Go Back   EcoModder Forum > AltModding > Saving@Home
Old 12-12-2009, 12:27 AM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
Arrow rain catchment + water turbine = Pico Hydro Power
a recent project in rain collection got me interested in Pico Hydro Power
it rained the other day and filled a 50 gallon drum in 10 minutes
so why not make some electricity too?
has anyone had any experience in this?
Pico hydro - Wikipedia, the free encyclopedia
Make: Online : Bucket-borne hydroelectric generator
Past Present Future?
Old 12-12-2009, 03:25 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Unless you live in a place where it rains often, then this may not be cost-effective. The output would not be kilowatts, but only a few watts. How often does it pour, and for how long (answer may vary denpending on where you live)? Most rain is not more than a drizzle for hours at a time, and there is not much energy in a gutter that is just dripping, probably not enough to overcome internal friction. Collecting water on the roof until there is a certain amount and then letting it rush down onto the turbine may be better, but holding a ton of water on the roof isn't a good idea.
On the other hand, maybe there is a better way to it? Maybe a formula for how much power is to be had per roof area, where the inputs are volume of water per area unit per time unit (how intense) and head of water (height difference between roof and turbine). Very interesting... Now I have something to think about
Piwoslaw's Peugeot 307sw modding thread
Old 12-12-2009, 03:57 PM   #3 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
It is pretty easy to calculate from gallons of water to pounds, and measure the vertical fall, etc, to get the potential HP (33,000 lb-ft per minute) and get from there to watts. One problem with tiny pelton wheels is that as you scale down, the boundary layer in the nozzle starts to dominate, and efficiency drops. I'm fond of systems with stored water and two ponds or tanks separated in elevation instead of a battery to store available wind power or whatever. However, for low-draw, on-demand generators, I think we will find that small, positive displacement diaphragm pumps will be very suitable, running backwards.
Old 12-12-2009, 06:36 PM   #4 (permalink)
Grasshopper
thats kinda what i was thinking about
collecting water in tank/drums and once the level is high enough,
releasing a valve to push the water towards the turbine
it may only be for x amount of time, but its power
might be good when theres a flood and the power goes out
why dont water towers use these?
and it rains a lot in hawaii
The average annual rainfall over the entire state
is equivalent to 8,000 billion gallons of water
Old 12-12-2009, 07:05 PM   #5 (permalink)
Water towers are only tall enough to generate the desired working pressure for sprinklers, etc. There would be no point in pumping water to a higher tower and then recovering some of the pump power with a turbine.
Old 12-12-2009, 08:05 PM   #6 (permalink)
Grasshopper
no pumps
i meant water reservoirs not filled through a pump
just by rainfall
Old 12-12-2009, 08:28 PM   #7 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
It's a neat idea but I feel like others have said, it's awful complicated set up with many moving parts (things to break). It can charge 11 cell phones which was the intended purpose I guess, but that's still only like 50 watts max. (Total guess there)
Thats almost a single light bulb and only during peak rainfall.
Wouldn't a solar cell phone be better? How big of a panel is necessary to get the 5V 0.7A necessary to charge a phone?
(3.5Watts)
Daily Driver
Winter Beast
Old 12-12-2009, 09:08 PM   #8 (permalink)
Grasshopper
i believe there are $20 pico generators that have an output of 300-500 watts
Old 12-12-2009, 10:16 PM   #9 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
Believe it or not, in Colorado it's illegal to catch rainwater unless you have water rights, and hardly anyone in Colorado has the water rights to their own property. I know people who've gotten in trouble catching rainwater to water their horses and trees.
Water law in the west is complex, and mostly ridiculous.
Old 12-13-2009, 12:33 AM   #10 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Hm... Seems like rain water isn't really property water until it reaches the property... so if you're catching it out of the air, and the water rights apply to water on the property, it's not really subject to water rights laws, eh?
I mean, unless Colorado's title laws allow land ownership to the area of the land deed, including area below ground and above ground, in which case, whoever owns the water rights to that property would still have property rights to the water falling from the sky.
However, if CO's deeds don't include the area above the land in their ownership (which must be in detail, of course), noone can say anything about capturing rain water, as ownership doesn't take place until it becomes property water.
Someone should look into that, really.
Use Washing machine to power toilet and save water! bennelson Saving@Home 34 04-02-2010 11:13 PM
Rain water pattern on rear glass QuickLTD Aerodynamics 3 09-04-2009 04:58 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
turbine engine for a geo metro kane66 EcoModding Central 41 10-26-2008 05:39 PM
