Old 08-15-2008, 12:41 PM   #201 (permalink)
Subaru GL - '86 GL Hatchback 4X4
90 day: 25.36 mpg (US)
looks very nice.
Old 08-16-2008, 02:58 PM   #202 (permalink)
Exxon/Mobil moles have purchased the house across the street! Now that you've resined to the occasion you'll have to watch your acetone! Looks great!!!!!!!!
Old 08-17-2008, 09:08 AM   #203 (permalink)
homeworkhome53's Avatar
Workride - '07 Aveo5 SVE
90 day: 51.74 mpg (US)
Has anyone tried to heat form lexan. It looks like the perfect material for a project like this,see through. Just a question. I know it very tough and they get nice radius in many applications. I think you have done great job Metro. I really dislike paint, never get it right. There is a product called E-poxy paint from marine stores that you apply with a brush which is self-leveling and looks sprayed on. I did a very good job on 22 foot aluminum boat a couple years ago and it still looks good. Not cheap $22 a quart but the price is worth the aggrivation
homeworkhome53
Old 08-17-2008, 11:31 AM   #204 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Phil: I had to read that a few times before I got the joke.
homeworkhome - I think that's the answer! I've used that paint before as well, and my brush job also turned out very well. Much better than the spray job. Also, the epoxy will be a more durable finish than spray "enamel". Thanks!
Old 08-17-2008, 09:35 PM   #205 (permalink)
Did a bit more work on the kammback this evening (still not 100% finished): this time I was painting the underside flat black. With a brush. Looks great! #&$^ spray cans....
I also weighed it: 10.5 lbs.
The car is mostly cleaned up. Now I need to drill a couple more holes to mount this thing well.
Old 08-18-2008, 11:27 PM   #206 (permalink)
Carbon based lifeform
dentprone's Avatar
Green Rocket - '01 Forester
Clifford - '76 M880
RuhRoh - '94 Metro
First post, I have been lurking for a while primarily watching the progress of the kammback. Absolutely incredible work, I personally think it looks great. About the paint, I have used that spray on bedliner in the past for less than perfect surfaces. It comes in a tall spray can that costs about $7. I know it sounds like it would make for a rough surface, but it's really not too bad. And because it is not very reflective, it hides very well.
-Chuck
-Chuck
Watching paint dry?
Check out my blog.......
http://www.mobiblog2500.blogspot.com
Old 08-19-2008, 12:32 AM   #207 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
-Chuck
Welcome to EM!! A good thread for your starter post.
I like the idea of spray on bedliner. I have worked at Rhino Linings for 7 years now. But got me wondering how would that black textured spray paint look, I see it at Lowes all the time and have been wanting to try it on something, my skirts,,,,Hmmm
Old 08-19-2008, 12:57 AM   #208 (permalink)
dentprone's Avatar
Clifford - '76 M880
RuhRoh - '94 Metro
Spray on liner
Thank you for the kind words. Yeah, this stuff comes out MUCH smoother than what you spray. You can even vary the pattern by holding the can farther/closer to the surface. Not nearly as tough as Rhino Lining, but once it cooks in the sun, it is fairly impressive.
-Chuck
Watching paint dry?
Old 08-19-2008, 09:31 AM   #209 (permalink)
Daily Driver - '01 Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
spray on bedliner? ask and ye shall receive
there are 2 different kinds
"undercoat" is half the price, and half the texture
this is behind the interior panels of my old truck
i didn't really do much prep, i just wanted a little extra sound deadening. notice the smooth texture
now, heres the "truck bed coating"
its coarser to the touch, and the color looks more "dull" than the undercoat (which looks more "glossy")
you can also use it to give a little more "pep" to your interior panels (mine were very scuffed/scratched in this area)
prep work is key! i didn't do much, this was just an experiment to see if i could save a few bucks by not buying the roll-on. for my use (offroad/fishing/camping truck,) i would have been better off using the roll-on, its a lot thicker and more durable.
btw, if you are looking for a way to "clean up" the bolts on top, use carriage bolts (the ones with the smooth dome top). they look like they need a square hole to seat properly, but thats only if you are using a lot of torque. with a round hole, you can just hold the top by hand and tighten the nut underneath.
i like this idea, makes me wonder if it would make a difference on my suv. i know theres a major low pressure area back there, its enough to suck dirt past the rear hatch seals.
My Intro
The Following User Says Thank You to Tony Raine For This Useful Post:
cfg83 (10-12-2010)
Old 08-19-2008, 01:48 PM   #210 (permalink)
Ah, the wonder of grainy photography!
Thanks for the bedliner spray idea. The air at the rear of the car certainly wouldn't care whether the paint surface is perfectly smooth or pebbly.
I'm leaning toward the epoxy paint route, but I can see the attraction of something that "hides well" so I don't have to spend a bunch more time doing smoothing bodywork.
But I'm still not going to refinish the thing until next year.
And welcome to the forum!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-making-permanent-metro-kammback-extension-3518.html
Posted By For Type Date
How To Get 99.7 Mpg From A Geo Metro This thread Refback Yesterday 02:20 PM
Ecomodder News, Videos, Reviews and Gossip - Jalopnik This thread Refback 01-18-2012 06:28 AM
100 mpg News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-01-2011 11:59 AM
Hypermiling stories - Jalopnik This thread Refback 10-09-2011 05:24 PM
Tuft testing a "Kammback" mockup - Geo Metro aerodynamics - YouTube This thread Refback 08-24-2011 01:35 AM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 08:37 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 02:02 PM
New car tech that saves on fuel - Sympatico.ca Autos This thread Refback 01-21-2011 01:18 AM
Wow A Best ever MPG! - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 01-03-2011 02:30 PM
Kammback Creator to be Inducted into Automotive Hall of Fame | CarZilla This thread Refback 12-21-2010 03:32 AM
SerayaMotor.com • View topic - IIMS 2010-Ford Fiesta Review & TD This thread Refback 08-01-2010 11:24 PM
Four cylinders are for chumps - 100 miles-per-gallon in a Geo Metro — Autoblog Green This thread Refback 06-15-2010 01:18 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 06-15-2010 01:03 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 02:28 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:02 PM
Donderdagavond caption contest: doe het met hout » Autoblog.nl This thread Refback 04-08-2010 04:12 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 11-27-2009 02:00 AM
Kamm Back - Overview : Kosmix This thread Refback 10-24-2009 10:39 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
