Old 07-12-2010, 11:12 PM   #1 (permalink)
ChopsQube's Avatar
Nissan Cube - '010 Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Miata SE
90 day: 35.9 mpg (US)
Question Pulse and Glide without the clutch...
Something I started doing with this tank of gas is doing my P&G without using the clutch. It's easier and more convenient to me. I just push it out of gear as I ease off the gas, then once I drop to my minimum glide, I blip the throttle to rev-match and keep a little pressure on the stick and it simply pops back into 6th gear.
Do any of you do this too, or are you still using the clutch? Just curious.
Old 07-12-2010, 11:25 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I've been doing it without the clutch ever since my clutch broke I will probably switch to EOC and bump starts after I replace the clutch.
Old 07-13-2010, 12:01 AM   #3 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
I EOC and use the clutch to save wear on the starter.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 07-13-2010, 12:18 AM   #4 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
You're probably OK popping it out of gear without the clutch, but you might be burning up the synchros by not using the clutch going back into gear. If it were me, I'd use the clutch.
Old 07-13-2010, 07:19 AM   #5 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Clutch wear is minimal, while transmission rebuilds can get very expensive.
It might be OK to go to neutral at the beginning of the coast, but I would avoid trying the blipped throttle rev match when you reengage the powertrain. That would definitely require perfect rev matching to avoid synchro damage.
Especially for no mileage benefit.
regards
Mech
Old 07-13-2010, 09:46 PM   #6 (permalink)
ChopsQube's Avatar
Yeah, I must have had a lucky streak yesterday. I was able to rev-match perfectly every time and the shifter would drop right back in gear. Today on the other hand, I was either under-reving or over-reving almost every time, so I was just using the clutch to reengage, but still nudging it out of gear without the clutch. It was about a 50-50 shot today.
For now on, I'll be using the clutch to reengage.
Old 07-25-2010, 11:45 AM   #7 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
My ex-step used to call that "feathering". If you do it right, you can shift into gears with just the force of one finger. Too many people "think" they can do it by jamming it in - big no-no.
There isn't an problem if you do it right, but takes a lot of practice to get the revs right for the speed and gear. Him and me are the only one's I've ever seen do it right.
2006 3500 Dodge QC/FB 5.9 handshaker
Old 07-26-2010, 07:14 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
Like the others said, no FE benefit from shifting w/o the clutch. But glad to see you're still experimenting with the mpg game, and handily beating the EPA estimates. You should be able to top 40 mpg easily on highway trips just by slowing down to 60 mph.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 07-27-2010, 09:25 AM   #9 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
It is a useful skill to have, just in case you have a clutch failure. Barring that, I see no reason to not use the great clutch that's right there.
Something else to consider: a starter is much easier to replace than a clutch. It might be worthwhile to sometimes use the starter instead of bump-starting. (I usually bump-start, still)
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Getting 45 MPG at 207 MPH .... can you pulse and glide an airplane? MetroMPG Hypermiling / EcoDriver's Ed 43 03-03-2010 02:20 AM
Pulse and Glide on the Honda CRX SVOboy Hypermiling / EcoDriver's Ed 4 05-09-2009 12:19 AM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Pulse & Glide on Hills mush3gan Hypermiling / EcoDriver's Ed 2 07-06-2008 01:53 AM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
