06-08-2012, 02:05 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Terminal velocity (THIS IS A TROLL THREAD)
If a tear drop is such a great aerodynamic shape:
Why does the rain drop have a terminal velocity of only 25f/s, compared to the outstretched human, with a tV of ~250f/s?!
Checkmate, aerodynamicists!
06-08-2012, 02:51 PM
Rat Racer
Density?
How about a thinner human will have a higher percentage of his weight made up of dense things like bone and muscle. Less surface area than water for a given amount of mass. Tubby McLardbutt will have a density more closely approaching that of water and will have a lot more surface area to act as a brake on his form, bringing him closer to the speed of a raindrop?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
06-08-2012, 03:40 PM
eco-scrapper
1. Raindrops aren't "teardrop shaped," they're roughly spherical.
2. Raindrops fall slowly due to the "square/cube rule": as you scale up a design (like a raindrop) the force of gravity goes up by the cube, but drag is roughly proportionate to frontal area, and goes up by the square (ignoring Reynold's number.) A teardrop probably falls faster than a teardrop-sized person would.
06-08-2012, 03:42 PM
Partly because rain drops aren't actually teardrop shaped. :P
EDIT: Beat me by 2 minutes, meanjoe75fan!
06-08-2012, 03:49 PM
...beats walking...
...don't falling raindrops look more like blood platelets, ie: semi squished / flattened in their vertical plane due to air pressure against the center of its originally spherical shape?
...or, maybe, more like a clear Hersey "Kisses" chocolate drop falling with its "flat" bottom facing downward?
06-08-2012, 04:16 PM
EcoModding Lurcher
But don't ignore Reynolds number.
-m
06-08-2012, 06:08 PM
teardrop
*Teardrop is not rain drop.
*rain drops alter their form continuously as they fall,as they are a deformable structure,yielding instantaneously to any stressor.
*A raindrops terminal velocity is meaningless unless its mass and time-averaged mean frontal area was specified as well as Reynolds number Same for human.
*The 'teardrop' is used in reference to streamline bodies of revolution of blunt nose and tapering tail.
*Streamline bodies are given the term due to the fact that they are 'streamlined',having no separated flow,and no appreciable turbulent wake.They are the lowest drag form for any structure tested.
06-08-2012, 09:25 PM
I really tried to make it obvious with the "check mate" comment, but you guys are really easy to troll... LOL.
Thanks for making me giggle, though. It's been a long week.
The Following User Says Thank You to Christ For This Useful Post:
06-08-2012, 10:32 PM
#9 (permalink)
Drive less save more
Save gas
06-09-2012, 08:58 AM
#10 (permalink)
Can I haz Coroplast plz
I've got a good one: what's the difference between a tear dropped car and a fish shaped car without any fins?
And as a side note: its nice to see efficiency working superbly in nature with the low drag flow throughout the body of a fish with its beautifully tapered body (like the marlin).
