Register
Now
Reply
Old 07-27-2008, 12:18 AM   #1 (permalink)
SaturnSl1 - '00 SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ranger
CRX HF - '89 CRX HF
90 day: 51.59 mpg (US)
Reducing Road Noise?
Anyone have some ideas on how to reduce road noise? My CRX is absolutely terrible on the highway.
I'm looking for a cheap way to cut down the noise. Any ideas welcome.
Old 07-27-2008, 12:49 AM   #2 (permalink)
adrive7's Avatar
Ranger - '08 Ranger XL
90 day: 22.99 mpg (US)
Cobalt - '05 Cobalt LS
Zuma - '99 Zuma II
Send a message via AIM to adrive7
dynamat everywhere.
Ohio State Baja SAE
Old 07-27-2008, 01:38 AM   #3 (permalink)
Red
Red's Avatar
Heep - '01 Wrangler Sport
90 day: 16.78 mpg (US)
Dingbat - '00 Insight DX
Send a message via MSN to Red Send a message via Yahoo to Red
Spray in bed liner on the wheel wells works
Old 07-27-2008, 01:53 AM   #4 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
90 day: 50.49 mpg (US)
find a quieter tire, make sure all wheel bearings are in good condition
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-27-2008, 02:24 AM   #5 (permalink)
Box Dreamer
xB Commuter - '04 xB
90 day: 40.76 mpg (US)
Agree with changing a new set of tires. Check with reviews on tirerack.com. Yokohama AVZ and General Altimaz are all quiet tires I tired. It makes huge different from the stock original.
Also, drive slower. Statistic shows the noise on 60mph is much quieter than 80mph. Both wind noise, engine noise and road noise are much less. I tried that and it is true. I believe this is the cheapest, most notable and fastest way to quiet down your car on freeway.
Old 07-27-2008, 03:43 AM   #6 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Send a message via ICQ to justpassntime
You could use bedliner of some sort, sound deadening padding or dynamat. All of those require pulling the carpet out of the car with the exception of the bedliner. I used the cheap padding JC Whitney has under the carpet on my 73 Ranchero and used spray on bedliner in the bed. It worked really well.
Or you could do like people around here seem to do. Put a thumping stereo in your car and turn it up so loud it blows out all the bolts holding on the important stuff. Then one day when it coasts to a stop you'll wonder why it never gave you any warning.
Honda...the economical, renewable resource.
Old 07-27-2008, 11:57 AM   #7 (permalink)
SaturnSl1 - '00 SL1
CRX HF - '89 CRX HF
Here's what I'm thinking. Tear off all the carpet, at least in the back under the hatch and put some of the carpet padding under everything.
For the wheel wells, I'm thinking I could spray some insulation foam in there. It wouldn't give me access to some of the wiring, but I figure if the electrical wires have lasted 20 years, they should be fine for another 10.
That seems like the cheapest way to do it. $25 for carpet padding and maybe $5 for insulation foam.
Old 07-27-2008, 03:40 PM   #8 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
90 day: 65.53 mpg (US)
Install underbody panelling. A lot of "road noise" is actually noise created by the wind turbulence underneath the vehicle.
Old 07-27-2008, 04:01 PM   #9 (permalink)
bhazard's Avatar
The Shadow - '92 Shadow ES Turbo
90 day: 25.4 mpg (US)
Dad's Ranger - '94 Ranger Splash 2WD
90 day: 25.5 mpg (US)
The Festiva - '93 Festiva L
90 day: 47.95 mpg (US)
I know I do want to do something about the noise in my festiva. Its rediculous in there going down the road. I also have some noise coming from the back end, like wheel bearings (which I JUST replaced) or flatspotted tires maybe.
Old 07-27-2008, 05:27 PM   #10 (permalink)
SaturnSl1 - '00 SL1
CRX HF - '89 CRX HF
My underbody is surprisingly smooth. The only spot that air really gets stuck is when it hits the muffler, which sits about 2-3 inches lower than everything else. I'm thinking...other Honda CRXers can correct me, that this is because I don't have a stock muffler on my car.
I headed out to Menards a couple hours ago and bought $25 worth of 1/2" carpet padding (I wasn't about to pay the prices for padding meant specifically for cars). So far, I've finished installing it on the entire back half of the car. I also sprayed 2 cans of insulating foam ontop of each rear wheel well. Once I get the brakes fixed I'll be taking it for a drive.
Old 07-27-2008, 05:49 PM   #11 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.02 mpg (US)
I just drive slower to reduce noise. When it comes to cheap and effective, it's gotta be high on the list. I can't believe when I was younger/stupider when I drove so fast that I would just turn up the music to cover the noise! Gah!
Driving fast + louder music = bad FE. No wonder my earlier FE was a pitiful 33mpg.
I can't comment on sound absorption techniques as I'm too cheap/lazy to do them (and if I wasn't so lazy I'd pull out my rear seats and that will only make the noise levels inside worse I think). Plus at 40-50mph I don't really seem to mind the noise.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-28-2008, 01:48 PM   #12 (permalink)
Big Blue - '06 Dakota Quad SLT
Last 3: 20.2 mpg (US)
Miazda - '96 Miata mx-5
90 day: 36.48 mpg (US)
When I was young and poor, I gutted the interior, used roofing tar and roofing paper (I think that's what it's called) to line the interior and then reinstalled the interior. It made a noticeable difference. It insulated sound as well as temp.
Old 07-28-2008, 06:29 PM   #13 (permalink)
CobraBall's Avatar
Insulation at JCWhitney.com
The idea about carpet padding may just do the job. U should be able to get enough scraps from a carpet installer to do the car free of charge.
"roofing tar" ?? Inside a closed vehicle??? Doesn't it stink? Great car for a date?
Old 07-29-2008, 09:27 PM   #14 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
90 day: 54.79 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Damplifier Pro - Acoustic Vibration Dampening Mat
That's what's in my Ride; I need lots more, but I have to ecomod myself first.
I feel as though the more comfortable the car is the less I feel the need to hurry up and get out. It MAY be an acceptable trade off for some . . . .
Old 07-30-2008, 07:36 AM   #15 (permalink)
How about Snow Roof, it's a weather proof roofing compound like tar but without the smell.
Old 07-30-2008, 10:05 AM   #16 (permalink)
02 Golf TDI Driver
t JCWhitney.com[/url]
I once used peal and seal; worked Ok, not great, did smell, but not tooo bad.
Reply
Road Bike Update (and asking for more advice) GenKreton Alternative Transportation 7 09-03-2008 05:40 PM
Car making a scary noise jesse.rizzo Off-Topic Tech 5 04-12-2008 03:50 PM
Road Bicycle Buying Advice GenKreton Alternative Transportation 67 02-26-2008 09:40 PM
News: Maryland legislators may require cars to make some noise MetroMPG Fossil Fuel Free 9 02-22-2008 09:51 AM
If all the vehicles on the road were ultra-low Cd.... basjoos EcoModding Central 10 01-07-2008 09:34 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
