Old 08-02-2008, 12:29 AM   #11 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Originally Posted by massimofinance View Post
3) Replaced my air filter and spark plugs
4) Remove all excess weight from the car
The 4.7 probably doesn't care about those two. I know my 4.0 doesn't
Old 08-02-2008, 12:36 AM   #12 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
After two weeks, I am still clocking 15.1, so it is clear to me none of the above worked, unless (a) I need more time for the onboard diagnostic tool to record any saves, or (b) these "fixes" do nothing for V8 S.U.V.s.
Any one have an idea?
Most likely you are looking at your number off of an computer on the car. You should calculate your MPG manually (miles/gallons) at the fill-up. Um, if you are doing it manually then never mind my post.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 08-02-2008, 03:23 AM   #13 (permalink)
TrikeKid's Avatar
The ClownCar - '91 Metro Base
Send a message via AIM to TrikeKid Send a message via Yahoo to TrikeKid
Yeah, be very wary of those built in gauges, my mom's Chrysler will read as low as 18 running down the freeway at the speed limit (EPA rated at 24 highway, of course, my mom wastes gas like it's her job too...)
Old 08-02-2008, 12:53 PM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
The only instruments that count are the odometer (check it with a GPS if you can) and the fuel pump.
The electronic thingies are OK for detecting changes but in general are electronic politicians.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 08-02-2008, 01:30 PM   #15 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
A ScanGauge or MPGuino used in controlled circumstances - mutiple, speed-controlled, bi-directional A-B-A runs, on an empty road - is the best method of measuring a mod's in/effectiveness.
aero, fairing, faring, thule
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
The extreme AreoCRX-HF project ebacherville Aerodynamics 278 04-17-2010 12:26 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 12:33 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
