Submit Tools LinkBack (2) Thread Tools
Old 11-04-2009, 06:50 PM   #51 (permalink)
usual
I probably got my usual pace at the same store as you did Darin!
Old 11-04-2009, 07:22 PM   #52 (permalink)
Moderate your Moderation.
Cara - '00 Caravan Base
90 day: 28.45 mpg (US)
My usual pace hasn't arrived yet.... must've bought it from one of you guys.
Originally Posted by tasdrouille View Post
Because bean counters always win, that's why.
Old 11-05-2009, 03:37 AM   #53 (permalink)
Take me to your Earthling
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 50.47 mpg (US)
Originally Posted by BamZipPow View Post
How about this train of thought...
Something like one of those collapsible cups but in a bigger format to fit the back of the vehicle. It could be made out of coroplast quite easily fer shape and low weight. Attach it to the back of the vehicle, pull it out and lock it in place when you need the aero capabilities and unlock/collapse it back down when you don't need it.
Do you really need to go to the very edge to git all of the aero effects? Can't you just kinda step it down from the edges to git some effect? Sort of a step/chop of the extension...a compromise? Just a thought...
From an old, forgotten post:
Originally Posted by Piwoslaw View Post
Another idea is that the boattail is in segments, like descibed above, only they're not inflatable, but stiff and they retract one into the other like a telescope. The first segment is a kammback, the others fit inside of it. This reminds me of a collapsible cup:
Piwoslaw's Peugeot 307sw modding thread
"You can't call yourself human if you think only of yourself."
Don't laugh at things you don't understand.
Originally Posted by blueflame View Post
The more you drive, the less you think. Thats why I always take the bus.
Old 11-05-2009, 04:02 AM   #54 (permalink)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Exactly...now who's up to making one? I think it would be more of gitting the calculations correctly to git them to nest and expand without being too loose. Although...it could be augmented with some rubber sheeting...
Old 11-05-2009, 01:42 PM   #55 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 35.91 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 29.05 mpg (US)
That's an idea. At work we build retractable loading spouts with cones that have to collapse similar to that without jamming. Calculations are pretty easy.
Winter daily driver, parked for the season, except used occassionally for junkyarding
Summer daily driver
The Following User Says Thank You to wagonman76 For This Useful Post:
Christ (11-05-2009)
Old 11-05-2009, 03:38 PM   #56 (permalink)
Was that a volunteer post? ^^
Old 11-13-2009, 06:53 PM   #57 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
This week I unbent the aluminum bows I picked up.
Set up a stool on the driveway, got out the duct tape and taped one of the tubes between the stool and the car, extending the existing angle of the Kammback (~15 degrees). Spent a long time staring at things.
Fired up Photoshop. Drew some lines.
Then I chose 130 cm / 52 inches as the length of the boat tail (roughly to the vertical green line. Two reasons: partly for aesthetic proportions because it's close to length of the car's existing "sections" (hood / door / rear), and 2) partly because the longest aluminum tubes will fit crosswise in the back of the car.
I think I'm going to aim for a 6 degree bottom angle, approximately what's shown there (don't do the photoshop measurement to check my work on this image - it's 5 degrees there.)
Bicycle Bob advocates for no more than a 4 degree angle. Unfortunately, that will leave the end of the tail a bit lower than I'd like for departing slope angles from the back tire.
I've since made a cardboard "transom", and four struts. Mounted on the car.
Plan is to make an aluminum + cardboard skinned prototype tail based on these angles and tuft test it.
Should have a couple of photos of construction this weekend.
Old 11-13-2009, 08:03 PM   #58 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
It takes me a long time to stare at stuff that isn't there yet, too. Looks good so far. When it is done, you can tape a camera on a lower rear corner to make a video of some tell-tales taped on underneath. If they are flapping, a nice line of vortex generators will probably save the day. Being a bit sloppy on the belly pan would get somewhat the same result. I'm sure a lot of people would be interested in that bottom side data.
Another approach to departure angle is to leave the attachments a bit loose at the bottom, so that the whole assembly can ground out without damage and slip back into position, if anybody really wants to get fussy.
Old 11-13-2009, 08:29 PM   #59 (permalink)
I probably won't bother tufting the bottom yet, because I have no belly pan on the car - it'll be messy even with a shallower angle.
Interesting idea for a possible "tail strike". Could put a little wheel under the bottom of the tip, too.
Old 11-13-2009, 08:42 PM   #60 (permalink)
Wheels are the 1st thing that come to mind, but they create point loads I try to stay away from. Race cars use skid plates on the bottom instead of bump stops, saving space, weight and complication. They can be very cheap to replace, and protect a wide area. Some helicopters land with forward motion so often, they have carbide skids.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-removable-geo-metro-boat-tail-10691.html
Posted By For Type Date
Guests without attachment permissions: options other than broken image icon? This thread Refback Today 09:45 AM
Project: removable Geo Metro boat tail - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 10-21-2009 03:17 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 130 10-29-2009 11:11 PM
Removable boat tail snydertalon Aerodynamics 7 09-29-2009 02:53 AM
Restoring a 1989 Geo Metro IheartGeos Introductions 10 07-03-2009 04:06 AM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-31-2008 12:23 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
