Old 10-03-2011, 08:51 PM   #1 (permalink)
50mph sur la 50
echo-francis's Avatar
echo-troll - '05 echo
90 day: 58.74 mpg (US)
question on Clutches ?
can a used clutche affect the fuel economy? (used like need to be change soon (not very soon))
Old 10-03-2011, 09:01 PM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
If it's slipping, yes.
Old 10-03-2011, 09:07 PM   #3 (permalink)
redyaris - '07 Yaris
90 day: 47.98 mpg (US)
Gray - '07 GS500 F
Motorcycle
90 day: 70.4 mpg (US)
KLR - '07 KLR650
Last 3: 62.78 mpg (US)
What are the signs and simptoms that you notice about the clutch?
Old 10-03-2011, 09:18 PM   #4 (permalink)
50mph sur la 50
a little slipping some times and wierd sounds some times but no problem with the 4 and 5 gear
Old 10-03-2011, 09:53 PM   #5 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
If it's weird sounds that happen in some gears but not others then you might have a transmission bearing that is going out, try replacing your transmission fluid? if your clutch is slipping tho not all of the energy is getting to the wheels so yes, it is costing you gas.
Old 10-04-2011, 12:37 AM   #6 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
A slipping clutch will show it most in top gear. Your description is the opposite.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 10-04-2011, 01:08 AM   #7 (permalink)
50mph sur la 50
maby i dont feel the slipping in top gear. but i recently made a trip of 140 km that i am used to do and a got a average of 4.05l/100km and about one month ago i did the same trip and i got 3.6l/100km dont know if its the clutche?
Old 10-04-2011, 02:07 AM   #8 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Hard to say, but could it be related to the cooler temperatures we have had over the past week or so ? There are so many factors than can have an impact on fuel consumption.
Old 10-04-2011, 09:19 AM   #9 (permalink)
Ryland's Avatar
Replacing the transmission is not much more work then replacing the clutch, so if you are already prepared to do the clutch you might just do both.
A bad bearing in the transmission is going to give you poor mileage as well, if it's the main bearing then it could be leaking fluid on the clutch causing it to slip.
Old 10-04-2011, 09:30 AM   #10 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Are you running out of pedal travel upwards after the clutch has engaged?
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
