Recommended rear shape and/or ducting
I have the following project trike (4-seater, like an extended Polaris Slingshot, with 3 wheels to make it street legal as a motorcycle) and am working on the tail end.
http://ecomodder.com/forum/member-mi...ototypetow.jpg I made that admittedly amateur sheet foam tail myself, but am curious if I, say, should be using a more or less aggressive tapering angle and also curious what I should do for the (now open) top. Any ideas? Will post more pics at different angles when I get home. |
more pics
If you can safely get up on the roof of the house,it would really help if we had images from above.
Is this a re-post?
Worse than a fastback design? http://ecomodder.com/forum/showthrea...tml#post517574 I even posted a sketch of it. http://s184.photobucket.com/user/kac...ml?sort=3&o=46 |
Recommended rear shape and/or ducting? Here you go:
http://st.motortrend.com/uploads/sit...rdGT_21_HR.jpg |
