danvanman... Maybe some front and rear wheel spats(little things that deflect air), and again, smaller mirrors.
I'm thinking your's is manual, so add the switch that lets you P & G from your shifter knob to ease the transition. EOC, should be easy for you in many situations, just be careful if in case you are not using this already!(and you may be heavier/loaded).
GOOD going, keep saving them Imperial Gallons...
Reason: Adding stuff
