Old 01-06-2012, 10:08 AM   #1 (permalink)
Red - '07 Civic EX
Quick Question
Anyone able to tell me te difference between Engine Load vs Engine Load (Absolute).
Which should I be watching.
Old 01-06-2012, 10:59 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'm not exactly sure what you're talking about, but absolute engine load would be the percentage of power being used versus total power the engine can produce. Regular engine load would be % of power being used that the engine can generate at that specific rpm. Engine load is much more useful than absolute engine load.
Old 01-06-2012, 12:51 PM   #3 (permalink)
JediSpam's Avatar
The TSX - '08 TSX
90 day: 33.06 mpg (US)
I bet he's talking about the distinction between some of the aftermarket instrumentation like the scan or ultra gauge
Old 01-06-2012, 01:37 PM   #4 (permalink)
CM400E - '81 CM400E
Yeah, thats what I was thinking. I've never heard of any instrumentation that differentiates between the two though, it give you one of the two and thats it.
Old 01-06-2012, 09:27 PM   #5 (permalink)
Red - '07 Civic EX
Another question i have is MAP the same as Intake Manifold Pressure?
Old 01-06-2012, 11:10 PM   #6 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
MAP=Manifold Absolute Pressure. It's the opposite of manifold vacuum or the atmospheric pressure that is allowed into the cylinders for compression.
If MAP and Vacuum are equal then you have 50% of the potential compression of the engine. Half of the available atmosphere can get into the cylinders past the throttle plate restriction.
regards
Mech
