Old 10-27-2009, 03:55 PM   #1 (permalink)
Grocery getter - '99 protege DX
Last 3: 38.1 mpg (US)
CRX Otterbox - '91 CRX HF
Last 3: 51.07 mpg (US)
Send a message via AIM to HeadlessNorseman
questions on manual driving
Hey...ive just got some simple questions. Basically...regarding starting in first gear vs 2nd gear
Is it more efficient to use 1st gear for a minimum of time, and short shift(1800 rpm) into 2nd? or drag first gear out a little longer and shift to 3rd?
or...Is starting in 2nd better, because of the taller ratio? but with more load on the engine it may not be worth it?
and finally...is there a "minimum" rpm at where you will be using less fuel? for hypothetical example...if i shift to 5th at 25 mpg, the engine chugs a little bit around 900 rpms. Or if i stay in 4th at 25mph...it runs smoother but at 1200 rpms. Which version is better?
Old 10-27-2009, 04:05 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
It depends on the gear ratios in your transmission, and your transaxle's final drive ratio. Some cars can start in second gear fine. Some can skip gears without a beat. Some can lug at low rpm in 5th gear. Others can't. Generally speaking, lugging your engine at too low an rpm is a bad thing to do. I'd rather err on the side of wasting a little gas, rather than damaging an engine.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 10-27-2009, 04:20 PM   #3 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I regularly start in 2nd gear. I shift early and "semi-lug" my engine, down to about 1000 rpm in some cases. I hate driving above 50 mph, because that takes me above 2000 rpm. You can see the results below.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 10-27-2009, 09:18 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...too much lugging for too long duration can "eat" main bearings, epecially if the engine's already old and parts are obviously worn.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 10-27-2009, 09:38 PM   #5 (permalink)
Weight Reduction
Drive Stick's Avatar
neon - '95 neon Highline
90 day: 37.7 mpg (US)
Subaru - '98 Legacy L Wagon
90 day: 29.94 mpg (US)
Saab - '98 900 S
90 day: 51.25 mpg (US)
Impreza 2.5i - '011 Impreza 2.5i
90 day: 24.06 mpg (US)
Blue Crush - '011 Prius II
90 day: 50.98 mpg (US)
Send a message via AIM to Drive Stick
As previously mentioned, there is no benefit to lugging your engine for the sake of saving fuel. You will replace a $3,500 engine once you spin a bearing, or snap a connecting rod and burn up many times the amount of money replacing your engine, or vehicle.
Row through the gears at 60% throttle or so and you will see the best combination of acceleration, and gas mileage in my opinion. Skipping gears is ok if you feel guilty about shifting through all 5 speeds, but only if you are not dropping below 1,800 rpm or so in any upshift. (unless traveling downhill when you won't lug the engine.)
Some people have mentioned reaping excellent gas mileage from never going over 2,000 rpms but every vehicle is different. My V8 truck can handle shifting early, its got 8 cylinders to power me along effortlessly. My 4 cylinder car can not be shifted too early with out lugging, it all depends on the vehicle and engine, play it by ear and gas receipt.
you'll find that winning combo of fuel efficiency, and longevity of your engine.
Old 10-27-2009, 10:30 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
you really have to define "lugging" better.
yes there is a minimum rpm to keep the oil distributed, but I don't know that it is 1800rpm, or even 1000 rpm.
Bearing wear and low RPM high/load operation.
Lugging the engine - good or bad for economy?
Key concepts:
1. the rpm must be sufficient to keep the oil layer intact, i.e. above idle.
2. Bearing wear is a function of rpm and load at the low end. extremely low rpm is usually pretty low torque for an ice, so it is somewhat self-regulating.
3. if you are centering your shifts on bsfc peak, you don't really have anything to worry about anyway.
I just don't want folks racing their engines out of an irrational fear of a $3500 engine repair bill.
Old 10-27-2009, 10:39 PM   #7 (permalink)
Bingo.
Old 10-27-2009, 11:01 PM   #8 (permalink)
well i didnt mean to totally lug the engine around. But more like.... for example, 1st, 2nd, 3rd, all using 10% throttle to maintain safe acceleration. Or, start in 2nd and use say 14% throttle and 10% in third. Any advantage either way? Its just rpms vs load im asking about basically. And please explain bsfc peak? or better yet...how do i find it for my car? i know that is something like brake specific fuel consumption...but i thought that was for figuring out proper AFRs on the dyno?
Old 10-27-2009, 11:31 PM   #9 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
10% throttle isn't safe, especially in NJ. 40-45% is safer, but doesn't load the engine as much as you could.
If you go 100%, or close to it, you're probably running in open loop, dumping fuel. Try 70-75% and see how you feel about it. If it's too much, back it off a bit.
Old 10-28-2009, 12:34 AM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
here are some:
The BSFC chart thread (post 'em if you got 'em)
Basically, if you know (or make a reasonable guess) under what load/rpm your engine makes the most power for a given amount fuel, you can control the throttle and shifting to maximize your efficiency during acceleration.
The big trick is knowing when to stop accelerating and start coasting, so you don't turn all that gas energy into brake heat.
In absence of actual data, I usually shift at 2700 rpm and keep the throttle at 3/4 open. My tdi is different, it is wide open throttle and shift at 2000 rpm.
here is the tdi graph, the peak "oval" is at the top of the torque curve centered at about 1800 rpm. When I shift at 2000 rpm it drops down to about 1600 rpm and so I accelerate from 1600 to 2000 rpm at the top of the graph where it is most efficient (plus I don't brake much)
Project: 3D Driving Model noeryan General Efficiency Discussion 51 04-01-2012 10:38 AM
11 mpg to 15 mpg is it possible mostly on driving style and small mods? strider3700 Introductions 48 05-09-2010 02:08 AM
"Hypermiler" pulled over for driving too slow SVOboy Hypermiling / EcoDriver's Ed 100 11-02-2009 11:11 PM
Choosing a Manual Transmission Fluid for my Mazda Protege 1337 EcoModding Central 5 03-20-2009 12:07 PM
[Donation] Geo Metro Factory Service Manual XFi For Sale 7 11-07-2008 02:55 PM
