Old 09-02-2008, 09:46 PM   #11 (permalink)
minic6
minic6's Avatar
Update front end in primer!!!!!!
Well I have to go back to work tommorow, so there was a big push to get the front end done. It is in primer far from perfect, but one step closer!!
The first pictrure shows how a metal ruler was used to keep the hood to front fascia gap equal. Next ready for primer. Between the fender and the bumper is a support, (round screwed in item) as the fenders have to come off several more times. Before the actual hidden supports are installed. Lastly how she looks today. Cable in rad. opening, is hood release. Since you can't lift the hood normaly, a candy cane shaped tube was attached to the core support, so when you pull on the cable it reverses the motion and lifts on the safty release. Fan did come on yesterday (almost 90) when car was coming off the freeway.
Old 09-03-2008, 11:38 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
That looks really good! I also admire the cowl on the hood. Thanks for the update!
Old 10-24-2008, 03:24 PM   #13 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
Nice work minic6. The lawn edging air dam looks good, I don't remember seeing that on your car before. What size did you use? I will need to do the rocker fix soon if I plan to drive mine for more than another year . I should probably gradute from packing tape on some of my aero mods that I've kept for over a year. Maybe I'll screw that kammback on next time it needs retaping.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 10-25-2008, 12:01 AM   #14 (permalink)
EcoModding Newb
trail rig - '02 ram 1500 sport
Last 3: 11.85 mpg (US)
looks great
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Lil' Red's Aero Mods sohl Aerodynamics 16 07-07-2009 02:19 PM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
