Old 01-11-2013, 08:17 AM   #21 (permalink)
328 Shooting Brake - '97 328i Touring SE
Team m8
90 day: 23.78 mpg (US)
Derv of Doom - '96 Golf 1.9TD Umwelt
Team m8
90 day: 46.6 mpg (US)
Adding a post to mark this- something I'd be interested in! Looks good!
One question- is it easy to insure a conversion like this?
thanks
My BMW 328i Mods thread
http://ecomodder.com/forum/showthrea...ead-21561.html
My VW Golf 1.9 TD (AAZ) mods thread
http://ecomodder.com/forum/showthrea...1-a-24680.html
UK MPG for the 328i Shooting Brake (on LPG)
US MPG for the 328i Shooting Brake
UK MPG for my Golf TD
US MPG for my Golf TD
Old 01-11-2013, 09:35 AM   #22 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
Last 3: 80.49 mpg (US)
Insurance on an EV conversion is a common question.
The simple answer is YES you can get insurance, and look before you start the project.
I had no problem getting insurance on my electric car conversion through Progressive. I was also using a full-service insurance agent, and explained to her exactly what I wanted to do before starting the project.
Other things to check on before you start your project include, license, title, registration, pollution control tests, and local, state, and federal laws.
Rules and regulations vary considerably from one area, county, state, country, to another, so look to see what applies to you.
By planning ahead, you can have a project you are proud of AND be able to legally drive it!
Here's a few more comments on it at my blog.
http://300mpg.org/projects/electro-metro/insurance/
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-11-2013, 01:02 PM   #23 (permalink)
Daox's Paseo - '97 Paseo
90 day: 36.6 mpg (US)
CM400E - '81 CM400E
Daox's Grey Prius - '04 Prius
90 day: 48.5 mpg (US)
Originally Posted by jackbauer View Post
Though not quite related to the build here is a high discharge test of a 180Ah CALB grey cell
It looks like you're going to change your signature now since you have batteries capable of delivering 2000 amps!
Old 01-11-2013, 02:58 PM   #24 (permalink)
jackbauer's Avatar
Insurance can be an issue especially in Europe. I was lucky enough to have a broker friend who did a lot of leg work to get it sorted. The thing is its all precedent. Now that the company have covered me in one ev another is no problem.
Last weekend I jacked up the front of the car for a look see as I had a sneaky suspicion that I may have a clearance issue between the motor frame and steering rack. Sure enough unlike on the E36 where the rack is mounted on the side of the crossmember on the 5 series its on top! Bit of headscratching later I think I have a solution. I picked up a driveshaft for the automatic version on ebay which is shorter than the manual. This will let me more the gearbox / motor assembly rearward by about 3 inches allowing the motor to clear the steering rack. I'll need to shorten the shifter linkages but that's only a bit of welding. Plenty of clearance in the tunnel. I doubt even a 9" motor would fit without this modification and I want the power of the 13"
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.e39ev.com
Old 01-11-2013, 03:02 PM   #25 (permalink)
jackbauer's Avatar
This is what I'm looking at for the aircon :
Toyota Prius 2nd Gen XW20 (2003-2009) 1.5L Hybrid Air Con Pump ACP638 | eBay
Couple that with a 2hp vfd and i'm up and running with aircon for less than 300 euros. Just need to graft the prius pipes to the bmw but again that's just a bit of silver brazing.
www.evbmw.com
www.e39ev.com
Old 02-03-2013, 04:45 AM   #26 (permalink)
jackbauer's Avatar
Here's the latest on the yacht!:
I've attached the arduino sketch in txt format. I'd be grateful if someone could have a look and tell me if it outputs 58 pulses then misses two as i don't have a storage scope at the minute!
File Type: txt crank_v2.txt (779 Bytes, 5 views)
www.evbmw.com
www.e39ev.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
a8ksh4 (02-05-2013), mechman600 (02-04-2013)
Old 02-03-2013, 11:56 AM   #27 (permalink)
Megasquirt community is a good source of info on topic, take a look for example here: Megasquirt MSEXTRA / MS3EFI • ms1e 60-2 wheel can't get wasted spark to run (View topic)
edit: stupid me, misunderstood your question
Old 02-04-2013, 10:03 PM   #28 (permalink)
This is awesome!!!!
Old 02-04-2013, 11:23 PM   #29 (permalink)
mechman600's Avatar
The eBooger - '92 MX-3
90 day: 67.67 mpg (US)
The Matrix - '07 Matrix XR-B
90 day: 27.52 mpg (US)
For a functional tachometer, why not remove the tone wheel from the ICE's crankshaft, install it on the DC motor shaft and mount the crankshaft speed sensor in the appropriate spot? No need to fool the ECU - simply give it a real speed signal.
I would also use some other useful ICE sensors, like mounting the coolant temp sensor somewhere on the motor or controller so you have a functional temp gauge.
Old 02-05-2013, 02:38 PM   #30 (permalink)
jackbauer's Avatar
Few reasons I can't do that. First is that its buried in the engine , second i dont have an aux shaft on the motor and third if the signal drops below 250rpm the mil light illuminates. While that presents no practical problems driving the car it would result in a failure during the mandatory vehicle testing which I will have to do. So the arduino will produce a false 300rpm signal to the tach when the motor drops below 300rpm.
www.evbmw.com
www.e39ev.com
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
