Old 10-28-2013, 04:01 PM   #1 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
Cherokee front air dam
Just installed the front air dam on the XJ Cherokee. This is easily removable if my destination takes me off road. I probably need to extend the sides out a bit farther but thought I would see if this makes any difference in FE.
I do not have any data yet but will let everyone know how it goes when it becomes available.
The Following User Says Thank You to Neen For This Useful Post:
aerohead (10-28-2013)
Old 10-28-2013, 06:07 PM   #2 (permalink)
Looks to be a clean installation at a minimum.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 10-28-2013, 06:12 PM   #3 (permalink)
You missed a great opportunity to give those front tires some needed coverage.
Old 10-28-2013, 06:18 PM   #4 (permalink)
Yeah I'm going to see what I can do to keep in looking clean but still addressing the wheels...perhaps I can score and readjust the angles on the dam "tails" without compromising the strength too much.
Old 10-28-2013, 08:26 PM   #5 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
What material is the dam? Almost looks like you've taken it off a different vehicle...
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 10-29-2013, 11:32 AM   #6 (permalink)
It's from a 1st gen S10 Blazer.
Old 10-29-2013, 05:51 PM   #7 (permalink)
looking clean
In the drywall section of The Home Depot they have a shallow black ABS plastic pan,about 18" X 36" for about $7.00.
The sheen of the ABS would be a good match to your airdam,and the pan has nice radii corners,which if cut down and integrated into the airdam,could provide the full coverage to the front wheels that Frank Lee recommended.
One pan would do the job.
Old 10-30-2013, 09:27 PM   #8 (permalink)
rav
Gas HOG - '08 JEEP LIBERTY SPORT
Here is how i did mine:
Front View:
Side view:
Like how the front pumpkin is all covered up
Also installed side skirts:
From a Blazer Xtreme, attached using 3M dual lock tape. Can take them off and put the back in less then 5 minutes. Tested them out at 75 mph on the freeway and they stayed attached, hope they help with the MPG too...
The Following 2 Users Say Thank You to rav For This Useful Post:
aerohead (10-31-2013), BamZipPow (11-02-2013)
