Old 10-04-2011, 02:42 AM   #11 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
I try also to "swoop" speed on the flat section or if possible in the end of the previous downhill. But in my diesel on the uphills I use glide with minimun load to climb the hills. On a diesel if I use best load that would mean almost always that I would accelerate on the uphill and the speeds would rise very high.
www.tuneko.com
Less drag = Less fuel
Old 10-04-2011, 03:04 AM   #12 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Cool demonstration !
"now I have lost my truck and I will have to find a new one"
hehehe
Old 10-04-2011, 09:34 AM   #13 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
Originally Posted by SentraSE-R View Post
60-45, or 55-40. Better yet, find roads where you can P&G 40-25.
That depends on your vehicle (and traffic obviously). Generally my ideal P&G speeds are 45-27ish mph. I set the low end by the lowest speed I can run in top gear (6th for me)--that way I'm never shift during a pulse.
That being said, recently I've played around with what I call "superglides". Most of my commute is on a 4 lane divided non-interstate mostly-rural highway (55-60 mph speed limit). On the rare occasion when there's nobody behind me as far as the eye can see, I'll glide all the way down to my 5th gear low speed range (about 20 mph), then pulse back up to 45 mph, shifting into 6th about 30 mph. Usually, I'm lucky if traffic allows for more than 1 or 2 of these per commute, but it seems to help when I can do it. But, like I said, I only do it when there's nobody behind me--I don't want some guy going 65 mph and not paying attention to come up and ram me in the tail.
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
Old 10-04-2011, 10:03 AM   #14 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
On clear roads with no constraints, 25-40 mph is my best speed. That's what I use for my daily commuting.
The "swooping" technique I find highly useful with a quick-to-downshift automatic.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 10-04-2011, 10:15 PM   #15 (permalink)
Whitey - '010 Ranger XL
Pickups
90 day: 29.44 mpg (US)
Wife's - '010 Clubman
90 day: 36.08 mpg (US)
Thanks for all the replies! So I need to lower the LOD I use when pulsing... I usually edge as closely to the 99 as I can, but I can try to lighten the lead foot down to 75. Unfortunately, my drive to work really has no lightly traveled city roads. I think, I can fudge at one section of it, but that's it. I have been using my scangauge over the past week and a half and my personal best trip to work is about 42.5 MPG.
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 10-13-2011, 09:19 PM   #16 (permalink)
Spaulding Rally Master
Fat Charlie's Avatar
Spaulding Bobsled - '05 Legacy GT
Subaru
90 day: 30.71 mpg (US)
With experimentation, you'll learn the minimum "launch" speed at the hilltops to maximize your glide. Sometimes pushing a little harder than you want can carry your glide over a smaller rise down the road that you would have had to restart to get over.
At last fill-up, number 30 by POE (active)
47) "Drive without brakes" (DWB) Minimize use of the brake pedal. Each time you press it, you're effectively converting gasoline into brake dust and heat.
Old 12-23-2011, 11:12 AM   #17 (permalink)
RebInsight - '010 Insight EX
What is LOD?
Old 12-23-2011, 11:39 AM   #18 (permalink)
Originally Posted by reb01501 View Post
What is LOD?
% load. It's available from a Scangauge or Ultragauge. It's the % of maximum load that you're currently running.
Diesel Dave
The Following User Says Thank You to Diesel_Dave For This Useful Post:
reb01501 (04-11-2012)
