Old 03-30-2010, 08:01 PM   #1 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Question about SGII and calibration
Ok so a day ago I filled up and hit "Fill Up" or whatever the button is, and when I get my next fill up I will adjust it...
My question is, I hooked up my SGII in my grandfathers truck while he drove so he could see he was getting 11 MPG... Does the SGII know that it was another car or will it count HIS miles on my thing?
Thanks
Old 03-30-2010, 08:21 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...but, did you *first* enter the engine displacement and fuel tank capacities?
...if you didn't, then the SGII will assume it's *still* working under the earlier inputs and NOT those partaining to your dad's vehicle.
...I'm guessing, it'll just add those numbers to what it thinks is your car's values.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 03-30-2010, 08:33 PM   #3 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Unless you reset the tank average it will show what the cumulative average is. So it will be off if you tansfer from one to the other without doing anything.
As Old Tele man stated if you did not set the engine perameters for your dads truck the reading won't be right. Also if you remove power from the device, as in unplugging it, sometimes it will reset to default vaules. Double check that the setup is correct or your numbers will be off.
"Judge a person by their questions rather than their answers."
Old 03-31-2010, 10:17 AM   #4 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
It does show a star (*) in the bottom right corner when you view tank values of any kind if it has been unplugged during that tank. That's the only thing it does.
Old 03-31-2010, 10:33 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Good thread title to add a related question: When entering the tank size, do I input the "official" (owner's manual) number, or the size that I believe is useable? In my case, the official size is 58 liters, but on more than one occasion I've put 63l in when there was at least another 3-5l still in there. Even the first "click" of the pump can be after 59l, and the tank wasn't dry when I pulled in. So if I enter 58 liters, then what will the SGII do when my next fill-up is more than the tank's size?
Piwoslaw's Peugeot 307sw modding thread
Old 03-31-2010, 10:40 AM   #6 (permalink)
Jyden's Avatar
Yaris 2000 - '00 Yaris Basic
90 day: 43.71 mpg (US)
Sound to me like the pump is calibrated wrongly, so you pay for more than you get?
Try and chek this at an other gasstation.
Old 03-31-2010, 11:08 AM   #7 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I regularly put 12.2 / 12.3 / 12.5 gallons into my "11.9" gallon tank. The official rating doesn't count for a little reserve at the bottom, or the extra capacity at the top if you top it off.
The tank size has no effect on anything, except the "miles to empty" and "gallons to empty" readings.
When you switch vehicles, you need to reset the gauge. Record the numbers on the old car. Adjust for the new car, drive it as needed. Record those numbers. Reset again for the first car, and for the rest of the tank, hand-calculate the total before and after the reset.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 03-31-2010, 11:50 AM   #8 (permalink)
I have it set to 15 gallons on my 14.5 gallon tank.
Old 03-31-2010, 12:37 PM   #9 (permalink)
The things you need to reset to get accurate mpg readings when changing vehicles:
- Engine size
- Speed calibration
- Fillup Offset - I do a fillup to reset the tank data, and reset the offset as well.
Also, any gauges that might be more or less useful in the other vehicle. (rpm in my civic which has no tachometer, but not in the Odyssey which already has one)
SGII first observations! Old Tele man Success Stories 10 04-02-2010 01:26 AM
SGII Horsepower gauge & related gauges RobertSmalls Instrumentation 3 03-03-2009 09:20 AM
SGII Not quite right dremd Instrumentation 37 09-26-2008 12:33 PM
Question: "Portability" of SGII? MechEngVT Instrumentation 8 08-27-2008 02:08 PM
ScanGaugeII Throttle Cut Off and MPG Calibration ballegre Instrumentation 9 07-18-2008 02:46 PM
