Old 06-18-2008, 01:52 PM   #11 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
As I understand it, there is actually less potential energy in higher octane fuel. So, if you don't need it to prevent knocking, then save your money.
Old 06-18-2008, 07:08 PM   #12 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by RH77 View Post
Which parameters to choose?
Even if you could compute FE from the params, would you be confident you could distinguish a few percent difference, if any, by switching fuels?
Unless you burn a LOT of fuel driving the exact same route day in & day out, you're facing the same data reliability issues everyone has who wants to test fuel and/or additives.
That said, by default, I think I'd probably go with regular in a car with a knock sensor.
Old 06-19-2008, 01:14 AM   #13 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Good points.
The vehicle is a commuter for my Wife (to work and school both), who has the same route except for the weekends. I would say she fills once a week -- FE is pretty stable at 29-31 this time of year (unless I drive it ). If it dips down to 27 or 28, then it may not be worth it (which is what happened during Winter). But Winter is Winter, as we know.
So, should the ECU be reset for such a change, or would that make it an unfair learning curve for a baseline?
We'll fill up with Reg next time 'round and see how it goes.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 06-19-2008, 01:22 AM   #14 (permalink)
Hyundai Accent - '01 Accent
90 day: 38.4 mpg (US)
Gixer - '97 GSXR600
90 day: 43.12 mpg (US)
Just to further complicate things, the octane rating on the pump is the minimum octane for that grade. there is no rule about them selling a higher octane than stated. In states where ethanol must be blended in 5 or 10 percent with regular gasoline, the "regular" might be the same octane as the mid grade or premium.
Old 06-19-2008, 12:14 PM   #15 (permalink)
Mr. Miragi - '96 Mirage S
90 day: 27.45 mpg (US)
higher octane gas also lets you run at a lower rpm without lugging it. On 87 my mirage wont do 35 mph in fifth. But with 89 or 91 it will do 30 no problem, of course till i get to a hill, but it will still creep up most hills at 35.
Old 06-19-2008, 12:26 PM   #16 (permalink)
Rick: I don't think there's any need to reset the ECU - a knock sensor is an immediate reaction type of thing.
gteclass: good point if you have a manual transmission.
Old 06-19-2008, 03:36 PM   #17 (permalink)
Bingo!
Local tv station did a report on this about a year ago. They took samples of 87 89 and 91 octane from a number of local gas stations to a lab to be analized. They found all the samples tested between 90-92 octane with anywhere between 10-15% ethanol content. All the gasoline came from the same refinery and the only variation was the ammount of ethanol mixed in.
Old 06-19-2008, 06:19 PM   #18 (permalink)
RH77's Avatar
Thanks Darin -- now I won't have to lookup the radio code . Also, I can force somewhat of a bog with the manu-matic shift, in 5th, TC lockup, and at the bottom of the speed band (I think it's 50 mph -- I don't drive it all that often, so not sure). I'll be curious as to how it "acts".
So do they use Xylene anymore? I used to "make" my own racing fuel just by adding xylene to a tank. I was told (at the time -- 2003) that each brand dumps their own additives into the tanker truck just before it leaves for the stations.
What I find interesting is buying gas in the State of Iowa. Mid-Grade is the cheapest (often by 10-20 cents) because it's 10% ethanol (and likely subsidized). 87-octane is the next most expensive, followed by 91.
The first time I saw it, I thought they were having a "Sale" on mid-grade. I don't know if folks remember, many Amoco stations used to have all grades the same price on like Tuesdays or something.
Truthfully, I haven't been bold enough to try it to see if FE plummets (plus, I've been turned off by the current ripple running through the world as a result of ethanol production (and locally with . I do a lot of driving in Iowa
Maybe I'll give it a shot on the mid-grade to see what happens. I often hear of a certain percentage of Ethanol being a good thing for FE.
RH77
EF5 / 22-May-2011
_
_
octane, premium gas
Mercedes modded C-class: Cd 0.25. Up 7.5 mpg over regular model (with other mods). MetroMPG Aerodynamics 19 07-19-2009 03:58 PM
Different Types of Oil MasterAlex EcoModding Central 12 06-25-2008 11:34 PM
GAS is 4.50 for Regular in Los Angeles dsq EcoModding Central 10 06-06-2008 04:11 PM
