Old 12-23-2009, 06:39 PM   #481 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
My welder is the same as yours, just a different brand. You plan on welding some 1" plate? Your welder should be good up to 1/4"... any thicker and you just do a multipass.
So what is this next thing?
Old 12-24-2009, 01:20 PM   #482 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
So, I'm thinking about mounting the cable to hydro adapter, and this seems to be a good place, but I'm a little wary. Unfortunately there are no open bolt holes I can use, so I was thinking of drilling and tapping two holes and just bolting it right there. About halfway through the drilling I started to doubt my plan however.
Anyone have better ideas?
Old 12-24-2009, 02:37 PM   #483 (permalink)
EcoModder!
ratatouli - '01 insight
Timeline back past the 1st yet? I'm pretty sure I'm back that far. Have work piling up and the holidays/ ordering/ waiting on parts.
I'd like to see what the progress looks like at this point. Pictures? Sure many others would like to see as well. Happy Holidays!
Old 12-24-2009, 02:40 PM   #484 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I've been bugging him for more pictures since he started the project!
Old 12-24-2009, 02:41 PM   #485 (permalink)
EcoModder!
Yeah, seems like he has a camera too from what I can tell. lol.
Old 12-24-2009, 02:42 PM   #486 (permalink)
Dartmouth 2010
SVOboy's Avatar
You'll get some pictures tonight. It always seems like not enough is changing to me so I hesitate to take them
Anyway, gonna work on a battery box now.
Old 12-24-2009, 02:43 PM   #487 (permalink)
CM400E - '81 CM400E
I usually just take tons and only use about 1/4 of what I take, that way I have it covered. Plus, you normally can't go back and get pictures of something half done.
Old 12-24-2009, 02:49 PM   #488 (permalink)
EcoModder!
Me too, tons of pictures, it ends up being like a movie when you look through them in sequence.
Old 12-24-2009, 03:27 PM   #489 (permalink)
Dartmouth 2010
SVOboy's Avatar
It's just troublesome having your flow interrupted by pictures sometimes, so I forget about them completely. But, I'm making a better effort.
Old 12-24-2009, 05:17 PM   #490 (permalink)
Dartmouth 2010
SVOboy's Avatar
Okay, so I've got some pictures and some updates and some more whining. I'll just go in the order that I dig up the photos.
Of all the things I've worked on recently, the only thing I can say I really "finished" would be the exhaust. Basically, I realized I couldn't making the crazy S-bend so I cut off the annoying bit and just ran a pipe back. The weld the further back isn't very good, I'm just hoping there's not leaking. Also, I welded in an O2 bung to relocated the second 02 about 6 inches down from the original, which was in the way of the crossmember.
This is just a boring shot of the swapped knuckle, which isn't done finally because I need to lengthen the axle on this side. So, in a few days I'll have to chop that axle, install both sides, load the suspension, see how much gap there is (probably less than an inch), then weld a sleeve on. Not the solution I would've liked, but o well.
The driver's side mount is on upside down, which is causing the engine to sag a good bit. I'll have to pop this out and have someone press it out and flip it for me. Shouldn't be too hard to fix this one whenever I get around to it.
This is the clutch adapter, showing basically how it works. Unfortunately I didn't manage to get this mounted up right today. Humbug.
Thoughts on these flares? The damn thing was giving me trouble, but they look good enough. I cut these off anyway since I kept changing my mind about the hardline, so it's not the finished product. Just curious.
I'm either going to mount the battery or the clutch here. Probably the battery if I can find a better spot for the clutch. You can see the two fresh holes I drilled during my plan to mount the clutch which failed.
This is the other spot for a possible battery mount. Don't like it though.
I would just shell out for a sealed battery and stick it in the back but I'm broke and can't afford it, so that's too bad. I'll figure that out one way or another. Right now I think it'd be prudent to make a checklist of things so I don't forget, so I'll probably do that eventually or else I might forget to tighten something down or put oil in the transmission or something bad like that.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
