reducing drum brake drag
It just occurred to me that drum brakes tend to have an amount of drag that varies from light to moderate to light etc. over time as they periodically adjust themselves. To jack the car up and turn a wheel by hand really points this out.
Ha anyone here come up with a solution to the problem regarding the automatic brake adjusting mechanism setting the brake shoe adjustment such that the shoes drag on the drum? |
unfortunately that little bit of drag is federally safety mandated and you will never pass a safety inspection without it.
My experience with this is from my own vehicles and from thousands of vehicles I have serviced etc. (gas station work). One solution to this problem would be to remove the automatic adjuster levers and then just adjust the brakes manually every so often but that does not appeal to me at all. To keep disk brakes from dragging, a slight amount of lateral bearing play does the trick as this allows the wheel to wobble left to right forcing the calipers to spread the pads away from the rotor. But drum brakes are of course a completely different design. |
why they even use drums at all is a total mystery to me , discs are far more efficient and far easier to work on .. with the invention of discs the drums should have been dropped completely.. I don't get it , anything over 30 years old should be discs all the way around.
When chevy went back to drums after 4 wheel discs in trucks, the trend of large wheels came around. That is awesome marketing, knowing that brakes only last 10,000 miles on those custom trucks and suv's. It's THE MAN.
* word filter :rolleyes: |
There is a simple explano at: http://auto.howstuffworks.com/drum-brake2.htm It talks about the reverse braking type and the parking brake type of adjusters. I had never known of the parking brake type before reading your post. |
I pinned the adjusting wedge so it can't over adjust. also have small stainless steel springs holding the front pads off the disc. i check them often and adjust if needed. in addition i drill a small hold in the wear face of the drum to let out dust which can cause drag. but then i try to drive without using brakes. a set of pads usually last me about 90.000 miles.
