Old 01-19-2012, 01:56 AM   #41 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
You can feel the intake on my car sucking air from up to 6 feet in front of it... then again, there is a mechanical compressor doing the sucking. Regardless, even when made to suck more air, the turbo doesn't positively affect mileage. The ECU's target AFR needs to be adjusted so that the injectors use less fuel per a given amount of intake air as measured by the MAF sensor.
Old 01-28-2012, 11:04 PM   #42 (permalink)
20:11:20:16:22:16:34
Arctic Fox's Avatar
アキラ - '00 Passat B5 Wagon
I just installed this tonight on my 93 Sundance (v6; auto; 160k). The only thing I noticed was quicker throttle response at above 40 MPH. Mine is such an old car, I don't think much will really help it sans an engine rebuild.
-Addicted to Chaos-
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
WAI vs Ram Air Intake --- at speed... basslover911 EcoModding Central 33 07-17-2009 06:34 PM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
