?etomania.pl This thread Refback 01-04-2010 12:14 PM
Teemu's planet This thread Refback 01-02-2010 10:15 AM
Bike Hugger This thread Refback 01-02-2010 08:55 AM
Daily DIY Network - Science Projects Plans Guides Blog Archive MPG boosting tail cone This thread Refback 01-02-2010 01:08 AM
Daily DIY Network - Science Projects Plans Guides This thread Refback 01-01-2010 08:22 PM
Make: Online This thread Refback 01-01-2010 08:11 PM
Autopia - Part 2 This thread Refback 01-01-2010 08:06 PM
siani_hedgehog's Friends This thread Refback 01-01-2010 06:09 PM
Make: Online : MPG boosting tail cone This thread Refback 01-01-2010 05:21 PM
Make: Online This thread Refback 01-01-2010 05:13 PM
A New Years Resolution - Bike Hugger This thread Refback 01-01-2010 12:17 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 02:42 AM
green hacks - Hack a Day This thread Refback 12-31-2009 04:02 PM
FFFFOUND! | flea-boat-tail-collage.jpg (JPEG Image, 500x363 pixels) This thread Refback 12-31-2009 10:56 AM
PWnT 2009 - (P)ost (W)hori(n)' (T)hread - Page 10598 - CarForums.net - Automotive Chat Forum This thread Refback 12-30-2009 08:08 PM
GeenStijl : Sneller, Scherper, Beter (maar eigenlijk komt hier een betere tagline) This thread Refback 12-30-2009 03:01 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage — Autoblog Green This thread Refback 12-29-2009 10:01 PM
Jalopnik - Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 12-29-2009 09:46 PM
Interesting New Products and Inventions: Boat Tail improves Mileage This thread Refback 12-29-2009 08:25 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 12-29-2009 08:09 PM
Attention, Greenies: Your Geo Metro Needs A Boattail - hypermiling - Jalopnik This thread Refback 12-29-2009 06:17 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 12-29-2009 06:16 PM
YouTube - EcoModderDOTcom's Channel This thread Refback 12-29-2009 05:19 PM
GeenStijl This thread Refback 12-29-2009 03:19 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 12:41 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:46 AM
GeenStijl : 15% zuiniger rijden met iedere auto! This thread Refback 12-29-2009 11:35 AM
GeenStijl This thread Refback 12-29-2009 11:16 AM
GeenStijl : 15% Zuinig rijden met iedere auto! This thread Refback 12-29-2009 11:16 AM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:15 AM
La Cacharrería: un blog de tecnología diferente This thread Refback 12-29-2009 11:04 AM
Aerodynamic long tail improves fuel efficiency 15 percent This thread Refback 12-29-2009 04:24 AM
Autopia This thread Refback 12-29-2009 01:37 AM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 12-28-2009 07:55 PM
DIY ‘Boat Tail’ Gives Little Car Big Fuel Economy | Autopia | Wired.com This thread Refback 12-28-2009 02:22 PM
Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Madshrimps Forum Madness This thread Refback 12-28-2009 08:16 AM
R4 DS Cards, R4 DS and Wii Modchip News And Reviews This thread Refback 12-27-2009 04:21 PM
Mike Szczys - Hack a Day This thread Refback 12-26-2009 06:51 PM
transportation hacks - Hack a Day This thread Refback 12-26-2009 08:35 AM
mpg - Hack a Day This thread Refback 12-26-2009 08:05 AM
Friends This thread Refback 12-26-2009 07:57 AM
Hack: Aerodynamic tail makes Geo Metro even cooler -> ASTALAVISTA.com - the hacking & security community This thread Refback 12-26-2009 04:36 AM
the other end of the spectrum... This thread Refback 12-25-2009 11:44 PM
YouTube - Raw video for: "Testing aerodynamic boat tail +15% MPG" This thread Refback 12-25-2009 10:51 PM
YouTube - Testing an aerodynamic boat tail - 15% better MPG - Geo Metro This thread Refback 12-25-2009 07:07 PM
You put WHAT on your car? Stupid shit we've seen people put on their cars - The Something Awful Forums This thread Refback 12-25-2009 07:03 PM
Hack a Day This thread Refback 12-25-2009 05:24 PM
Geo Metro Mpg - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 12-24-2009 07:07 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
