Old 09-19-2010, 09:50 PM   #11 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
Originally Posted by Old Mechanic View Post
If you know the MAP, RPM, and fuel consumption, shouldn't you be able to map BSFC for any engine?
...yep, what I said earlier:
Originally Posted by Old Tele man View Post
...a computerized VACUUM gauge path toward realtime BSFC?
Best spark plugs / wires with FE in mind? noopy7 EcoModding Central 12 10-29-2010 03:18 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 06:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Oxygen sensor gauge reading at wider throttle openings markweatherill Instrumentation 4 08-28-2008 05:18 PM
MAF sensor life Daox Off-Topic Tech 9 03-25-2008 02:29 PM
