Old 06-11-2009, 01:39 PM   #11 (permalink)
The Civic - '00 Civic DX
90 day: 37.05 mpg (US)
I guess my real question here is, if I have a dial with 30 clicks between hottest and coldest, what does the first click from coldest do to make it not as cold?
Old 06-11-2009, 05:09 PM   #12 (permalink)
Jalilah - '07 Cobalt LT
90 day: 40.57 mpg (US)
I THINK some of it runs through the heater core, and some past the condensor. However, i don't know.
-Steve
Old 06-11-2009, 08:35 PM   #13 (permalink)
With most a/c set ups the air is first sent over the a/c condenser to make it dry and also cold and then if needed it is sent through the heater matrix / core to add whatever heat is deemed necessary.
Many drivers want both warm air and dry air in a humid environment to defog windows etc.
Also auto a/c compressors are notoriously inefficient due to the operating rev range they are needed to work over.
If they were even close to the efficiency levels in household a/c units they would not last at speeds much above idle.
Pete.
Old 06-12-2009, 01:01 PM   #14 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.8 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
I think the original question as I understand is valid and representative of healthy curiosity, but I think the answer could be more tailored to comprehensive understanding if there is a secondary reason behind asking.
Peter7307 is correct (except air is cooled at the evaporator in the heater box; the condenser is up by the radiator and gets HOT). Cars with A/C have two heat exchangers in the HVAC box; an evaporator and a heater core. From there I'm aware of two different ways to control temperature that may be used separately and/or together. Some vehicles have a shutoff valve in the coolant line feeding the heater core that will stop the flow of hot coolant when no warming of the air is desired. Other vehicles have a "blend door" that controls the flow of air between the blower and the vents and allows varying proportions of air to flow over the heater core by changing position of a flap in the ductwork. AFAIK both could be easily used together.
The cycling of the A/C compressor is based on the refrigerant pressure. When running fully cold with a low blower speed the evaporator will get very cold as there is little air blowing over it to warm it up. When this happens the refrigerant regains less pressure after passing through the evaporator, decreasing the pressure on the low side of the compressor. Some systems have a low-pressure cycle switch that shuts off the compressor to prevent freeze-up until the low-side pressure increases (which will happen as the evaporator warms). I'm not sure if many vehicles do this, but one could detect an increase in high side pressure that will correspond with the same events as the decrease in low-side pressure and control the compressor in that way.
To improve fuel economy while using air conditioning the goal should be to maintain the coldest evaporator possible. Operating the ventilation system in recirculation mode allows the A/C to chill already cooler air from inside the car to keep the car cool while operating the compressor less. Using as low a blower speed as you are comfortable with helps as well. At night, in the shade, or when it isn't too hot outside you may notice that in recirc mode at low fan speed it still gets too cold. Rather than cooling outside air or turning up the temperature to warm the air with engine coolant you should turn off the compressor if your vehicle allows you independent control of the compressor (my truck has a snowflake button). When it begins to warm up again you can turn it back on.
Old 06-12-2009, 01:16 PM   #15 (permalink)
Modern cars cycle based on pressure of both high and low sides. They have a high side pressure switch, and a low side pressure switch. The low side pressure switch will not engage if the pressure is too low, and the high side pressure switch will not engage if the pressure is to high.
This also prevents the A/C from running if the coolant has leaked out!
-Steve
Old 06-12-2009, 11:55 PM   #16 (permalink)
MechEngVT,
Yes you are correct.
The evaporator in the heater box is where the cooling takes place not the condenser at the front of the vehicle.
Got those two mixed up.
Pete.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Magazine: Green Car Journal cfg83 General Efficiency Discussion 5 09-28-2010 12:18 PM
Getting Off Gas! bennelson Fossil Fuel Free 117 05-19-2009 12:36 PM
10 years to build an electric car? - Blog article bennelson Fossil Fuel Free 8 01-26-2009 09:01 AM
