Old 05-01-2011, 10:36 PM   #1 (permalink)
Black Magic - '96 Civic HX
90 day: 46.37 mpg (US)
Pulse and Glide VS DWL
Driving with load says you should hold throttle constant going up and down hills.
Pulse and glide/BSFC charts suggest you should pulse up them in low gear at high throttle and coast down.
Both theories are pretty well accepted around here, but they appear contradictory to me in this area.
Explain/discuss.
Old 05-02-2011, 05:11 AM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
When you get your best MPG during constant load driving, the engine isn't working at its best BSFC.
That's the key to P&G.
The engine is only returning good MPG because it's hardly putting out any power.
It could make more power more efficiently, if only you'd let it.
But in normal driving, you can't let it as you'd always be accelerating because the engine would put out more power than what little you'd need.
Enter P&G.
The pulse is done near the best BSFC.
MPG are fairly high, but there's also a lot of power being generated very efficiently, for a short period of time.
Gliding engine-off consumes no power at all.
(Keeping the engine on uses only a little bit of gas - though in a highly inefficient way)
The catch is to stretch the glides to the maximum, i.e. reduce drag as much as possible.
The combination of bursts of highly efficient fuel use with no fuel use at all, is often better than driving with constant load at an inefficient power setting.
Lifetime fuel consumption :
Old 05-02-2011, 12:16 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
^^^ That's why MT P&G beats AT DWL, because the P&Gers only run their engines when needed, while the DWLers have to run their engines all the time when moving
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 05-02-2011, 12:41 PM   #4 (permalink)
So in your opinions DWL is more of a "stopgap" measure. Pulse and glide is the one true way.
Old 05-02-2011, 01:56 PM   #5 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
Pulse and glide can get cumbersome, with traffic, repeated starts and stops on a long journey. Most use a mix of the two. Pulsing and gliding where able, dwl where unable and driving "normal" where necessary.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 05-02-2011, 02:07 PM   #6 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Explain/discuss.
I thought DWL was you selected an MPG level (min and max) or a LOD rating (still don't know what that is based on) and drive to that rather than a constant position. You may combine it with a min speed range.
I am happy to be wrong about this...
No longer here. Bye, and good luck to all.
Old 05-02-2011, 10:04 PM   #7 (permalink)
This is my understanding of DWL as well.
Old 05-02-2011, 10:38 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
As Bestclimb said, most of us mix and match our driving to suit local conditions. P&G gets the best results, especially on level roads and downhills. DWL works well on short and moderate uphills.
Darrell
