Old 09-11-2009, 07:10 PM   #11 (permalink)
I think it might help, mainly as wind fences on the sides. I think that is what lunarhighway is saying in post #9, point 1. I think wind fences could be beneficial on a lot things, particularly pickup trucks. I have done no testing to confirm or disprove this, just a hunch.
Old 09-11-2009, 07:53 PM   #12 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
As others have said, I think if you do something to prevent the flow from detaching at the back glass you might make use of the boundary layer effect.
However, I suggest you go ahead and try it! It would look cool, anyway
Old 09-11-2009, 10:10 PM   #13 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Yet another reminder is many of us experience strong x-winds on a regular basis. Once I calculated it and I see 11-22 degree yaws on a regular basis. I suspect fins in the yawed condition would be more a liability than an asset. A 14 mph x-wind can cut fe 13% at 55 mph.
Old 09-11-2009, 11:10 PM   #14 (permalink)
LegacyGT - '01 Legacy GT
90 day: 33.72 mpg (US)
Good point Frank. I think I'll stick to some vortex generators to achieve a similar affect.
Old 09-12-2009, 12:06 AM   #15 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
vortex generators
my car has a built-in vortex generator, it's called the *** end.
Old 09-12-2009, 12:07 AM   #16 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I was waiting for that response...
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 09-15-2009, 06:47 PM   #17 (permalink)
notch-back
You're graphics are top-notch! I like where you're trying to go but my brain has hit two glitches.I suspect that from the driver position,unless the vanes are splayed out to respect line-of-sight through the rear view mirror,you'll develop tremendous blind-spots at each side of the rear windshield.---------- The other thing that may enter the picture,is much surface area friction and shedding vortices behind each vane due to dead spots close to and directly behind each vane.--------- Something that worked on my CRX,was to keep the end plates and blend them into the C-pillars,then,at the "top" of the vanes,construct a single flat spoiler shelf which runs horizontally right up to the backlite.The air captured below the shelf will be below the Kamm profile,and above it,you'll have a single attached vortex which the outer free stream will bounce off,reattaching at the tail of the shelf.--------------- There's a lot less skin friction,it's simpler to construct,rear visibility is maintained accept at the extreme sides and it's lighter and should do the cleanup just as well.
CdA list Daox Aerodynamics 105 01-17-2012 09:48 PM
reducing drum brake drag Gregte DIY / How-to 40 10-19-2011 03:48 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
Increasing downforce while reducing drag? Hermie Aerodynamics 88 01-12-2010 01:10 PM
new drag reducing technology pmaltinsky Aerodynamics 26 08-01-2009 11:13 AM
