Old 06-24-2008, 11:45 PM   #1 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
Pulse and Glide
Well I tried this and on the glide I cutoff the engine too on a long striaght strip. I am not worried so much about the cutoff b/c my car has EPS and the brakes showed no sign that I could not stop fast enough. My issue is only with the restart. I pop the clutch and it starts. This can not be good for my or any car. I know if your battery is dead you can push start a manual. But I always heard it is bad on the starter. Any thoughts?
"There is no such thing as a dumb question.. Just dumb people".
Old 06-25-2008, 08:30 AM   #2 (permalink)
dwendt1978's Avatar
Dragon - '93 Metro XFI
90 day: 51.13 mpg (US)
You don't "pop" the clutch at all!! You just slowly let it out.
For example in my car, if I'm rolling at 35 mph, I put it in 5th gear and slowly let out the clutch and you can't even feel it start.
At 25 mph, same gear but then after restart I drop into 4th to get back upto speed.
This process should be soooooo smooth that if there was a passenger they wouldn't know what you were doing unless they seen it.
Old 06-25-2008, 08:30 AM   #3 (permalink)
dwendt1978's Avatar
P.S.
You completely bypass the starter doing this.
Old 06-25-2008, 08:46 AM   #4 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
Yea, if you any popping, it's going to break something eventually...
You should be letting out the clutch slowly until you can find that exact point where the clutch is in just far enough to let the wheels scrub the engine and get it spinning. Once you can do it consistently, you can start to go faster if you would like (less wear on the clutch?) but you just have to remember where the clutch needs to be and not go further than that. It should be neither violent or rough, if done properly, like dwendt1978 said, you shouldn't even be able to feel it start.
Old 06-25-2008, 08:50 AM   #5 (permalink)
POS - '97 Aspire
90 day: 47 mpg (US)
how could it be bad on the starter? the starter doesn't even know the engine was shut off or started!
Old 06-25-2008, 08:53 AM   #6 (permalink)
Bicycle Junky
NoCO2's Avatar
The only time P&G could ever be bad for the starter is if you were turning the ignition and trying to pump start at the same time, it would be the equivalent to trying to turn the engine over with the starter when then engine is already running. If you aren't specifically telling your car, via turning the key all the way over like you would to start it, then the electromagnets in the motor for the starter are not activated and the spindle inside the starter motor just spins like it always does when the engine is running.
Old 06-25-2008, 09:05 AM   #7 (permalink)
POS - '97 Aspire
90 day: 47 mpg (US)
most starters are not engaged when they are not being used (i've never actually seen one that was continuously engaged w/ flywheel/flexplate). When the starter is engaged, the gear extends to meet the flywheel/flexplate. If there are cars that don't do it that way, i'm curious to know!
Old 06-25-2008, 09:22 AM   #8 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
Well hybrid cars the electric drive motor is the starter too... so technicaly.. lol
Old 06-25-2008, 09:22 AM   #9 (permalink)
Modified Driver
Twerp's Avatar
Location: South Western middle of nowhereish New Hampshire
Frozen Tundra - '03 Tundra 4WD SR5 Access Cab
90 day: 26.51 mpg (US)
Red Skateboard - '91 Civic DX
90 day: 45.49 mpg (US)
You're prolly thinking of the cat... All of my owners manuals have said not to pop start the vehicle because it can do serious damage to the cat. They don't mention anything about the starter.
Old 06-25-2008, 09:36 AM   #10 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'd look here:
How to smoothly bump start / clutch start an engine
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Pulse and Glide with hills Tango Charlie Hypermiling / EcoDriver's Ed 14 06-05-2008 01:46 PM
Pulse and glide with Caravan automatic (actually EOC) popimp Hypermiling / EcoDriver's Ed 20 12-29-2007 01:10 AM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
