Old 12-11-2007, 06:33 PM   #21 (permalink)
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
featurecreepitis
I'm putting down a wishlist of features I'll include in version 1.1.
-US units - I can't count on people having either completely US units or metric units as a resource, since a lot of these figures will be straight out of google. So there will have to be options for each.
-parasitic loads included (e.g. alternator), maybe A/C (suggest others and likely power draw)
-transmission losses for autos
-constant velocity cruise in gear automatically calculated for comparison
-two valve per cylinder engine map (I believe that Variable Valve Timing and Lift (VVT&L) engines should be the same as a 4 valve/cylinder engine in terms BSFC(min) for a given rpm. Based on the graphs here.) Note that the vertical lines of BSFC from 2300 on are at identical rpms, and this is where we want our engine operating during the pulse.
-diesel engine map
-something saying that Engine Size is only useful for calculating idle fuel burn rate, so if you have a hybrid this should be zero. Or maybe just a check box for Hybrid/Engine Off Coast (versus idle).
-I'll include Synlube after effects have been independently verified and quantified.
-results in l/100km, mpg, km/l.
Let me know if I've forgotten anything.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
Old 09-24-2008, 06:30 AM   #22 (permalink)
LeanMeanGreenMachine - '95 Tercel DX
90 day: 47.67 mpg (US)
TurboQuattro - '89 200 Turbo Quattro AWD
Last 3: 33 mpg (US)
DeathTrap - '94 Escort LX
Last 3: 36 mpg (US)
CreamPuff - '96 Stratus
90 day: 27 mpg (US)
Pulse & Glide Online Calculator
Old 09-24-2008, 10:38 AM   #23 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The instructions page doens't seem to load correctly Drew. Also, welcome to the site.
Old 10-20-2008, 03:06 PM   #24 (permalink)
EcoModding@Large
LOGAN - '08 Logan GLE
Yes this works
Old 10-20-2008, 09:41 PM   #25 (permalink)
Last 3: 33 mpg (US)
Last 3: 36 mpg (US)
90 day: 27 mpg (US)
I've fixed the instructions and am currently working an easier-to-use version for common American units - gallons, miles, and m.p.h.
Old 11-04-2008, 03:32 PM   #26 (permalink)
EcoModding@Large
The hard part is maintaining that elusive 62% at different gears/throttle positions and speeds.
This is the one figure I am tracking on the ScangaugeII while pulsing. Dramatic results! Am achieving sustained fuel efficiency close enough to BSFC(min) to make friends seriously envious
If only we could get some Audible alarm that buzzes a LOW tone below ~57% and a HIGH tone above 67% engine load and I would not have to look at the Gauges at all while driving!
