Old 08-22-2008, 02:29 PM   #21 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by MazdaMatt View Post
Skinny fingers were not intended to grip -35 steering wheels.
That's what gets me first -- hands/fingers. Then core temp goes and rest is downhill.
Although, I'd take the cold over the heat.
I once rented a Buick with a heated steering wheel. That was nice. Too bad it was a guzzling V-8.
Anyhoo, earlier-on, we were talking about underhood insulation. Is that similar to what's on my Dad's 1988 Oldsmobile or something more custom. I haven't seen a car with insulation (that I can recall) for a while.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 08-22-2008, 03:17 PM   #22 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
I think the hood insulation may have been for engine noise as much as anything else. It seems to have been on luxury cars longer than it was on others. My 93 Century had it.
Old 08-22-2008, 04:11 PM   #23 (permalink)
Neon1 - '97 Neon highline
90 day: 27.26 mpg (US)
Actually, it is not just luxury cars. The Neon has it installed, but I agree it is probably for noise restriction rather than for heat retention. Most manyfacturers want to get all of the heat OUT of the engine compartment. It makes cooling easier and prolongs engine life if a constant temp can be maintained.
In fact the battery on the neon has a "themoguard" with a cold air tube. So they had to add additional cooling....
Jim
Old 08-22-2008, 06:09 PM   #24 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
@ Mr. Mullet:
Good tip. I disabled the AC-on-with-defrost in the xB, and the Impreza I previously had. It wasn't a huge waste of fuel, but every bit counts. I disabled them semi-permanently by taking apart the HVAC controls in both cars, and simply moving the tiny switch that is closed when the defrost setting is selected. Sort of a pain to do, but I get results.
Old 08-23-2008, 08:09 AM   #25 (permalink)
There is a difference between defrost and defog. Defog works better with A/C (dryer air and all that). Defroster works better without A/C (melting ice with cold air is so effective). The air conditioner gets cold way faster than the engine gets hot.
If it was just an issue of the first few minutes of driving, I wouldn't be as concerned. But my Escape is very prone to fogging up when it rains, more so than any other car I've owned. That means that if I drive in the rain, I have to constantly turn on the A/C to defog. A steady draft across the windshield would do the same, but I don't have the option. Hence, I see a switch in my future.
Likewise, I suspect that the heater core is always hot because when I turn on the vent, the air is warmer than ambient. I can find no indication of a heater flow cutoff valve. Turning off the heat will require a valve, motor and switch, a little more involved than the A/C switch.
Old 08-23-2008, 09:10 AM   #26 (permalink)
Carbon based lifeform
dentprone's Avatar
Green Rocket - '01 Forester
Clifford - '76 M880
RuhRoh - '94 Metro
+1 on the defog/defrost
I worked on a late model F-series that was like that. I think it is fairly common nowadays. They use a door to open/shut off the heater core to/from the rest of the box. Unfortunately, when the door motor goes bad, it is in a real fun place to get to.
-Chuck
Watching paint dry?
Check out my blog.......
http://www.mobiblog2500.blogspot.com
Old 08-24-2008, 02:27 AM   #27 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
I hate HVAC controls that don't allow you to select compressor or recirculation independent of vent setting, both my cars have the dumbed down setup. But I'm pretty sure my Escort disables the compressor for the defrost settings when the ambient temperature is below a certain point, I think 45 degrees F. I assume it uses the IAT sensor to do this.
More choices...
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
Yikes! I've become a fuel saving nerd! metromizer Introductions 9 06-06-2008 10:19 AM
Psychological Ways of Saving Fuel Wayneburg General Efficiency Discussion 22 06-06-2008 09:24 AM
