Old 01-19-2008, 12:27 AM   #11 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
andy is right, probably 10hp to make a difference, the controller is key. a good driver can almost do as good as regen, maybe better if you count the weight saving.
Old 01-21-2008, 11:47 AM   #12 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
I've seen layouts for hybrids where there's one motor, mounted concentric with the engine. It's used as a starter motor and for braking regen and for propulsion when running electric+combustion simultaneously.
I confess to not knowing whether any production hybrids are using this or not. But it makes a lot of sense to me. A relatively simple design in that there's no additional clutching or belt drives etc. needed to make the parts spin. The down side would be that you're spinning both engine and elec. motor/gen whenever either is needed.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 01-21-2008, 12:16 PM   #13 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I believe that is how the Insight and 1st gen Civic hybrid work brucepick. I'm not sure about the 2nd gen Civic hybrid.
Old 01-21-2008, 06:05 PM   #14 (permalink)
Nomadic Chicken
WaxyChicken's Avatar
This is interesting stuff.
But it leads me to asking another question on the same font:
which would work better: Regen braking or windmills? (the windmills could be covered when driving and could popup or get uncovered when breaking - such as covered radiator air intakes) I'm thinking that they would work about the same. any input?
Old 01-21-2008, 06:59 PM   #15 (permalink)
MP$
Smile
I have a windmill that pumps air to the bottom of my pond 24/7, it weights over 300 pounds. cars have to be much lighter, but the windmill could be at home compressing air or charging batteries.
some of the hybrids have the motor built in to the engine flywheel, but engine doesn't turn until started.
"waxy" in WWII they had DC generators that were about 10hp the generator would start the 1 cyl. engine as a motor and then become a generator to make a power supply for their 24vdc equipment. back in the 60's I used one for several years as a motor on farm equipment. no controller it was either full on or off. so it has been done. if the motor/generator was small enough so it wouldn't fry the tires, it could used with just an on/off contactor and clutch, it would be rather jerky, but if hooked directly to a rear wheel it would be to bad, like a golf cart. Also I had an 8 hp lawn tractor and the generator had real heavy windings, it actually was used to as a starter to start the engine with its 12vdc battery.
pedestrian right will definitely improve as more and more of us become them.
Old 01-21-2008, 07:07 PM   #16 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
One day pedestrian safety will also be a factor on this side of the Atlantic like it is in Europe. I can't see that as being particularly pedestrian friendly...
Old 01-22-2008, 12:02 AM   #17 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I'm not sure about the civic hybrid, but I know for sure that the insight hybrid uses the hybrid drive motor as a motor, generator, and fly wheel, thus saving the weight of the fly wheel, and helping to smooth out the imballence in speed of the engine as it rotates.
diesel_john
As i understand it, the regen part is where it gets expensive. just a dc drive probably wouldn't cost more than 8 or 9 K$.
It shouldn't even cost that much, I was thinking $3,000-4,000 $700 or so for a really nice electric motor, $1,000-1,200 for lead acid battery pack, more for other chemistry, $1,000 for speed controler, wiring, and other electronics, and of course any of those parts can be upgraded for better, this is of course figuring that you are doing a pure electric vehicle, not a hybrid.
windmills on a car is just a bad idea, it's almost as good as useing boat ankers as a brake, they are going to do a lousey job of slowing you down in a comfertable way, and when you want yoru vehicle to move they are only going to slow you down, and if you are dreaming of powering your electric vehicle with on board wind... remember that to get reliable wind, you need to be no less than 30 feet higher then anything within 500 feet, this includes the roof of your car and people standing around, to do any less is a waste of money.
Old 01-22-2008, 01:48 AM   #18 (permalink)
Nomadic Chicken
i was referring to windmills not as a breaking system but as a recapture system.
EG:
1 - start hitting the breaks
2a - breaks engage and at the same time
2b - air intake on the nose of the car opens up allowing air to pass over the windmills to recapture electricity from wind. (or maybe uncover windmills under the spoiler.)
Old 01-22-2008, 02:08 AM   #19 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Think on that some more.
Old 01-22-2008, 07:35 PM   #20 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
An enthusiastic hypermiler in a car without regen will almost always go further on a given amount of energy than someone driving normally & using regen to recapture some energy slowing the vehicle down.
The hypermiler will only use as much energy as necessary to get the vehicle to the point where they can start coasting to reduce speed, where the "normal" driver will keep burning energy until they apply regen to slow the vehicle (more rapidly). The extra energy input + the conversion losses in regen = less efficiency.
Of course not everyone can drive without braking. So for the times you do have to press the pedal to the left of the accelerator, regen would be more efficient than friction brakes.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 06:50 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 10:03 PM
