Old 09-09-2013, 12:26 AM   #21 (permalink)
I'm considering a kammback but not quite sure how I feel about how it would look.
It would scream 'look at me' to little aero effect. I would focus on the bottom. You've got the air dam, is it higher or lower than the average height underneath? If it's lower you might notch the center bottom to let a little more air underneath. Basjoos style double sidewalls to channel the air front to back and then a diffuser in back.
You could work on internal airflow ahead of the firewall. Spats and bellypans.
Watch what aerohead is planning for his CRX, that should be interesting.
