Old 05-15-2011, 01:31 PM   #1 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Rear deck/trunk extension instead of Kammback
I have been reading some old posts on this site (search function). I came across this post but no satisfactory discussion of it. So I want to repost the statement and start a new thread. A kammback on a coupe like mine tends to undermine visibility and trunk access. Would a truck/deck extension work as an alternative to a kammback? Here's the quote:
"Your cheap fix, is to create a rear deck spoiler which extends rearward,and upward,no steeper than 30-degrees from horizontal,until it intersects the line of the template. That will give you a locked vortex which the air above will skim over as if the car was more like the teardrop. If the spoiler is steeper,you'll start inducing downforce which is induced- drag,and that will cost you at the gas pump."
james
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 05-15-2011, 03:38 PM   #2 (permalink)
vskid3's Avatar
Civic DX - '97 Civic DX
90 day: 34.15 mpg (US)
GTO - '04 GTO
90 day: 22.62 mpg (US)
Have you seen Bonneville flat spoilers? Sounds like the same concept, except the flat spoiler is horizontal or angled down slightly instead of going up.
Old 05-15-2011, 04:04 PM   #3 (permalink)
Thanks! Using Bonneville flat spoilers as a search term I found this thread on this site:
Flat Bonneville-type spoiler
EDIT: here's a pick from that thread:
