Old 04-28-2008, 08:55 PM   #21 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
The Corvette and Viper get away with the huge 0.5:1 overdrive because of their enormous low-end torque. The T-56 would be perfect for a diesel down to 3.0 liters or so.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 04-29-2008, 08:19 PM   #22 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Nice use of the BSFC maps, Daox.
I would only be concerned about running extremely low gear ratios if you were required to increase low-end torque. I wouldn't be concerned due to the complexity of that task, but rather that you will be putting immense loads through the transmission when geared so low.
I have no idea how over-engineered Japanese transmissions tend to be, but stripped gears seem to be a real possibility...especially if they are of the self-manufactured variety.
- LostCause
Old 04-29-2008, 08:25 PM   #23 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I have no Idea on the Tercel transmission, but the W58 is 200% over engineered, the R-154 is 300% over engineered and the Getrag is about 250% over engineered IMHO
I know that the 5sfe Camry 5 speed will do 200 Whp no problems as well (don't know transmission code)
6 speed ALH TDI
Old 04-29-2008, 09:29 PM   #24 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Yeah, the Tercel tranny is beefier than need be and I'm sure would hold up just fine. However, I won't be using a Tercel transmission in the car. It'll be swapped out for a Corolla trans to get the ratios I want along with a LSD since I am supercharging it. The Corolla trans is even beefier and proven to take over 300 hp.
Old 04-29-2008, 10:54 PM   #25 (permalink)
Liberti
LostCause's Avatar
I think I'm in the minority when I believe a transmission being 300% stronger is a bad thing. I understand why they do it, but efficiency-wise, that thing is 3x over-engineered (aka, heavy).
Good luck, though.
- LostCause
Old 04-30-2008, 09:08 AM   #26 (permalink)
6 speed Diesel FTW!
Diesel
Good luck, though.
- LostCause
All depends on the application in my opinion. In an efficient daily driver, Yes absolutely However in something that's going to be relentlessly pounded, and hot roded, No.
6 speed ALH TDI
Old 04-30-2008, 09:11 AM   #27 (permalink)
CM400E - '81 CM400E
There have been a few isolated incidents of guys doing drag racing with drag radials and eventually snapping differential parts. Going with the Corolla trans ensures me that this will not happen. I'd also agree with dremd's comment.
Old 05-29-2010, 10:32 PM   #28 (permalink)
skate - '92 Paseo
90 day: 48.56 mpg (US)
Why not go with changing the final drive? I drive a 92 paseo with a MT and think that the whole transmission is a little short in the ratio domain....
News: Toyota to provide fuel economy instrumentation in all models MetroMPG General Efficiency Discussion 13 12-18-2009 07:40 PM
Cheap Fix for a Tranny line? WaxyChicken Off-Topic Tech 18 02-14-2008 04:29 AM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 10:02 AM
Toyota Will Offer a Plug-In Hybrid Vehicle by 2010 SVOboy Hybrids 6 01-19-2008 02:25 AM
