Old 09-03-2017, 11:20 PM   #1 (permalink)
Lone Ranger - '97 Ford Ranger XLT step-side
90 day: 28 mpg (US)
Raising the rear?
I don't have a real world application for this so I guess it goes in the hypothetical column. If you had a car with a sloping rear but it sloped beyond the "template" could a gain be made by raising the rear (and possibly lowering the front) to better conform to the template? It would increase the height and I assume punch a bigger hole in the air but would there be any gain from better airflow over the top? Just a thought. Probably a simple answer but I like to try and learn when I can.
These are about the only real world examples I can think of.
ID:	22589  Click image for larger version
Old 09-03-2017, 11:36 PM   #2 (permalink)
Ecomodding amateur
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl
Team Chevy
90 day: 18.84 mpg (US)
the old bike - '83 Kawasaki KZ1100
90 day: 37.44 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
90 day: 59.71 mpg (US)
If you raise the back, lower the front or both you create more down-force. The smaller gap from the lower front makes the air expand under the back and "sucks" down the back of the car. I think that alone would counteract any gains seen from making it adhere better to the template.
I think there is still merit to the thought though. If you made a belly pan parallel to the ground at the same height as the front bumper it would eliminate the vacuum effect at the back. It would then conform to the template better. But it might increase the Frontal area a little bit. Too many variables to say yes or no I would think.
I know there are others on here more knowledgeable than I that could verify or deny my initial thoughts.
Matt
At 55 mph, a 10% drag reduction translates to a 5% increase in fuel economy. At 70mph,a 10% drag reduction translates into a 4% increase -Phil Knox (Aerohead)
Old 09-04-2017, 04:09 AM   #3 (permalink)
Stubby79's Avatar
Topoff (RIP) - '92 Geo Metro LSi
90 day: 48.54 mpg (US)
'91 Miata - '91 Mazda Miata
90 day: 27.11 mpg (US)
'86 Fiero GT - '86 Pontiac Fiero GT
Purple Penny Pincher - '95 Pontiac Firefly Base
90 day: 43.68 mpg (US)
Jett-Black - '01 Volkswagen Jetta
90 day: 39.32 mpg (US)
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Hmm....I'd pondered if raising the rear would be benefitial to give you that 4-degree rise to the underbody. That probably wont work without a completely flat underbody, mind you.
Old 09-09-2017, 01:35 PM   #4 (permalink)
inclination
The 1983 Ford Probe-IV concept (Cd 0.152) had active suspension to drop the nose and lift the tail on the highway,for minimum drag.They had the benefit of a wind tunnel to dial in the optimum inclination.
Other vehicles with active suspension which come to mind are:
McLaren P1
Tesla Model S P85
Jaguar XJ220
Bugatti Veyron 16.4
1985 Mitsubishi Galant
Subaru XT (static testing(
Renault Vesta-II
1984 Lincoln Town Car
1970 Porsche 914 (static testing)
1958 Buick Limited Series 700
2017 Ford GT
2008 Ford Fusion 999 LSR (static drop)
GM Ultralite
Old 09-09-2017, 10:36 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.78 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.47 mpg (US)
I had a van with torsion bar front suspension and leafs in the rear. I cranked down the front suspension to give me a bit of rake.
The lowered front end acted like an airdam reducing under car drag.
Hucho shows that filling the wake does reduce drag, so the idea has merit.
Old 09-11-2017, 12:18 PM   #6 (permalink)
If you do a lot of aerodynamic testing like Porsche did in the early 1970's you might be able to come up with a large Gurney Flap at the rear of the car that lowers Cd and raises top speed by also increasing down-force (Ducktail).
My guess is that just guessing at it will have unpredictable results.
However, the general idea I see is that anything you do to fill out the template, the better off you are.
Link to related thread - see numbers on chart I posted.
Aero Design Senior Project Community Ideas
More images in my rusty old dysfunctional bucket:
http://s184.photobucket.com/user/kac...?sort=3&page=1
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 09-12-2017, 01:23 AM   #7 (permalink)
Any good book on aerodynamics will discuss angle of attack. There is an optimum angle and height above the ground for a body.
Old 09-12-2017, 02:20 AM   #8 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
My grand mother had a '61 GMC 1/2 tone pickup with torsion bar front suspension that was miss alined from the factory. Too low (had a hevy rake) and set for handling/low resistance. After the first alignment to factory speck ,she ran 1 tank with a loss of MPG (I don't remember how much1-3MPG) and the truck handled like a raidal-flyer. She took it back had them reset the truck to the previous wrong seting and recorded the proper specks. Regained the lost MPG and. handling . The truck was maintained like that till '06 when she passed.
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 09-12-2017, 02:58 AM   #9 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Don't forget, you're also moving the highest point of the vehicle backwards. This would affect the boundary layer thickness on the roof as well as reducing the rear glass angle, perhaps for more improvement than you would otherwise think
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 09-12-2017, 09:36 AM   #10 (permalink)
I stumbled over this thread recently.
Stepped shape for flow attachment.
Chin Spoiler:
Roof Wing
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
