Old 03-01-2009, 04:35 AM   #21 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 43.46 mpg (US)
alohaspirit -
Originally Posted by alohaspirit View Post
I think this is a great mod cfg83
hope to see updates
(maybe I should splurge and get 2 pans)
Thanks, I literally took maybe a year of looking around for what was in my head. I mostly looked in plant nurseries at the plastic "dura cotta" saucers, but they only got as big as maybe 20" diameter. Then one day I gave the plumbing section a try in Home Depot, and there they were, looking at me, as if to say, "where have you been all this time"?
I also think that they can be a stepping stone for a bolder aero mod :
rear wheel skirts...
Originally Posted by cfg83 View Post
malibuguy -
I have been thinking that my mod is probably better as "infrastructure". If you look at the picture above, you could cut out the center and use the surrounding "frame" as a base to attach varying skirt designs :
(the dots would be fastener locations)
The cool part is that the skirts could be attached with "quick release" connectors like dzus fasteners. You would have full access to the tire and you could more easily try different wheel skirt designs.
https://www.pegasusautoracing.com/pr....asp?RecID=758
I think that doing this would also negate the problem I cited in post #13 above, because cutting out the middle of the drain pan would make it more flexible to fitting in "close-but-no-cigar" wheel-wells.
Cutting out the middle is based on jthistle's idea of using a wheel flare as a "base" for a wheel skirt :
Fender flares to make front wheel skirt
However, I think the drain pan is a better "base" for mounting wheel skirts because you don't have to deal with the "curve" of the fender flare (hard to describe). You just have to mount the cover on a uniform "flat" surface. If I was more bold, I would make a cover for mine that looks something like this outline :
CarloSW2
American Solar Energy Society
Old 03-25-2009, 04:49 PM   #22 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
On my home to work route I got 61.8 MPG today. That is 0.2 MPG below my all-time record. What is interesting to me is that I had been driving without my rear wheel skirts for the last two weeks (removed for car wash and wheel rotation). :
1999 Saturn SW2 Trip Log : home to work ; 2009/03/25
ROUTE : 10 West -> 710 South -> 105 West -> 405 South -> Exit Freeway => Roughly 27+ miles
NET ELEVATION CHANGE : ~210 feet drop
SCANGAUGE "CURRENT" READINGS :
61.8 MPG,
0.4 Gallons,
206 Water Temp Max,
27.7 Miles,
2079 RPM Max,
0.5 Hours,
59 MPH Max,
47 MPH AVG
IAT READING : Hot Air Intake + dynamic grill block led to Input Air Temp readings of around 140+ degrees F.
WEATHER(.com) :
72.5 degrees F,
Sunny to Fair,
18.5% Humidity,
27 degrees F Dew Point,
30.045 in. Pressure,
TIME : ~11:16 AM to ~11:46 AM (PST), ~30 minutes
RECENT CAR CHANGES : I had just restored my rear wheel skirts. They were off for a week or two because I had my wheels rotated and a car wash. I went to an increased oil filter size on my last oil change. I also have a "dynamic grill block" mod that I haven't published yet.
HYPOTHESIS : "Good" Goldilox traffic (not too pushy). Bone dry weather. If I had a snail to follow, I think I would have hit my record.
I think that without the skirts, at my *minimum* assumption of a 1.36% gain, I would have lost 0.84 MPG, which would have knocked me just below 61 MPG.
There are a few other small mods I need to publish, but I think this is pretty neat.
CarloSW2
Old 03-25-2009, 11:37 PM   #23 (permalink)
Grasshopper
alohaspirit's Avatar
Windjammer - '96 Tracker
90 day: 27.02 mpg (US)
Budget "Insight" - '91 CRX
90 day: 50.96 mpg (US)
nice update
I would love to get 61.8mpg
sheesh, Id love to even get half that (30.9)
Past Present Future?
Old 03-26-2009, 09:26 PM   #24 (permalink)
Pokémoderator
cfg83's Avatar
alohaspirit -
nice update
Thanks, this is my "milk run", where all my best MPG comes from. I drive about 7 miles on city streets before I reach the freeway, so the engine is nice and toasty warm. These recent mods *might* have also helped, but it's way too early to say :
Larger than OEM Oil Filter ...
Spring mounted Grill Block
CarloSW2
Turning off electric hot water heater when not home? ZachUA Saving@Home 27 10-16-2009 08:04 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 25 09-06-2009 01:27 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 05:50 AM
Dream Wheel Skirt. Am I Crazy? 2003protege Aerodynamics 7 05-21-2008 02:40 PM
Solar Water heater extragoode EcoModding Central 5 03-31-2008 01:54 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
