Old 12-18-2008, 09:17 AM   #21 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Ah, a Grand Prix - nice car. That's a great highway cruiser. Just go nice and easy on the gas pedal and it'll reward you. MUCH easier than many other cars. The transmission is eager to unlock when you let up on the gas, so you'll have little need to manually shift into neutral. Just keep it rolling. Stops are a killer on those. (actually, it's the start that follows...)
A friend here has a Buick with the same drivetrain. He gets ~25 mpg in town, but has come this close to 40 on highway trips.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 12-18-2008, 10:04 AM   #22 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Given that it's an automatic, I think your best hope is DWL in top gear with the torque converter locked. Without instrumentation, DWL is harder to do. You'd be surprised at what the slightest - almost imperceptible - changes in throttle position do to your current fuel consumption.
For DWL, a vacuum gauge would work fine.
Or wire a multimeter to your MAP sensor and aim for voltage readings that correspond to lightest load.
Old 12-18-2008, 01:53 PM   #23 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Pale - Tell me about the starting off again thing.. I try not to stop if I don't have to, b/c I can actually hear the car groaning under it's own fat backside when I hit the gas again. If we end up keeping this car, I intend to do something about THAT as well.
MetroMPG - Thanks for the tip, I'll have to see how this trip up north works out.. if it's pretty good, I'll probably invest in a Guino kit and go from there, since I can put it in a diff car later on. (PS I think I have a vacuum/boost gauge somewhere, actually.. )
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Pulse & Glide on Hills mush3gan Hypermiling / EcoDriver's Ed 2 07-06-2008 01:53 AM
Pulse and Glide with hills Tango Charlie Hypermiling / EcoDriver's Ed 14 06-05-2008 01:46 PM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
