Old 08-31-2009, 10:06 AM   #101 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Found some info on the CRX HF vs. Insight CV's
CRX HF
OAL (COMP.LENGTH): 35 11/16 +/-0.125
INNER SPLINE COUNT: 25
OUTER SPLINE COUNT: 23
OUTER SEAL DIAMETER: 1.931 +/-0.001
OUTER THREAD PITCH: M22X1.5
Insight
OAL (COMP.LENGTH): 34 5/8 +/-0.125
OUTER SEAL DIAMETER: 1.930 +/-0.001
I'd bet the HF hubs would work just fine, however this is just a comparison of the right side CV's. The CRX uses the same one on the right and left, I couldn't get any info on the left side CV for the Insight???
Old 08-31-2009, 10:57 AM   #102 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
CRX HF
Insight
There is only one D-series transaxle that uses equal length axles, and the HF isn't it.
The ZC transaxle comes with a separate half shaft that bolts to the block, which then requires the use of 2 short axles, instead of a short and a long. It's designed to control torque steer under hard acceleration. JDM only piece, though. The half shaft, or intermediate shaft, can be used with other D-series transaxles, but you'd have to tap the holes in the block that it bolts to.
It's also something you could look into for the Insight's transaxle, as well, which may allow you to use the shorter HF axle on both sides. (Then again, I think you wanted to use the Insight's twigs, right?)
Old 08-31-2009, 12:06 PM   #103 (permalink)
Team ZX2
[QUOTE=Christ;124900]There is only one D-series transaxle that uses equal length axles, and the HF isn't it.
QUOTE]
I wouldn't know, the info I found shows the same part number for right and left sides for the HF...I'll look again to be sure.
Old 08-31-2009, 12:12 PM   #104 (permalink)
Team ZX2
Oops, I read it incorectly. The right side is 23 11/16" OAL.
Old 08-31-2009, 01:15 PM   #105 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Well, that's encouraging news...Back to scamming around for a local set of HF knuckles.
Old 08-31-2009, 06:23 PM   #106 (permalink)
Steve - '92 Festiva
SVO- I don't think the CV joints can stand being stretched an inch on both sides, so you might want to make sure if the Insight's other shaft is 1" longer or close to it, so you can take up the slack of the long shaft by shifting the engine one way 1/2".
Old 08-31-2009, 06:43 PM   #107 (permalink)
Dartmouth 2010
SVOboy's Avatar
I agree. Somewhere I looked I found the total length to be something like 1/8th inch off from the CRX. I'll lay they axles out and measure in a bit. Working one figuring out how to jiggle the engine into place right now, but I keep doing stupid things...
Old 08-31-2009, 06:45 PM   #108 (permalink)
Steve - '92 Festiva
Measure the compressed length, and compare it to the OAL. The result should be about 1/2 way in between, if you can set it up that way. You should never mount them any longer than the OAL, if possible.
Old 08-31-2009, 06:50 PM   #109 (permalink)
Dartmouth 2010
SVOboy's Avatar
Isn't the OAL the same as the compressed length?
Old 08-31-2009, 06:52 PM   #110 (permalink)
Steve - '92 Festiva
It shouldn't be, because OAL is "Overall length" and they're not installed compressed. They're installed about 1/2 way between compressed and extended.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
