Old 09-26-2008, 01:50 PM   #221 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Phil: So far the MIB have been leaving me alone. Maybe they feel some affinity to me for driving a black car.
Schultz: good idea. I think I still have the mirror & mount from the red ForkenSwift car.
Weather was pretty ideal this AM (light winds) so I headed out to my test route for an A-B-A comparison.
Unfortunately, the replacement cruise control crapped out before I finished the B runs. I kid you not. The first unit worked fine for a year (?) before becoming unresponsive; the second one worked for less than an hour. Same symptoms.
So here's the incomplete data @ 55 mph (88.5 km/h), where A = Kammback on; B = Kammback off. Units = mpg (US)
Code:
Run ... East ... West ... Average
A1 .... 60.9 ... 57.7 ... 59.3
A2 .... 60.4 ... 59.4 ... 59.9
A3 .... 61.2 ... 56.4 ... 58.8
Average of A runs = 59.3
B1 .... 57.2 ... 56.5 ... 56.9
B2 .... 57.6 ... 54.9 ... 56.3
... cruise control stops working ...
Average of B runs = 56.6
No conclusions should really be drawn from this, because it's incomplete. But looking @ just the available figures, the Kammback runs were 4.9% better than the non-Kammback runs.
I really ought to get something to measure sound as well, because there seemed to be a noticeable difference in wind noise between the A & B runs.
Old 09-26-2008, 02:13 PM   #222 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I'm starting to consider this a plausible addition to my protege5 hatchback... I like the plexi one next door.
Old 09-26-2008, 03:48 PM   #223 (permalink)
incomplete
Darin,the incomplete data set looks very promising.I would like to think that after the cruise-control issues(bummer!) are resolved,that the mpg trend will resurface.The Metro looks really good.If bondo lived down the street,he could pull a mold off the back of the car and reproductions could be layed-up for those with Metros that don't have the facility to do it themselves.If I didn't know what was going on,and just saw your car in passing,I'd presume it was an OEM or SEMA aftermarket part.Seamless!
Old 09-26-2008, 10:47 PM   #224 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Noise can be a surrogate parameter for turbulent drag. Turbulence is noisy.
Much lower noise was how I knew I wason the right track with my bed cover. That funky-looking thing I have is very quiet. An open bed roars at you.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 10-06-2008, 03:07 PM   #225 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
ooo - I totally missed this thread
Metro, some reading for you on moldless sandwich construction by Burt Rutan (you know, the spaceshipOne guy )
http://www.actechbooks.com/products/act431/
Unfortunately, I haven't found a digital copy - check your library.
As for your earlier comment on the black paint showing ripples and such... You're totally right - it's just more time (and some fairing putty) to get it smooth. Using proper sanding implements (sandpaper glued to a long straight 2x4 and implements that match the curvature of your rounds) helps a whole lot - necessary, even.
Because I'm thinking about it (recently saw this in application) - a cheap way to add stiffeners to compound curves is to use foam tape or adhesive weather stripping - then glass over that. The foam conforms nicely and is available in a bunch of thicknesses (bonus for lightweight and cheap)
It looks great though - congratulations Of course, the creator is also the most critical.
And if you didn't think about this already - you now have a working prototype to make a mold and tool from I'm not precisely sure how big the market would be though
Challenge me, or correct me, but don't ask me to die quietly.
Old 10-10-2008, 04:48 PM   #226 (permalink)
Pipina - '93 Civic CX
90 day: 46.88 mpg (US)
could someone do the ideal teardrop thing with a 92-95 civic hatch thats stock (not the aerocivic)
Old 12-01-2009, 12:20 AM   #227 (permalink)
White Wocket - '98 Metro LSI
Last 3: 31.74 mpg (US)
If this turns out well, I was thinking I could make a mold and produce copies for people, but shipping would be a problem! Not really practical.
I'd buy one for sure!! Let us know if you decide to make them for people.
Old 03-27-2010, 03:38 PM   #228 (permalink)
Mirage - '93 Mirage ES
90 day: 41.92 mpg (US)
Anyone have the tear drop image file? I want to do my car.
Old 03-28-2010, 02:36 PM   #229 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
This is awesome, I wish I could make mods look that pro on my car.
Old 05-08-2010, 05:58 AM   #230 (permalink)
The Toecutter's Avatar
I want to do this to my 300 SDL. It would be a lot less of a hassle given that there is no hatch; it's just a matter of assuring that the trunk can open all the way. As much as I would hate to drill holes into that car, it already has rust around the trunk area so I doubt it would ever make financial sense to restore the car anyway. The improvement you have gotten based on your results so far, while not scientific due to the incomplete testing, is still obvious. A 3% or higher gain can certainly be expected, but I think the completed results will be more closer to 5%.
Thanks for putting together a very clean addition for us all to oggle at and envy! It's pretty.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-making-permanent-metro-kammback-extension-3518.html
Posted By For Type Date
Ecomodder News, Videos, Reviews and Gossip - Jalopnik This thread Refback 01-18-2012 06:28 AM
100 mpg News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-01-2011 11:59 AM
Hypermiling stories - Jalopnik This thread Refback 10-09-2011 05:24 PM
Tuft testing a "Kammback" mockup - Geo Metro aerodynamics - YouTube This thread Refback 08-24-2011 01:35 AM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 08:37 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 02:02 PM
New car tech that saves on fuel - Sympatico.ca Autos This thread Refback 01-21-2011 01:18 AM
Wow A Best ever MPG! - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 01-03-2011 02:30 PM
Kammback Creator to be Inducted into Automotive Hall of Fame | CarZilla This thread Refback 12-21-2010 03:32 AM
SerayaMotor.com • View topic - IIMS 2010-Ford Fiesta Review & TD This thread Refback 08-01-2010 11:24 PM
Four cylinders are for chumps - 100 miles-per-gallon in a Geo Metro — Autoblog Green This thread Refback 06-15-2010 01:18 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 06-15-2010 01:03 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 02:28 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:02 PM
Donderdagavond caption contest: doe het met hout » Autoblog.nl This thread Refback 04-08-2010 04:12 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 11-27-2009 02:00 AM
Kamm Back - Overview : Kosmix This thread Refback 10-24-2009 10:39 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
