Old 06-16-2017, 12:45 PM   #661 (permalink)
Primer is still paint!
ChopStix's Avatar
Found these while searching other things....
The second pic is my old van!
The Following User Says Thank You to ChopStix For This Useful Post:
aerohead (06-17-2017)
Old 06-16-2017, 07:37 PM   #662 (permalink)
Show me your rear end - Page 29 - Pelican Parts Technical BBS
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 06-18-2017, 08:49 PM   #663 (permalink)
Please, lose the advertising. And welcome to Ecomodder.
I would point first to the Search box in the upper left. Search on 'Hucho".
Then to Youtube: GraysGarage - YouTube
Finally, Automotive Technology - Bellingham Technical College
Old 06-19-2017, 04:51 PM   #664 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
Kyle.DRIVES youtube channel
Is a nother good sorce to help understand what is causing the air to move like it is.
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
aerohead (06-30-2017)
Old 06-23-2017, 05:55 AM   #665 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
https://youtu.be/_NPNiyR5cWo
MAN 's Concept S Vs curent production side by side cfd
Theres a nice cfd of a tear drop in ground effectat 1:01 and morphing into there bullet truck. at 1:07 .
Former
87' Hyundai Excel
Old 06-25-2017, 04:19 AM   #666 (permalink)
ChopStix's Avatar
Although NOT wind tunnel pictures, these are interesting aerodynamic pictures which show air flow effect during flight, taken of an F35 flying over an airshow.
Name:	ba8 - Copy.jpg
ID:	22086  Click image for larger version
Name:	baa - Copy.jpg
ID:	22087  Click image for larger version
Name:	be2 - Copy.jpg
Old 06-30-2017, 01:02 PM   #667 (permalink)
F-35
As compression ceases along the aircraft,the air behaves as any refrigerant,expanding,losing the heat of compression,falling below dew point to create the cloud as the water vapor condenses.
The same occurs inside the aircraft,as some air from the compressor section of the engine,as a working fluid, is run through an expansion valve,creating air conditioning for the pilot.
Old 06-30-2017, 01:22 PM   #668 (permalink)
...beats walking...
Old Tele man's Avatar
...that's also why such 'visible' effects only happen when RH% is high and temperatures are low to moderate...they don't appear under hot & dry conditions.
2014 Toyota Prius 1.8L eCVT
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2011 Chevrolet LTZ Cruze 1.4LT 6A
1971 Dodge Charger 318 3A
1970 Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
Old 07-01-2017, 02:21 AM   #669 (permalink)
ChopStix's Avatar
Those pic's were taken by my active duty friend while in Germany. They had the F35 at an airshow. Between the wingtip vortices and the clouding effect they are really cool pic's.
Old 07-01-2017, 01:32 PM   #670 (permalink)
It's interesting how the single phenomenon causes two different effects.
The blunt trauma of the bow wave[s] is circular, even though the cross-section of the aerobody is anything but, and dissipates immediately; while the wingtips induce vortexes that persist indefinitely.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
