Old 09-30-2009, 12:56 AM   #21 (permalink)
03 OZ - '03 Lancer OZ Rally
90 day: 34.67 mpg (US)
Originally Posted by blownb310 View Post
Jim,
Do you have an underhood pic of the hot air setup you built?
Mike
Would be interested in that too as I have a K&N intake - as of yet unmodified.
Old 09-30-2009, 12:02 PM   #22 (permalink)
ScabbySentra - '93 Sentra SE
90 day: 44.37 mpg (US)
I don't have a picture, but the setup is extremely simple. I removed the stock intake 'horn' assembly that attaches to the intake box. It's the plastic piece that has two forks, one going forward and the other down to the intake port in the fender well. That leaves a round opening into the air box. I attached a piece of appropriate sized accordion type exhaust riser tubing that I bought at a parts store. It's about 3 inch diameter by about 3 feet long, pleated paper with wire coiled inside. I routed it forward from the air box, then across the front of the engine compartment. It's tied with wires to various points to hold it in place. The open end is then stretched out to be about two inches away from the exhaust manifold shroud, next to the O 2 sensor.
You could as easily use a dryer exhaust vent tube, the foil/wire accordion type.
If I can bum my wife's camera, I'll post a photo in case my description is unclear.
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Pulse & Glide on Hills mush3gan Hypermiling / EcoDriver's Ed 2 07-06-2008 01:53 AM
Pulse and Glide with hills Tango Charlie Hypermiling / EcoDriver's Ed 14 06-05-2008 01:46 PM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
