Registering a car based reverse trike in CA
I'm considering making a Civic or Del Sol into a reverse trike. I believe this will make it classified as a motorcycle, because the 1500 lb. weight limit for three wheel "motorcycles" was recently lifted. My understanding is that this was done to make it possible to register three wheeled vehicles as HOV's, allowing them to use the carpool lane. The Honda I use will probably be a 1992 to 1998. The CA legislature is about to vote (or may have already voted), on a law that would require smog checks on 2000 or newer motorcycles. I'm assuming it will eventually pass. If I take a 92-98 Honda and make it into an RT, will the year of the vehicle be changed to 2009 or whenever I register it? One of the reasons for undertaking this project was to end up with a smog exempt vehicle. Anyone know about this?
Brian |
It keeps the year it was born with.
Go ask DMV then.
A vehicle converted into a 3-wheeler will probably be specially constructed and unless you're one of the first 500 in 2010, it'll have to comply w/ the model year emissions requirements.
Read up on the state statutes for your self, the DMV only knows the answers to the 20 most common asked questions and will tell you you can't do anything, if you can give them solid info they will give you more room.
Frank -
CarloSW2 |
Thanks, Brian |
Maybe the DMV doesn't know either? If I was doing it, I'd just keep the car registered as a car. So what if it has a bit of custom bodywork, at what point does it become fundamentally different from the kid who jacks up the suspension on his pickup? You'd be keeping the same engine & drivetrain, no? Keep the part of the body that has the VIN on it too, and logically you should be set.
I don't live in California, but here you just take the car to a smog check place every year, they plug in the OBDII connector & check the VIN, and the rest of a registration renewal can be done on-line. One year I even had my neighbor take the car for the check, and did the rest while I was at work - in Switzerland. |
