Old 08-26-2008, 04:23 AM   #1 (permalink)
Sub-Hypermiler
Unhappy Question about EOC with an Auto... :confused:
Hi All!
Im new to the site and new to Hypermiling (although at this point i would call myself a sub-hypermiler).
Ive been perusing MetroMPG.com, Gassavers.org, CleanMPG.com and this site of course
I am slowly learning the lingo and science behind Hypermiling not to mention some of the car/engine/transmission limitations that I will have to overcome.
By no means is any one situation the same due to age and wear of parts, but I feel that I can still learn from others experiences to help with my own.
This brings me to my question. I have been reading about Pulse and Glide, Engine Off Coasting, and Deceleration Fuel Cut Off.
I guess what I drive will help... I have a 1996 Acura TL 2.5L Inline-5. I wanted to get something fuel efficent, but this car was mint and my uncle let it go for half the kelly blue book price, so it was cheaper than a Civic or Metro of similar age/condition.
My question is this. I know that Honda's have a lean burn mode (so Im assuming that acura's do too) and that for an automatic its best to DFCO with the transmission in gear to power the engine since the fuel has been cut off. But can i really EOC?
Well, I got to screwing around (i got bored, who doesnt from time to time) and wanted to see what the car could do, if anything on a EOC. I get up to crusing speed on a nice area right before a downhill grade and kick the car into neutral. No issues rolling fine, but the engine is down to idle speed and burning fuel. Well, lets cut the engine to stop that. I key it off and then right back to the ACC selection (dunno if thats right, its the second click choice, the one that would let you activate the ECU along with accessories). Engine speed starts reporting again and all my usual lights click on, so when I get a scanguage that will be fine, and engine is off with 0 RPMS to verify. I coast down to 45 from 60 and then with radio off to listen, restart the car. I didnt hear any grinding of the starter since it had no load on the engine, and then popped it back into drive. No transmission lunge, jerk, pop, or anything. And to boot, it was already in forth gear. Of course i didnt apply any gas until the engine RPMS went back up for the normal range at that speed.
After that little test, i think that I could EOC with no issues, and even tested braking (had about 3 good pumps left) and steering (not an issue from lane to lane) on another EOC down the next hill.
Is there an issue here that Im not seeing? I really dont want to mess something up on this car. I am already getting around 3 MPG than the updated EPA standard and really think that I can get this car to around 40 just on mods but really want the driving skills and techniques to push past that figure.
Anyone else find that they can do this on their car or currently do this?
Thanks in Advance,
LBS
Now, I ride the Eternal winds once more! And none shall ever be my master!
Old 08-26-2008, 05:22 AM   #2 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
read your manual, can your car be towed with all wheel on the ground?
if not u may burn up your tranny, by not letting the fluid circulate.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 08-26-2008, 02:13 PM   #3 (permalink)
Sub-Hypermiler
Here is an quote from my Acura Service Manual:
If the vehicle cannot be transported by flat-bed, it should
be towed with the front wheels off the ground. If due to
damage, the vehicle must be towed with the front
wheels on the ground, do the following:
• Release the parking brake.
• Start the engine.
• Shift D4 to position, then N position.
• Turn off the engine.
That is essentially what I did... only the parking brake was never involved
It seems like I would be safe. Would you or anyone else agree? or do all car manuals say the same, but end up blowing up transmissions?
Old 08-26-2008, 04:19 PM   #4 (permalink)
EcoNoob
RSX - '03 RSX
90 day: 29.61 mpg (US)
Send a message via AIM to kaveman12
Welcome, fellow Acura hypermiler! Yes it is possible to EOC, but just be very careful and pay close attention to the transmission since Honda/Acura automatics are notoriously fragile as it is. (Interestingly enough, their manuals are all but bulletproof) My suggestion would be to get a ScanGauge and monitor when the fuel cuts off. When it cuts off just stay in D4, and the times it doesn't, coast in neutral. The gas used is minimal and it will save your starter in the long run. Just my 2¢.
Old 08-26-2008, 07:48 PM   #5 (permalink)
adrive7's Avatar
Ranger - '08 Ranger XL
90 day: 20.73 mpg (US)
Send a message via AIM to adrive7
One more story, take it as you like.
I tried EOC with my automatic Cobalt which is supposed to be ok to flat-tow. Upon restarting the engine I had transmission issues which caused jerky shifts until I was able to leave the car sit turned off for about 30 min. So, I wouldn't do it again in that car. Not saying your Acura is the same.
Ohio State Baja SAE
Old 08-26-2008, 08:04 PM   #6 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
What damage that may occur is cumulative and probably not immediately noticeable until the most awkward moment. If you must EOC, do it for short periods of time/distance. Be warned that you're rolling the dice if it is not flat-towable.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-26-2008, 11:35 PM   #7 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I had a 1999 TL 3.2L and now a 2006 TSX stock auto in the garage. The steering is the first to show a deficit. It gets pretty rough to steer, so be aware.
Including the '98 Integra automatic (daily driver), I can't really quantify the wear on the auto-trans at 137K miles. The recommendation is to keep it short and sweet.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 08-27-2008, 01:37 AM   #8 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 xB
90 day: 40.85 mpg (US)
Send a message via AIM to Z man
Basically, with an auto, its not worth it to EOC.
I have tried it, it can be fun and dangerous, but you really should just coast in neutral. It's a lot easier on the whole vehicle and less work for you. Plus you don't have to hear your radio cut out or scare passengers!
Old 08-27-2008, 04:42 AM   #9 (permalink)
Sub-Hypermiler
Well, upon further (and difficult due to the rarity of this engine/tranny combo) research i found out that I could EOC, but Acura recommends this only for short distances of around 25 miles and only at speeds slower than 35 MPH so its pointless.
Im now trying to confirm that i do have a deceleration fuel cutoff for this ECM and to what RPM until it starts pumping fuel again.
Old 08-27-2008, 04:55 AM   #10 (permalink)
Sub-Hypermiler
Dont you love answering your own questions...
If I had only waited a few more minutes before I posted....
Exert from my Acura Service Manual:
"Fuel Cut-off Control
• During deceleration with the throttle valve closed, current to the fuel injectors is cut off to improve fuel economy at
speeds over 1,250 rpm.
• Fuel cut-off action also takes place when engine speed exceeds 7,100 rpm, regardless of the position of the throttle
valve, to protect the engine from over-revving"
So, since i have been getting up to 40 MPH in 4th gear (my highest gear) with the auto shifting at 2k RPMS, i guess i will need to down shift into third when i decide to FAS (i think i used that term right even though i dont have a hybrid)
Here is one interesting thing i did read though:
Although, one idea that came to mind, although I dont know how dangerous this is and it would have to be watched to ensure I dont have to restart the engine is possibly splicing into the same wire that the ECM uses to cut power to the injectors and have a manual way to DFCO.
Im not sure that it would be beneficial though.
On a side note, I did order a ScanGauge II this morning, does it have an alarm feature that i could set to sound at the aforementioned RPM? Or does anyone know a way to set up a light to warn me before I get withing a few hundred RPM so that I can downshift?
Just a few thoughts to try and maximize FE.
Thanks again for all this feedback!
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
Auto in N question Doofus McFancypants EcoModding Central 14 08-20-2008 02:21 PM
EOC / P&G on auto... smells?? mush3gan Hypermiling / EcoDriver's Ed 14 08-05-2008 04:05 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
