Old 08-23-2010, 05:47 PM   #1 (permalink)
Racer XD - '06 Elantra GT
90 day: 35.42 mpg (US)
Questions about making an electric bicycle.
I have an old razor electric scooter that does not work, and some old bikes. My idea was the take the peddle of the bike and add the motor to the sprocket, so its like I am peddling but the motor is doing the work. Also use the gears from the back wheel for different gear ratios.
Do you think this would work?
Or do you have any other ideas of what I can do with the parts?
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 08-23-2010, 07:26 PM   #2 (permalink)
Most bicycle gears will not handle reverse torque during regen unless you add a locking mechanism.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-23-2010, 07:53 PM   #3 (permalink)
I don't see why not-if the scooter was able to propel you by itself then it should be fine for power assist(or better) on a bike.
Were you planning to pedal this bike or just replace the pedals with the motor? If the former then you need to be careful of the Gearing lest the pedals start slapping your feet around(a freewheel pedal crank would solve that quickly enough)-if the latter, be advised that a powered, pedal-less bicycle might be illegal in many states...
If you wish to retain pedal power your first solution would work-other options include:
-independent chain to a gear on the opposite side of the rear wheel
-Rear wheel in the front fork for freewheeling FWD(beef up the drop-outs if you do this)
-friction drive directly to the front or rear tire(has its drawbacks but it easy to set up).
Also, do you know why the Scooter stopped Working? Eliminate that one component and you can likely salvage all the others for the bike(batteries, controller, wiring harness etc)...or fix the Scooter of course.
The link below has everything you'll need to get started:
Endless-sphere.com • Index page
(I lurk there once in awhile but refuse to join until I have the time to make one of my own) Also:
Browser Warning
Best of luck!
Old 08-25-2010, 12:23 AM   #4 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
If you remove the pedals, you'll need to make footrests. Given that the scooter had much smaller wheels, you may need a reduction gear in there, not the standard step-up from the pedal axle.
Old 08-26-2010, 07:18 PM   #5 (permalink)
Ok. Thanks for all the helpful info guys.
I will have to get some pics and post them to show what i have to work with.
Old 01-30-2011, 04:18 AM   #6 (permalink)
How did this end up working? I want to do something VERY Similar (cept I don't have any motor in mind yet) But I want to take my 21 speed 26" mountain Bike and make it electric. But I don't want any hub motors I want to remove one of my pedals gears out of the equation and instead link it to a motor. Are there any affordable kits out there to do this with (I've checked around and cant find much) This is a Mid-Drive setup right?
Old 01-30-2011, 04:10 PM   #7 (permalink)
I never did end up getting to this idea. I was just getting some ideas form people form here to see if it would work the way i had envisioned it.
bicycle, electric, motor, project
Electric Cars Push Japan Engine Parts Makers to Crisis Mode tjts1 The Lounge 12 01-17-2010 12:23 PM
Electric motor questions Tango Charlie Fossil Fuel Free 3 06-02-2009 07:14 AM
Ever seen an "antique" electric bicycle? MetroMPG Fossil Fuel Free 4 02-04-2009 11:58 AM
hybrid bicycle with electric CVT? NiHaoMike Alternative Transportation 11 01-25-2009 06:06 PM
Making an electric bicycle (looking for advice) NoCO2 Alternative Transportation 44 06-04-2008 02:54 PM
