08-21-2008, 09:22 PM
Hi-Tech Redneck
Quick fuel saving tip for Winter
If you have a vehicle that has A/C and would like to save fuel during the coming winter months, then do like I do and unplug the A/C compressor or remove the relay/fuse. Most vehicles are made to engage the compressor when in "Defrost" or other modes on your climate control selector, and this will waste fuel.
Some may argue and say.............
"Not running the compressor clutch will make it go bad!" - Then why do junkyards sell them?
"That freon has to circulate during winter!" - Just like it does in my A/C machine?
"The defroster will not work correctly!" - Um, what?
All incorrect statements. I have done this for years on all vehicles I owned with A/C and never had any problems at all. Not to say that maybe some newer vehicles with complex heater control systems (Volvo XC90, Cadillac, Lincoln, etc) will show some sort of fault, but if you are driving one of those puppies, then you seriously need to rethink what you are driving if you are planning to attempt a mod like this to save fuel.
An even better way to do this would be to purchase a belt for a non-A/C vehicle and bypass the compressor, but this does not work on some vehicles depending on the belt routing.
This mod along with installing a block heater to keep the engine warm and for warmer startups, a grill block, under hood insulation (if not equipped), etc will really help you in the fuel saving department over time.
Discuss.
08-21-2008, 10:58 PM
Hybrid Student Driver
Great idea  I vote for a switch, just in case...
Luckily my car has a switch to engage/disengage the compressor while directing air to the defrost vents.
When the car is parked outside for a few days, I like having the option -- if a bunch of snow gets in, starts to melt, and fogs up the works and just breathing does it too.
More on the reason: the extended parking situation (airport) offers no outlet for the block heater, so it takes a loooong time to heat up. I'd crack the window to let the dry air fix the situation, but the combination of continuing to freeze my arse, not letting the temp get up to allow TC lockup, and robbing the engine's heat is the 3rd strike. Even with a winter grille block, it's tough to get that heat. I hit the highway immediately in this case.
The worst situation last Winter: scraping a 1/2" layer of ice off of the glass, the temp dropped to the teens so it was freezing, and I don't idle the car to warm it up.
I'm sure there's a solution -- any thoughts? (other than being tougher in the cold -- I know  )
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
 _
 _
08-21-2008, 11:36 PM
Discuss.
Thanks for this JM.
I checked out the manual for my truck, and it looks like there is a fuse and a relay for the A/C clutch solenoid. My guess is that popping the fuse would disable the A/C -- it will be easy to test that.
I will explore the belt swap option as well. If anyone here has a recent B-series Mazda or a Ranger, I would like to know if you have any experience with swapping belts.
My 2008 B2300 came with a block heater, so that piece is covered. I will likely buy a timer so it switches on at 5 am or so -- two hours before I leave for work.
The grill block idea is straightforward, but under-hood insulation is a new concept for me. Can someone explain what it would look like so I can see if I am factory-equipped in that area?
EDIT: I get it now -- insulating the underside of the hood. "I was associating "under the hood" with the entire engine compartment...
Thanks,
bluesfan
In reverent quest of the last mpg...
08-22-2008, 12:23 AM
Addicted
Great idea Johhny, too bad I don't have a/c.  I do like the idea of adding underhood insulation, do you guys think the silver backed house insulation would do the trick? I have some of that laying around, some liquid nails and stick it in place,,,?
08-22-2008, 01:16 AM
Carbon based lifeform
Definitely...run a switch in the dash to make the process even easier. I suppose a relay would be really sweet, but add another link to the chain. Here in FL, though, I have always appreciated the A/C running with the defrost...seems to help cut the 100% freakin' humidity we have.
08-22-2008, 01:20 AM
Is it the thin bubble wrap type? I always wanted to stitch up a reversible hat out of that stuff, with one side dark fabric, other reflective. But then I think of all the tinfoil hat jokes..... I think liquid nails would hold it just fine on the hood, seems to be fairly high heat stuff.
08-22-2008, 07:13 AM
VIVA LA MPG RESISTANCE
Excellent topic. I do this to my wife's Buick every year.
08-22-2008, 08:16 AM
Well booo-fricken-hoooo... this IS an international forum remember! I'm not even in the "extreme north" and last winter we had a week where the temp didn't get above -30C... try THAT and tell me I shouldn't idle my car for a bit!
As for the compressor, i wouldn't turn it off because it blows dry air on my window for defog. Without it I'm screwed.
08-22-2008, 08:24 AM
#9 (permalink)
Great suggestion Johnny. I'll definitly have to do this to the Matrix this winter. I like RH77's suggestion about the switch too. Its nice to have the defrost for summer when its rainy or super humid out. But, in winter its totally unnecessary. Too bad they don't let you have the choice from the factory.
08-22-2008, 08:35 AM
#10 (permalink)
Huh???
