Go Back   EcoModder Forum > AltModding > Saving@Home
Old 12-05-2009, 05:47 PM   #1 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Pulse and Glide my heater?
It's really anoying to me that the heater will come on for 5 min's then click off because the temp droped by one degree, then went up again. This happens pretty often. I've got a programable thermostat, older one. I've looked and I can't find any info on home thermostats that you can set a point for the heater to come on and go off. For instance, let the home cool down to 68 degrees and the heater kicks on till it reaches 72, then stays off until it's down to 68 again....
Any idea where I can find a thermostat that can do this?
Old 12-05-2009, 06:25 PM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Doesn't sound comfortable and furnace combustion isn't like engine combustion.
Old 12-05-2009, 06:32 PM   #3 (permalink)
Team ZX2
I got an oil fired boilder for base board radiant heat. Just 12 minutes ago the heater kicked on and ran for ten minutes then shut off. The base boards never even got warm, just wasting oil and not even heating my home...This madness must stop!
Old 12-05-2009, 06:36 PM   #4 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Oh that doesn't sound good. Sounds like the limit switches need adjustment.
Old 12-05-2009, 06:50 PM   #5 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
In the classic old Honeywell thermostats, you will see a small spiral of resistance wire. It is there to heat up the thermostat itself, instead of waiting for the furnace heat to get there. The contact point for the wire is adjustable, and the more wire you use, the less heat it makes. There may be a similar arrangement in many other thermostats.
Old 12-05-2009, 06:57 PM   #6 (permalink)
Team ZX2
This is a digital programable thermostat....
Old 12-05-2009, 07:24 PM   #7 (permalink)
Replace the thermostat.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 12-05-2009, 07:48 PM   #8 (permalink)
Team ZX2
Is it faulty?
I went out and bought a fancy Programable thermostat today, but it has the same features as my old one, just 7 days instead of 5 so I haven't installed it yet....
Old 12-05-2009, 08:35 PM   #9 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
google oil furnace cycling; plenty of things to think about there.
Old 12-05-2009, 09:01 PM   #10 (permalink)
Team ZX2
Gotta like a site called HVACOracle My Furnace burner cycles on and off
I believe my issue may be the cycling rate is not adjustable on the old T-stat. The new Thermostat I got has a setting for oil heating, so I presume it has some cycling rates in there to allow for proper warm up. I will try it.
Pulse and Glide on the Honda CRX SVOboy Hypermiling / EcoDriver's Ed 4 05-09-2009 01:19 AM
Pulse & Glide question Christ Hypermiling / EcoDriver's Ed 22 12-18-2008 02:53 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 08:26 PM
Pulse & Glide on Hills mush3gan Hypermiling / EcoDriver's Ed 2 07-06-2008 02:53 AM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 09:06 PM
