Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph
http://ecomodder.com/imgs/flea-boat-tail-collage.jpg
Above image clockwise from top left: aluminum frame, cardboard construction; finished prototype; removed during A-B-A fuel economy testing; still frame from video of tuft-testing Overview ... This discussion thread documents the construction & testing of a temporary, proof-of-concept aerodynamic "boat tail" on a 1998 Pontiac Firefly (Geo Metro). Some facts about the prototype ...
Testing the prototype ... 1) First road test: read my impressions of the first drive with the boat tail on the car. Skip down to Nov. 21, post #100 2) Tuft testing: the tail spent a lot of time in the poor man's wind tunnel (ie. being tuft tested). This means observing the motion of yarn tufts taped to the car. The tufts reveal the direction & nature of air flow, and indicate whether the design works or not. Tuft testing results can be seen in the YouTube video, below. 3) Fuel economy testing: I used a ScanGauge to do an A-B-A test (before/after/before) that revealed a 15.1% fuel economy improvement at 90 km/h (56 mph). For testing details: A-B-A testing results posted, Dec. 5th http://www.youtube.com/watch?v=1sQFtd-bTfw http://ecomodder.com/forum/attachmen...1&d=1264546553 The original discussion started here ... These are the goals for the project:
I'm imagining 6 separate panels that will somehow snap or wingnut on to a light frame that can be easily dis/assembled. I've done lots of waffling on materials, but I think I'm going to go with aluminum for the frame and coroplast for the skin. Both for their lightness, and ease of workability. Assuming I can find black coroplast (Home Depot here only has white - $20 per 4x8 - and the sign making shop wanted an obscene amount for a 4x8 black sheet of it). Runner up idea was a fabric skin - UV resistant boat top canvas (which I can get in black). But thinking about hurricane force wind that will rarely be coming from directly ahead of the vehicle made me think coroplast is probably better. One task I've actually completed so far: I added 6 feet to the wiring harness of each of my tail lights so I can move them between the back of the boat tail and their stock position as needed. Twice now I've pulled the car into the garage and fussed around with various building materails, from cardboard to styrofoam to wood to alumimum. Nothing built yet. I've spent a silly amount of time standing around looking at the back of the car. I think I need to just start building! http://ecomodder.com/imgs/boat-tail-poll.gif Also see my second boat tail project: http://ecomodder.com/forum/showthrea...uft-25223.html http://ecomodder.com/imgs/tail-wrapped-collage.jpg http://ecomodder.com/imgs/collage-summary.jpg . |
I vote for boat canvas. If fabric is good enough for biplanes why not a car? You could use brass grommets to hook onto pins. Also works for lacing, cinch up points, or tie-down points. It keeps it flexible to fold up when not in use.
Interesting project. I'm following closely. I need to do something for my aero some day. |
Have you considered the Fiber Reinforced Plastic sheets at Home Depot, (the bubble texture shower wall stuff) It can take high heat, can be formed and is quite strong. Easy to cut and very thin. $27 for a 4x8 sheet.
Oh! This is gonna be interesting to watch! You might wanna check Rona too. Here 4x8 coroplast sheets are 16 and change at Rona.
If built intelligently, a piece of the removed canvas could also double as a windshield sun-shield, as well as a couple pieces for the front windows. That would take some real engineering time, though. |
You may not need aluminum framing except as stiffeners. A bent coroplast corner is quite stiff. Modern plywood boats are often frameless, and better for it.
Cool, I'd like to see what you come up with.
I used metal skin on mine because it was free, and because welding it to the frame made it rigid with not as much work. Didn't get a pic of mine with the extended tailpiece before I took it off, but I've gotten my downstate mileage back after removing it. |
Metro,
I would go for the Styrofoam!! The stuff is easy to cut/glue/form/sand/paint and so on. Go for panels that are 1.5 inch thick. I think cost is around $15 per sheet. After the shape is complete, add one layer of 6 ounce fiberglass cloth and epoxy to the foam, using the wet layup method. Make sure to add about 3 layers on all your hard-mount points, and embed wood blocks in the foam in these areas. For a boat tail, you will probably go through about one gallon of resin, and if you use West Systems, it will set you back about $100/gallon. Cloth, about $40 or so. The cool thing about foam is, after your done, it will look just like an automotive finish. Of course don't ask about how much time the sanding/glazing/priming and painting will take. But this is something you can do anytime you wish. Just take them off the car and start sanding. And you can still drive the car in between. Just my $.02, Jim. |
I've been pondering this as well. Not a priority at the moment with two other projects on the burners, but maybe something worth it for either of us to cobble something together as a mock-up for the AMEC run. Don't forget the use of strong magnets and/or suction cups! I really feel like neodymium magnets or strong suction cups could be at least two of the supports for a removable boat tail.
Christ: the chicken wire idea to support fabric is a good one. But I decided against fabric because chicken wire or the supporting "tent pole" framework to get the polygonal "resolution" I want will be as bulky for storage or as much work as doing coroplast surfaces, I think. Anyway, here\'s all I have to show so far. Should have enough length here to go almost to a point if I want to take it that far. (But I don\'t plan a point - it\'ll have a flat rear surface to mount the lights/licence plate. http://forkenswift.com/album/7-tail-...s-ext-rear.jpg http://forkenswift.com/album/7-tail-...s-ext-side.jpg |
